13 minutes ago, toe_head2001 said:
Most people don't use tabs with any C style language.
A shame, really.
That's completely subjective. The same exact things can be said about tabs. I'm not even joking.
The standout issue with tabs is variable tab width among different environments.  For you a tab width might appears as 40px, but for other people it might be 80px.
This is very evident in web browsers. For some reason, a tab is about double the normal (if there is such a thing) width in a web browser.
A space is always the same width.
Yes, I know it's completely subjective. That's why I think it's silly to enforce this... (I'm not talking about you - I blame Microsoft!)
Personally, I think it's a great thing that tabs have variable width! To me, indents are logical separators, not visual ones. One indent equals one tab, and its visual width is just your personal preference.
Anyway...
52 minutes ago, toe_head2001 said:
it would be very easy to add an option to CodeLab for tabs.  However, all the templates within CodeLab are hard-coded with spaces. So basically, you would easily end up with a document mixed with tabs and spaces.
Well, it's not really a big deal, replacing manually is quite easy. Or actually, it would just be easier to simply to do a replace in the templates before adding them to the documents if the user has some "use tabs" option enabled.
  • 3 months later...
2 hours ago, Reptillian said:
... a find/replace function similar to the one implemented in KDE Kate.
So you want a pane to list the lines that contain matches?
EDIT: oh, I see, you want to toggle if a match gets replaced. Is that right?
Edited by toe_head2001
So, it really only for renaming identifiers.
Here I have renamed the Local Variable selection to mySelRect. When I hover my mouse cursor over the word, the Light-bulb menu appears.
As I said before, it does matching with a stricter criteria. (as opposed to basic text compare)
  • You're a Smart Cookie! 1
4 hours ago, Heptor said:
Need some help here. Whenever I put this into CodeLab, the entire program just shuts down. What am I doing wrong?
Please check for a crash log and post it here.  Go to the settings - top right of paint.net canvas ⚙ and see if there is a crash log.  If not, post the Diagnostics.
Failure paint.net in this case, does not create a crash log. @Heptor just inserted the script from github into the default script. Most likely, none of the overloads of the 'Render' method accepts the specified number of arguments. I think @BoltBait or @toe_head2001 will give a more qualified explanation.
CodeLab 6.1 Released
This is only for Paint.NET 4.2.16+!
Long awaited update today...
Changes:
 Use Roslyn syntax in generated code (BoltBait)
 Fix the disablement of the Transparency menu (toe_head2001)
 Disable intelligent assistance when document is readonly (toe_head2001)
 Fix issue with square brackets in controls' Display Name (toe_head2001)
 Add SubmenuNames.Color which is new in PdN 4.2.16 (BoltBait)
 Copy Text and RTF formats onto the clipboard (Handy when pasting syntax highlighted code into Word) (toe_head2001 and BoltBait)
 Fix compilation with PDN v4.2.16 (toe_head2001)
 Fix Clouds rendering for Paint.NET v4.2.16 (BoltBait)
 Fix URLs for Errors and Warnings (toe_head2001)
 Minor code refactoring and bug fixes (toe_head2001 and BoltBait)
Grab the CodeLab DLL here:
https://www.boltbait.com/pdn/CodeLab/
  • Like 5
  • Upvote 2
Click to play:
