ddbaker95 0 Posted October 23, 2009 Report Share Posted October 23, 2009 SWEET! thanks man!! Quote Link to post Share on other sites
Bleek II 0 Posted May 30, 2010 Author Report Share Posted May 30, 2010 With the Displacement On? checkbox checked, it acts like a displacement filter; without, it acts like an alpha masking filter. That is, to use it like my original plugin, just leave that box unchecked and import a file. Also, Bleek, I suggest having a catch (System.IO.FileNotFound) in the try...catch of the EffectConfigToken.GetImage() if you do update it again. And have the return fallback be an embedded single white pixel instead of null... it tries to read from file for every single pixel if you don't. If you're still around. I just got back to working with PDN. I've been MIA for a long time, sorry. Yeah, I know this is sort of an odd plugin being a mixed Alpha/Displacement mapping plugin. The reason I made it that way is because I hate having to dig through the hundreds of plugins in PDN just to get to the one I want. I wanted to have a universal mapping plugin. I know that Curtis has made several mapping plugins that have "better" UIs than mine but this one still has a few features that are needed by myself and others. These features include adjustment of neutral value, standard edge behavior, mask alpha clipping, and 0 pixel value exclusion. As a professional artist and not programmer I need these tools. I have lost my copy of visual studios and can't update this plugin anymore. I have to ask you to become the maintainer of this useful plugin. I will post any updates that you make and give you credit for them. Thank You. Quote Link to post Share on other sites
csm725 8 Posted May 30, 2010 Report Share Posted May 30, 2010 Bleek, you can download Visual Studio Express 2008 / 2010, it is free. Quote My deviantART | Sig Battles | My Tutorials | csm725.com Click to enter or vote in the official Paint.NET competitions! COMPETITIONS: LOGO OF THE WEEK Link to post Share on other sites
Bleek II 0 Posted May 31, 2010 Author Report Share Posted May 31, 2010 Bleek, you can download Visual Studio Express 2008 / 2010, it is free. Awesome, thanks! I'm a little out of touch when it comes to programing. BTW, I wasn't bashing Curtis' mapping plugins. I was worried that it sounded that way. If his displacement plugin had all the features of this one I would delete my own and use his better UI. Quote Link to post Share on other sites
Sarkut 7 Posted May 31, 2010 Report Share Posted May 31, 2010 (edited) I have found your plugin to be very useful. Use it regularly. Load Mask from Clipboard would be a valued feature, if it's possible. This code may be relevant to that. Re: Load from Clipboard Edited May 31, 2010 by Sarkut Quote Link to post Share on other sites
warfighter67 1 Posted May 31, 2010 Report Share Posted May 31, 2010 My alpha mask plugin already has built in "mask from clipboard" as well as the original "pull from file" IDR who's it was though, I have so many plugins installed it takes almost 30 seconds for PDN to start up XD Quote My Soundclick!--Well of Souls MMO--Gallery--Facebook--Photobucket--Cool Tile Texture! Link to post Share on other sites
Sarkut 7 Posted May 31, 2010 Report Share Posted May 31, 2010 Yes. Illnab1024's Alpha Mask Import plugin has it. It would be very nice to have to use with the displacement function. Quote Link to post Share on other sites
Bleek II 0 Posted May 31, 2010 Author Report Share Posted May 31, 2010 Okay I see how awesome that clipboard thing is. I'll try to make a version of this plugin with that feature by next week. I also plan on removing the alpha mask part of this plugin because it seems to be a source of confusion. Quote Link to post Share on other sites
Sarkut 7 Posted August 7, 2010 Report Share Posted August 7, 2010 Is Load Mask from Clipboard still a prospect? Quote Link to post Share on other sites
KellyJ13 4 Posted June 14, 2013 Report Share Posted June 14, 2013 I tried to watch the video but it takes too long to download Is there a newer alpha mask/displacement tutorial? Quote Link to post Share on other sites
KellyJ13 4 Posted June 14, 2013 Report Share Posted June 14, 2013 BTW I tried to let the video download for 20 minutes and nothing happened. Quote Link to post Share on other sites
doughty 326 Posted June 14, 2013 Report Share Posted June 14, 2013 (edited) This is it on You Tube: Edit: Hope this is the one you meant. Edited June 14, 2013 by doughty Quote Link to post Share on other sites
KellyJ13 4 Posted June 15, 2013 Report Share Posted June 15, 2013 Thank you I found it helpful. Quote Link to post Share on other sites
KellyJ13 4 Posted June 19, 2013 Report Share Posted June 19, 2013 One question after watching the video: Can you use the Alpha along with custom brushes? And how do you do this? Quote Link to post Share on other sites
doughty 326 Posted June 19, 2013 Report Share Posted June 19, 2013 Found a tut that makes sense to me. Yes you can, just treat it similar to what's shown in the tutorial. Hope it helps. http://forums.getpaint.net/index.php?/topic/21508-improved-grafitti-technique/ Quote Link to post Share on other sites
KellyJ13 4 Posted June 19, 2013 Report Share Posted June 19, 2013 Thanks, Doughty Quote Link to post Share on other sites
preeber 0 Posted April 23, 2016 Report Share Posted April 23, 2016 When I open Alpha displacement the menu is all When I open Alpha displacement the menu is all messed up. Quote Link to post Share on other sites
kennethwalls 0 Posted July 12, 2016 Report Share Posted July 12, 2016 I am a rookie at this and I'm trying to install this Displacement and Alpha mask plug in... each time I try to install, I get a message saying it could possibly corrupt the computer but I insist on running anyway... down pops a list of apps to use to open the zip file and I check use another app... I find the paint.net folder in Programs Folder and use the Setup application file to install... it doesn't like that option... can anyone give me a clue as to what I need to do? Thanks in advance... BTW the project I'm working on is an animated GIF of the American Flag to use as a 'signature' in email. Any help would be greatly appreciated as I'm right near the end of putting it all together and can't find where I need to adjust the Alpha Mask to '0' in the paint program.. so apparently, I need this mask plug-in... Thanks again~~ paint.net version 4.0.9 Quote Link to post Share on other sites
Ego Eram Reputo 2,758 Posted July 12, 2016 Report Share Posted July 12, 2016 You need to unzip the file first. Paint.net does not do that. Full instructions can be found here: http://boltbait.com/pdn/InstallingEffects.php Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
Sakana Oji 33 Posted January 5, 2019 Report Share Posted January 5, 2019 This needs a clipboard function Quote Big McThankies From McSpankies! Link to post Share on other sites
Philon 0 Posted January 16 Report Share Posted January 16 On 4/22/2016 at 11:09 PM, preeber said: When I open Alpha displacement the menu is all When I open Alpha displacement the menu is all messed up. Same with me. It seems to be a common problem with older plugin UIs combined with high-res monitors. I'm a n00b to paint.net so I'm not sure if there's a fix. Haven't found one based on my searches. Quote Link to post Share on other sites
toe_head2001 1,792 Posted January 16 Report Share Posted January 16 3 hours ago, Philon said: It seems to be a common problem with older plugin UIs combined with high-res monitors. I'm a n00b to paint.net so I'm not sure if there's a fix. Haven't found one based on my searches. A new version of the plugin will need to be published. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
ardneh 50 Posted January 16 Report Share Posted January 16 (edited) The controls look okay in paint.net 4.2.15 alpha build 7683. . Edited January 16 by ardneh Quote Link to post Share on other sites
toe_head2001 1,792 Posted January 16 Report Share Posted January 16 30 minutes ago, ardneh said: The controls look okay in paint.net 4.2.15 alpha build 7683. It's an issue with HiDPI scaling. The version of Paint.NET you're using is irrelevant. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
