danelover Posted May 1, 2008 Share Posted May 1, 2008 I was having the problem where Paint.NET wouldn't open, then I downloaded the Windows Install Clean Up and I removed Paint.Net with the program. But when I try to install it again I get "Paint.Net Setup Front-End has encountered a problem and needs to close." Is there anything I can do?? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
BoltBait Posted May 1, 2008 Share Posted May 1, 2008 Have you tried these steps yet? viewtopic.php?f=10&t=854 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
danelover Posted May 2, 2008 Author Share Posted May 2, 2008 Have you tried these steps yet?viewtopic.php?f=10&t=854 Yes. I already have Microsoft .NET Frameworks 2.0 installed. But after I click "change/remove" and then "repair", I get "Microsoft .NET Framework 2.0 has encountered a problem during setup. Setup did not complete correctly." Should I install Frameworks 3.0? Could this be my computer? Or is it Paint.NET that's having some kind of problems? Because my Microsoft Zune program is not opening the same way too Quote Link to comment Share on other sites More sharing options...
BoltBait Posted May 2, 2008 Share Posted May 2, 2008 Sounds like the problem is with your framework. Fix that and I'm sure Paint.NET will work better. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
danelover Posted May 2, 2008 Author Share Posted May 2, 2008 Sounds like the problem is with your framework. Fix that and I'm sure Paint.NET will work better. Ok thanks! I'll download the Frameworks 3.0 and see it that works! Quote Link to comment Share on other sites More sharing options...
danelover Posted May 2, 2008 Author Share Posted May 2, 2008 OK so I tried to download Frameworks 3.0 but I got an error report which said [05/02/08,15:07:36] Windows Communication Foundation: [2] Error: Installation failed for component Windows Communication Foundation. MSI returned error code 1603 [05/02/08,15:07:43] WapUI: [2] DepCheck indicates Windows Communication Foundation is not installed. [05/02/08,15:07:44] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0 was not attempted to be installed. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted May 2, 2008 Share Posted May 2, 2008 Try to google the error message to see what help you can get. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
