Ability to Deactivate Pressure Sensitivity for Paintbrush
I have suggested this before, and I will suggest it again, but slightly modified.
Background:
I own a Wacom graphics tablet and I use Windows Vista, therefore pressure sensitivity is supported. This is a real pain in the in Paint.NET. Whenever I try to use the stylus, I get huge lines. This makes it impossible to draw anything. I show you an example below:
http://www.freewebs.com/cornipsus/paintbrush%20tool.gif
Suggestion Text:
I would like the option to disable pressure sensitivity, so I can just draw lines, instead of the example below. I assume that you coded the whole pressure thing, so I don't think this could be so hard.
I thank you in advance for taking the time to read this suggestion.
The God of Judgement is not pleased...
Can't you change this within the Wacom control panel?
