Mike Ryan Posted April 30, 2008 Share Posted April 30, 2008 Alright, this issue appears with all colors on all blending modes. If you set the alpha level of the paintbrush to 1, no matter how many times you click in the same area the alpha level stops increasing at 128. This is, to the extent of my knowledge, not the same with other alpha levels. Quote Link to comment Share on other sites More sharing options...
Ash Posted May 1, 2008 Share Posted May 1, 2008 I just tried it, Black Hex=000000 Alpha=1 After many clicks it does turn to alpha 255..... But This color Hex=7F7F7F Alpha=255 What the... :shock: :?: Edit: Hex=000000 Alpha=2 will turn into... Hex=3F3F3F Alpha=255 Edit2: Any alpha level below 128 will not give you the same color as you start out with. Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
Mike Ryan Posted May 1, 2008 Author Share Posted May 1, 2008 Confirmed. As well, while Ash may not have my problem my problem is still occuring. It seems anything after 128 gets messed up. Quote Link to comment Share on other sites More sharing options...
