usmanhameed Posted March 20, 2008 Share Posted March 20, 2008 i m getting the follwoing error during compilation due to which i m unable to proceed. besides that i m using VisualStudio2005 Error 19 The command "@rem Embed manifest call "D:\src\Manifests\embedManifest.bat" "D:\src\bin\Debug\PaintDotNet.exe" "D:\src\Manifests\asInvoker.xml" call "D:\src\Manifests\embedManifest.bat" "D:\src\obj\Debug\PaintDotNet.exe" "D:\src\Manifests\asInvoker.xml" @rem Sign rem call "D:\src\signfile.bat" "D:\src\obj\Debug\PaintDotNet.exe" rem call "D:\src\signfile.bat" "D:\src\bin\Debug\PaintDotNet.exe" @rem copy Interop.WIA.dll over copy "D:\src\\Interop.WIA\Interop.WIA.dll" "D:\src\bin\Debug\" @rem Copy DDS over mkdir "D:\src\bin\Debug\\FileTypes" copy "D:\src\\DdsFileType\DdsFileType\bin\Debug\DdsFileType.dll" "D:\src\bin\Debug\\FileTypes" copy "D:\src\\DdsFileType\Squish\Squish_x86\Debug\Squish_x86.dll" "D:\src\bin\Debug\" copy "D:\src\\DdsFileType\Squish\Squish_x86_SSE2\Debug\Squish_x86_SSE2.dll" "D:\src\bin\Debug\" copy "D:\src\\DdsFileType\Squish\Squish_x64\Debug\Squish_x64.dll" "D:\src\bin\Debug\" @rem copy SystemLayer.Native.*.dll over rem copy "D:\src\\SystemLayer.Native\SystemLayer.Native.x64\Debug\PaintDotNet.SystemLayer.Native.x64.dll" "D:\src\bin\Debug\" rem copy "D:\src\\SystemLayer.Native\SystemLayer.Native.x86\Debug\PaintDotNet.SystemLayer.Native.x86.dll" "D:\src\bin\Debug\" @rem copy WiaProxy32.exe over copy "D:\src\\WiaProxy32\bin\Debug\WiaProxy32.exe" "D:\src\bin\Debug\" @rem copy English strings over copy "D:\src\\Strings\Debug\PaintDotNet.Strings.3.resources" "D:\src\bin\Debug\" @rem copy non-English strings (we won't copy the other file/image resource overrides) rem copy "D:\src\\Resources.mui\*.resources" "D:\src\bin\Debug\" :done rem call "D:\src\prejit.bat" "D:\src\bin\Debug\PaintDotNet.exe"" exited with code 1. paintdotnet Quote Link to comment Share on other sites More sharing options...
harold Posted March 23, 2008 Share Posted March 23, 2008 How can a remark throw an error..? Quote I would write plugins, if I knew what kind of plugins were needed.. Link to comment Share on other sites More sharing options...
mpeccorini Posted March 28, 2008 Share Posted March 28, 2008 I'm getting the same compilation issues. The remark is of course not throwing the error but the call to the embedManifest.bat. The batchfile uses an executable called mt.exe and I can't find it (yes, I searched my whole hard disk). Can this be because I'm using Visual Studio 2008 Standard Edition? Does anybody know a workaround? Thanks Mauricio Quote Link to comment Share on other sites More sharing options...
mpeccorini Posted March 28, 2008 Share Posted March 28, 2008 I looked for the mt.exe file and I realized I was missing some files from the Windows SDK (v6.0A in this case). I repaired my installation of Visual Studio and the file mt.exe appeared in the folder C:\Program Files\Microsoft SDKs\Windows\v6.0A\bin. After that I was still having the problem, but I don't know if thats because the file was not there when I first loaded the solution or something, so I changed the file src\Manifests\embedManifest.bat adding the full path of mt.exe. That made the trick. I hope this helps, Mauricio Quote Link to comment Share on other sites More sharing options...
