d.rojas Posted April 24, 2008 Share Posted April 24, 2008 I used the eraser Tool. I set the transparency to 30%. When I stay longer somewhere then it erases more than needed! Can you fix this problem? Quote :-P Link to comment Share on other sites More sharing options...
Simon Brown Posted April 24, 2008 Share Posted April 24, 2008 Here is a way you can still achieve what you want until the problem is solved: Open the image, duplicate the layer, set the transparency of the new layer to 255-the eraser transparency you want, make sure the eraser is set to 255 alpha, click on the lower layer and erase as normal. Then merge the layers. Quote Link to comment Share on other sites More sharing options...
Myrddin Posted April 26, 2008 Share Posted April 26, 2008 This is a known issue of the current brush system. You will find the same behaviour with both the Eraser and Brush tools. If I remember correctly, Rick - the lead developer - has disclosed a 'fix' for when the new brush system comes into play during the development of v4.xx. I could be mistaken and it was, in fact, another member, but when all said and done, he is the one who truly knows what is in store for Paint.NET. Quote How to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
