Patriotsfan83 Posted March 22, 2008 Share Posted March 22, 2008 I want to know how to have a colored glow around text and pics. Also, I wanted to know how to make a background transparent so it doesn't show up on signatures. If there is already a tutorial out there, I'm sorry, and please provide a link. Regards Quote Link to comment Share on other sites More sharing options...
Tendou Posted March 22, 2008 Share Posted March 22, 2008 To make backgrounds transparent use the magic wand, for tolerance, you'll have to try for yourself. Once you click magic wand, click on the background, adjust the tolerance. Quote Link to comment Share on other sites More sharing options...
Myrddin Posted March 22, 2008 Share Posted March 22, 2008 I want to know how to have a colored glow around text and pics.Duplicate the image/text, and on the bottom of the two identical layers apply either a drop shadow (a plugin in the Plugins Forum), or a Gaussian Blur (Effects > Blurs > Gaussian Blur) to which you can recolour using Hue/Contrast or Curves (both found in the Adjustments menu).Also, I wanted to know how to make a background transparent so it doesn't show up on signatures.You could try the technique given by Tendou as this is very quick and easy, if a little 'rough'; it does not suit everybody.As an alternative, but not necessarily a better alternative, would be to either use the tutorial 'Cutting Out Images the Easy Way', or an alpha mask, which, although long and tedious, can (depending on your outlining) give far better results than the previous two methods. (Alpha Mask: plugin | tutorial.) Try all three methods and see which you feel most comfortable with. If have you problems finding anything, there are two two search facilities available to you, the built-in Forum Search and the Paint.NET Custom Search Engine. Both can give varying results to say the least. Also, do not forget to save your final flattened work in the .png format as this supports the full range of transparency. Does any of this help you further? Quote How to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
BoltBait Posted March 22, 2008 Share Posted March 22, 2008 For colored glow around objects (including text) you could use the Outline Object plugin in my plugin pack: viewtopic.php?f=16&t=22819 Just select your primary color as the color of the glow you want before running the plugin. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
St.Jim Posted March 24, 2008 Share Posted March 24, 2008 Follow my tutorial that i made: viewtopic.php?f=15&t=23521&p=160484#p160484 good luck! Quote My DeviantArt Link to comment Share on other sites More sharing options...
