punisherjb Posted April 11, 2008 Share Posted April 11, 2008 heya does anyone know how to make a rasengan or a chidori in paint.net? i make them but they are really rubish any tips?thats a rasenganand thats a chidori Quote recently converted from photoshop Link to comment Share on other sites More sharing options...
Rubrica Posted April 11, 2008 Share Posted April 11, 2008 Could you please post an example of what on earth those thing are? Quote Link to comment Share on other sites More sharing options...
Myrddin Posted April 11, 2008 Share Posted April 11, 2008 Are you requesting help with an animation, or a still with the flares emanating from some object? If the former, then Paint.NET, as you should know is no native animation application, however we do have a tutorial listing the steps to create the frames for the animation. You will need an external program for the animating, naturally. If the latter, there is a topic that I remember posting in which has a mini-tutorial explaining a very similar result. I will try and locate this again. ---- Also, not wishing to be a bugbear, your topic title is a little obscure. How is anyone to know what 'these' are? ---- EDIT: take a gander at this topic; the link should take you to a post from screenmutt containing an off-site tutorial: viewtopic.php?p=130199#p130199 That should give you an idea how to make the off-shooting energy bolts from your exampled images. If the tutorial proves too Photoshop-orientated for your liking, I give some small tips in my following post in the topic. Quote How to Use Images in Your Posts, Signatures, and AvatarsHow to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
