Kaiden2 Posted April 22, 2008 Share Posted April 22, 2008 Ok i have tried numerous times to create a redial gradient or realy any type of gradeient that fades from coloured tranparent to completely transparent. The best i got was makeing a tansparent gradient and then deleteing the white background. Which didn't work to well because there still seemed to be white behind the colour. Like others im fairly new to paint so could some one please tell me how to fade a gradient to transparent :?: Quote My subconscious is consciously aware that I am subconsciously unconscious. Link to comment Share on other sites More sharing options...
Simon Brown Posted April 22, 2008 Share Posted April 22, 2008 Do you mean like this? Quote Link to comment Share on other sites More sharing options...
Ash Posted April 22, 2008 Share Posted April 22, 2008 On a transparent layer 1st color's alpha=255 2nd color's alpha=0 http://www.getpaint.net/doc/latest/en/ColorsWindow.html Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
flarn2006 Posted April 23, 2008 Share Posted April 23, 2008 Try enabling the Alpha gradient mode (click on :AllColorChannels: in the toolbar to turn it into :AlphaChannel: with the Gradient tool selected) and see if that does what you want. Quote "The Enrichment Center reminds you that the Weighted Companion Cube will never threaten to stab you and, in fact, cannot speak." — GLaDOS Link to comment Share on other sites More sharing options...
Kaiden2 Posted April 23, 2008 Author Share Posted April 23, 2008 I tried what Ash suggested and it worked perfectly, thanks for the help. I just didnt relize that the secondary colour was used as well. Quote My subconscious is consciously aware that I am subconsciously unconscious. Link to comment Share on other sites More sharing options...
Ash Posted April 23, 2008 Share Posted April 23, 2008 You're welcome. Glad it worked Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
