Whispered Posted July 2, 2008 Share Posted July 2, 2008 Ok, I just want to ask, will the computer (Running Windows XP SP2 Home) pick up the pointer things from whereever they are? Or is there a system file that you need to save them in? Quote Link to comment Share on other sites More sharing options...
Myrddin Posted July 2, 2008 Share Posted July 2, 2008 You should proceed to Control Panel > Mouse > Pointers tab, select which cursor you wish to change in the list, then browse for the replacement cursor. It would be best to have all your new cursors that you have created in a folder of its own, simply for organisation and for ease of locating. Now, when you're happy with your new setup, you can save your new pointer scheme via the Save As dialog for future use. Does this make sense? Quote How to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
Raw Voltage Posted July 3, 2008 Share Posted July 3, 2008 awsm thonks sabrown!!! tis plugin r awsm!!! Quote Link to comment Share on other sites More sharing options...
ksuviper Posted July 9, 2008 Share Posted July 9, 2008 is it possible to get 16-bit format added to the available formats? Quote Link to comment Share on other sites More sharing options...
drew Posted July 15, 2008 Share Posted July 15, 2008 Thank you for this plug-in. It works wonderfully! Quote Link to comment Share on other sites More sharing options...
Krudtso Posted September 3, 2008 Share Posted September 3, 2008 Well Blast. I guess I'll be sticking with my 3.10 install and associated plug-in(s) for a while... Can you uplaod the version of this plugin you have and give me a link? Because i would realy like to have the possibility to make individual sizes into 1 icon. Quote Link to comment Share on other sites More sharing options...
Ash Posted September 3, 2008 Share Posted September 3, 2008 Use the latest version Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
jiZer Posted September 15, 2008 Share Posted September 15, 2008 I love this plugin! i have made so many icons with it thx so much for this! Quote Simplicity ftw! Link to comment Share on other sites More sharing options...
Chadmstraight Posted September 30, 2008 Share Posted September 30, 2008 This is really nice. I've searched for days on download.com for a good icon/cursor program, but all the free ones where really low quality. So, thanks for this plug-in. Quote Link to comment Share on other sites More sharing options...
zzz92 Posted October 1, 2008 Share Posted October 1, 2008 Great plugin! Love it! now i dun have to use noob programs tht still wans me to pay! But how do you make an icon like lets say recycel bin? It's empty and it show's it empty but when it has smth it will show crushed paper inside. How do you make it? Quote L i f e I s C o l o r f u l Link to comment Share on other sites More sharing options...
Ziusudra Zoon Posted October 15, 2008 Share Posted October 15, 2008 Great plugin! Love it! now i dun have to use noob programs tht still wans me to pay!But how do you make an icon like lets say recycel bin? It's empty and it show's it empty but when it has smth it will show crushed paper inside. How do you make it? In XP you can make two separate icons and set them using Display Properties - Desktop - Customize Desktop. Quote Link to comment Share on other sites More sharing options...
zzz92 Posted October 16, 2008 Share Posted October 16, 2008 In XP you can make two separate icons and set them using Display Properties - Desktop - Customize Desktop. Hey thx! but what about folders? Quote L i f e I s C o l o r f u l Link to comment Share on other sites More sharing options...
nathan63134 Posted October 17, 2008 Share Posted October 17, 2008 can you edit gifs from the internet Quote Link to comment Share on other sites More sharing options...
MiguelPereira Posted October 18, 2008 Share Posted October 18, 2008 can you edit gifs from the internet If your question is not Paint.NET related this isn't the proper place, try the Overflow section of the forum And to answer your question, no Paint.NET can't edit anything through the Internet, there are probably some sites that have such software, but this is not an option of Paint.NET, nor will it be. Quote [The stock on my sig is a photo I took not a render from Splatter] [My deviantART][My Gallery][My Space] Link to comment Share on other sites More sharing options...
gOUJOSAMMA Posted November 11, 2008 Share Posted November 11, 2008 Ha Haaa, my winamp skins will be complete... You sir, are now a god. Wear it well. GS Quote My Stuff Link to comment Share on other sites More sharing options...
dovella Posted November 12, 2008 Share Posted November 12, 2008 I have always used this plug in and love it , but tonight does not work well, and it's strange the same effect l I had to every PC (3 pc) Incredible Max work 32x 32 why not 256 x 256? were is a problem? ps excuse me my english Quote Link to comment Share on other sites More sharing options...
Conjured Posted November 14, 2008 Share Posted November 14, 2008 Thanks! This is a wonderful and most needed plugin. This plugin should be a standard feature included in the Paint.NET install. It is greatly appreciated. Many thanks. Quote Link to comment Share on other sites More sharing options...
AlperDmr Posted November 24, 2008 Share Posted November 24, 2008 I have to say that: You're the one, you're the champion.... :wink: Quote Link to comment Share on other sites More sharing options...
Ulriksen Posted December 12, 2008 Share Posted December 12, 2008 nice plugin, however is there any chance for 24 or 16 bit support? Xp/.Net framewor 2 keeps throwing exception on 32 bit. Quote Link to comment Share on other sites More sharing options...
rogerdpack Posted January 23, 2009 Share Posted January 23, 2009 This plugin should be a standard feature included in the Paint.NET install. Yeah .ico support should be built in. Where can I donate for this amazing plugin? -=r Quote Link to comment Share on other sites More sharing options...
DavidJCobb Posted March 7, 2009 Share Posted March 7, 2009 Perhaps you could bring back the ability to save icons with multiple, differently-sized images without using a transparency-based hack... What you could do is, have the user name each layer -- the 48x48 icon layer would be named "48x48", the 32x32 icon layer would be named "32x32", etc. -- and then just add an option that would have the plug-in check the layer names at runtime. Quote dA | CWF Link to comment Share on other sites More sharing options...
Possum Roadkill Posted May 2, 2009 Share Posted May 2, 2009 This is wonderful. Thanks ! I really need this. Quote My Gallery SAC, WOTW and Photo Manip Competition Host To visit the Comps click HERE Link to comment Share on other sites More sharing options...
evanolds Posted May 10, 2009 Author Share Posted May 10, 2009 This plugin should be a standard feature included in the Paint.NET install.Yeah .ico support should be built in. Where can I donate for this amazing plugin? -=r If you are considering donating (which is always appreciated ), I have a donation page that I put up today at www.evanolds.com/donate.html. Perhaps you could bring back the ability to save icons with multiple, differently-sized images without using a transparency-based hack... What you could do is, have the user name each layer -- the 48x48 icon layer would be named "48x48", the 32x32 icon layer would be named "32x32", etc. -- and then just add an option that would have the plug-in check the layer names at runtime. This is a possibility, however this and pretty much all other options are kind of "hacks" in the sense that they're getting around the fact that Paint.NET isn't really suited for editing multiple images of different resolutions in a single document. I and several others have authored separate applications for icon editing that better serve this purpose. Now I realize that a lot of people don't want to have to download a separate utility application and they'd just like it all to be in Paint.NET. While I can't say I disagree with this, I do think that for more serious icon editing and deployment, you'll probably have to use a separate app. So I guess some questions that I'd want to ask people are: 1) Are you aware of the numerous other free applications that do icon/cursor editing? 2) If so and you're not using them, why is that? Is it just because you do the editing in PDN and don't want to do the extra step of saving your intermediate work, reopening in another app, and then resaving? Is it because you'd just rather not download another application to your hard drive? 3) If you aren't aware of them, would you be more eager to be informed about them or would you rather some sort of workaround be added to this plug-in to make Paint.NET have extended icon/cursor editing capabilities? 4) Are you happy enough with the way this plug-in is and would rather have me work on new plug-ins that do new things, instead of tweaking other plug-ins to try to accommodate the needs of the more advanced users? I assure you that these are honest questions and aren't trying to imply something by just being posed. If any current users of this plug-in can give their feedback, I'd appreciate it. Quote There are no warranties whatsoever on my plug-ins. Use them at your own risk. You may redistribute them if you'd like, but I'd prefer you just link to the download on my site. Please do not modify and redistribute. Link to comment Share on other sites More sharing options...
Rhapsody Posted May 26, 2009 Share Posted May 26, 2009 I use this great plugin in combination with IcoFX. (freeware) I use Paint.NET to open existing icons and use Paint.NET to edit portions of it. After that I export it to png and use IcoFX to build the icon for me. Quote In Metal We Trust Link to comment Share on other sites More sharing options...
Axle Posted September 22, 2009 Share Posted September 22, 2009 cool, this could be quite nice Quote My Deviant Art | My Gallery Link to comment Share on other sites More sharing options...
