onion57 Posted May 21, 2008 Share Posted May 21, 2008 First of all hello everyone, and yes I'm a complete noob at using this program. I'm using version 3.31, and having trouble selecting various layers (I'm designing a sig) instead of the entire picture. This should probably be simple, yet I'm confused. Any help would be appreciated. Thanks. Link to comment Share on other sites More sharing options...
Simon Brown Posted May 21, 2008 Share Posted May 21, 2008 Are you asking how to select multiple layers simultaneously? Link to comment Share on other sites More sharing options...
subiewrex Posted September 19, 2008 Share Posted September 19, 2008 Searching landed me here, i'm trying to figure out how to select multiple layers simultaneously. Any suggestions? I have 3 layers I would like to move around together. Link to comment Share on other sites More sharing options...
LFC4EVER Posted September 19, 2008 Share Posted September 19, 2008 onion57, you can't select multiple layers and move selections about on them at once. If you're trying to move a few things on different layer to another position, then use the Panelling plugin: viewtopic.php?f=16&t=3074&hilit=panelling then just press Ctrl + F on each layer. __________ subiewrex, like i said above you can't select multiple layers, but you can try the suggestion above. If it is what you need. ☆★☆★Merry Christmas★☆★☆ .::.My Gallery.::.Make Gold Text!.::. Link to comment Share on other sites More sharing options...
Ash Posted September 20, 2008 Share Posted September 20, 2008 No, the first thing you need to do is update to the latest version of PDN. No support for old versions. Wait, this is a 4 months old topic. Locked. All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
