Help with Jpg Pictures. They aren't visible
Hello forum, and praise the Lord:
I'm a Newbie here and I just want to read posts and learn the tuts, but I'm having trouble seeing most of the jpg pictures in the tut's. :( Especially in the step by step ones. All I see is a small white box with a small red x that says "image."
Is there some simple fix to this? Thanx so much.
In Christ, Judah
First of all, welcome to the forums.
Please take a look at the rules, and you will see this is for Tutorial Publishing Only.
To answer your question:
It might be due to the image being deleted or moved of its original host, causing a broken link. Or it could be still loading, that happens to me sometimes. Did you try refreshing? Which tutorial caused this problem, could you provide a link?
Call me expired. Please.
Don't go counting your chickens before the pack of rabid ravaging foxes attacks. -Sozo
Moved - please read the rules.
Hello:
First I am sorry about the posted placement error, but praise the Lord for the quick response. :)
As for the jpgs. Most of the pics aren't visible. Even the one in your post above. I have refreshed, and as for the speed of d/l, I am on cable so I don't think that's it. Perhaps it's a setting in IE7? I don't have this problem with any other site or forum; only here. Here's a quick link to the exploding planets tut. I can't see anything.
viewtopic.php?f=15&t=2792
Thanks, and God bless
Hmm, I'm not sure. I use Firefox and it works just fine for me, so maybe it has something to do with Internet Explorer.
Other than that, I don't know what could be causing the problem. :|
