CodeLab v6.6 (for advanced users) Released August 9, 2022
8 hours ago, toe_head2001 said:
There are two reasons someone might want to disable it:
3. When it changes your own simple variable to some unknown (to me) Pdn method with a similar name.😉
- Thanks both for putting in the work.
Visual Studio has a visual hint to indicate when an item will/won't auto complete:
Solid Selection = Auto Complete
Outline Selection = No Auto Complete (in case of typos, auto complete can be forced with the Tab key)
I'm adding a similar hint to CodeLab.  I hope this will reduce "surprises" when an item auto completes (or doesn't).
Serveral months ago Visual Studio Code added this thing called Rainbow Braces.
The feature is available in the regular Visual Studio with extensions: Viasfora or Rainbow Braces.
Now that I've become accustom to these rainbow braces, I wanted them in CodeLab too.
So... the next version of CodeLab will have an option for Rainbow Braces!
  • Like 3
  • You're a Smart Cookie! 1
  • Hooray 1
Dang. I never knew I needed them until I saw this ^ screenshot. Yes please :)
So pretty 😍 It might even get me interested in writing code 😂
I like the multi-colored brackets as I think it will make reading codes easier as I sometime get lost in reading the sequencing.
Paint.NET Gallery | Remove Foreground Object Tutorial | Dispersion Effect Tutorial
”An artist should never be a prisoner of himself, prisoner of style, prisoner of reputation, prisoner of success.” ~ Henri Matisee
That could be very informative.
The colour coded parenthesis look very useful too... previously I would add a comment e.g.. "// end inner loop"... it's so easy to get it wrong, then the errors disappear and you can't see where you have gone wrong.
