Problem updating from v3.30 to v3.31 with vista
Hi
I had been using version 3.30 without any problem and the last time, I got a message asking me to update and after acepting, the update appeared to be installed, then I closed the program and after that I have not been able to open it again. I tried uninstalling and installing v3.31 directly again but I get the following error message while running the installer:
"There was an error while installing Paint.NET (1622)
Error opening installation log file. Verify that the specified log file location exists and that you can write it"
Also, I tried to go back and install v3.30 but that showed this same error, this happens even previous to allowing which directory should PNET be installed. I don't know where is the installation log file....Also tried customized installation, save it in another direction and still got the same problem....
Please Help!!!
