BLUEnLIVE 0 Posted January 20, 2020 Report Share Posted January 20, 2020 11 hours ago, BoltBait said: If you create a pan slider: It creates it like this: PanSliderControl Amount4 = Pair.Create(0); // Slider 1 Description Because of the default. If you then... press Ctrl+I to go into the interface designer again and press Enter, it will update the script and it will work fine. EDIT: I have fixed this for the next release. In the mean time, just do this Oh, Thank you! After posting my last reply, I saw your answer. Thank you for your work and kind help. Quote Link to post Share on other sites
BoltBait 3,232 Posted January 31, 2020 Report Share Posted January 31, 2020 CodeLab 5.2 Released This is only for Paint.NET 4.2.9+! Small (but important) update today... Changes: ▪ Fix Pan Slider Default (BoltBait) ▪ Improved File New Template code (BoltBait) ▪ Updated default script for Paint.NET v4.2.9 (BoltBait) ▪ Various code cleanups (toe_head2001) Grab the CodeLab DLL here: https://www.boltbait.com/pdn/CodeLab/ 3 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
ReMake 996 Posted February 1, 2020 Report Share Posted February 1, 2020 CodeLab 5.2 in Russian You can find the new version of CodeLab in Russian here. Вы можете найти новую версию CodeLab на русском языке здесь. Quote Link to post Share on other sites
toe_head2001 1,787 Posted February 21, 2020 Report Share Posted February 21, 2020 Does anyone ever use the Ctrl+D hotkey to toggle the Debug Output? It would be nice to have the hotkey perform Duplicate Line(s); like most other editors. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
ReMake 996 Posted February 21, 2020 Report Share Posted February 21, 2020 I don't use hotkeys Ctrl+D. Reassign these keys for duplicate of lines is preferable. Quote Link to post Share on other sites
BoltBait 3,232 Posted February 21, 2020 Report Share Posted February 21, 2020 Fine with me. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
Ego Eram Reputo 2,750 Posted February 22, 2020 Report Share Posted February 22, 2020 Nor I. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
Reptillian 303 Posted February 22, 2020 Report Share Posted February 22, 2020 So, cntrl+e for debug? Quote Link to post Share on other sites
toe_head2001 1,787 Posted February 22, 2020 Report Share Posted February 22, 2020 2 minutes ago, Reptillian said: So, cntrl+e for debug? That currently toggles the Error List. I hope you aren't you saying you want Ctrl+E to toggle between the Error List and the Debug Output? That sounds obnoxious, to be honest. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
null54 745 Posted February 22, 2020 Report Share Posted February 22, 2020 15 hours ago, Reptillian said: So, cntrl+e for debug? I would suggest Ctrl+Alt+D. This would be similar to the Ctrl+Alt+O shortcut Visual Studio uses for the output window. The error list shortcut could be changed to Ctrl+Alt+E for consistency, which would free up Ctrl+E for some other feature. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to post Share on other sites
toe_head2001 1,787 Posted February 24, 2020 Report Share Posted February 24, 2020 On 2/22/2020 at 7:34 PM, null54 said: I would suggest Ctrl+Alt+D. This would be similar to the Ctrl+Alt+O shortcut Visual Studio uses for the output window. I'd rather it match Visual Studio. So, Ctrl+Alt+O would be the better choice in my opinion. 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
Erdos 0 Posted March 26, 2020 Report Share Posted March 26, 2020 Возможно ли сделать математические операции над каналами изображения, взяв информацию из каналов другого изображения? Quote Link to post Share on other sites
BoltBait 3,232 Posted March 26, 2020 Report Share Posted March 26, 2020 18 minutes ago, Erdos said: Is it possible to do mathematical operations on image channels by taking information from the channels of another image? Yes. But, only if that other image is in a file or on the clipboard. In a CodeLab script, you do not have access to other open images or even other layers of your current image. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
Erdos 0 Posted March 26, 2020 Report Share Posted March 26, 2020 16 minutes ago, BoltBait said: Yes. But, only if that other image is in a file or on the clipboard. In a CodeLab script, you do not have access to other open images or even other layers of your current image. Да, это другое изображение, его можно даже не открывать в Paint.NET Не подскажите, как реализовать такую задумку? В скриптах я новичок, умею проделать математические операции над текущим изображением. Quote Link to post Share on other sites
BoltBait 3,232 Posted March 26, 2020 Report Share Posted March 26, 2020 44 minutes ago, Erdos said: Да, это другое изображение, его можно даже не открывать в Paint.NET Не подскажите, как реализовать такую задумку? В скриптах я новичок, умею проделать математические операции над текущим изображением. Start here: This will generate the script you will need to read an image from the clipboard. In the inner loop of the Render function, the WRK surface will have your clipboard image and the SRC surface will have your original image that you are working on. The DST surface is where you need to put your final calculated pixels. 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
Erdos 0 Posted March 26, 2020 Report Share Posted March 26, 2020 14 minutes ago, BoltBait said: Start here: This will generate the script you will need to read an image from the clipboard. In the inner loop of the Render function, the WRK surface will have your clipboard image and the SRC surface will have your original image that you are working on. The DST surface is where you need to put your final calculated pixels. Thanks! I will sort this out. Quote Link to post Share on other sites
ReMake 996 Posted April 24, 2020 Report Share Posted April 24, 2020 I get this error when running CodeLab in paint.net 4.2.11 (α4. 211.7417. 40976). In paint.net 4.2.10 and the previous alpha build paint.net 4.2.11 this did not happen. Quote Link to post Share on other sites
toe_head2001 1,787 Posted April 24, 2020 Report Share Posted April 24, 2020 1 hour ago, ReMake said: I get this error when running CodeLab in paint.net 4.2.11 (α4. 211.7417. 40976). This has been fixed in CodeLab for the next release. 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
BoltBait 3,232 Posted April 25, 2020 Report Share Posted April 25, 2020 CodeLab 5.3 Released This is only for Paint.NET 4.2.10+! Small (but important) update today... Changes: ▪ Fix File New Code Generation for Paint.NET v4.2.11 (BoltBait) ▪ Added Layer Rotate/Zoom to File New Templates Effects (BoltBait) ▪ Changed: The hotkey for the Debug Output pane is now Ctrl+Alt+O. Duplicate Line(s) is now performed when Ctrl+D is pressed. (toe_head2001) ▪ Changed: Editor tooltips will now hide when clicking or typing. This mimics behavior of Visual Studio. (toe_head2001) ▪ Improved editor support for Shapes. Better error messages. Tooltips and F12 Lookup are now supported on Tags and Attributes. (toe_head2001) ▪ Various small bug fixes to the Auto Complete box. (toe_head2001) ▪ Fixed reference to System.Core assembly for Paint.NET v4.2.11 (toe_head2001) Grab the CodeLab DLL here: https://www.boltbait.com/pdn/CodeLab/ 1 3 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
Djisves 532 Posted April 25, 2020 Report Share Posted April 25, 2020 It may be important for you to know that AVG is warning me against installing v.5.3. This is the first time that AVG has warned me that CodeLab may be dangerous. No such warnings for any of the previous versions. Quote Link to post Share on other sites
null54 745 Posted April 25, 2020 Report Share Posted April 25, 2020 2 hours ago, Djisves said: It may be important for you to know that AVG is warning me against installing v.5.3. I use AVG and it did not find any problems with CodeLab v5.3. VirusTotal also reports the there are no issues. https://www.virustotal.com/gui/file/0466e38bcebab358b5c9345d7f998e0fc045b067588ce26124da5ccff7336c25/detection Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to post Share on other sites
Djisves 532 Posted April 25, 2020 Report Share Posted April 25, 2020 Well, it was submitted for analysis (or something similar) and I did reply that I trust it (or something similar). That may have changed AVG's rating. Of course I did not believe there was any problem and I did install it anyway. Quote Link to post Share on other sites
ReMake 996 Posted April 25, 2020 Report Share Posted April 25, 2020 CodeLab 5.3 in Russian You can find the new version of CodeLab in Russian here. Вы можете найти новую версию CodeLab на русском языке здесь. Quote Link to post Share on other sites
NSD 56 Posted April 25, 2020 Report Share Posted April 25, 2020 (edited) Thanks for this update! Edited April 25, 2020 by NSD Quote Link to post Share on other sites
toe_head2001 1,787 Posted April 28, 2020 Report Share Posted April 28, 2020 Suggested Names will perform a bit differently for Types that implement IEnumerable<T>. The suggestions will be based on T, and will be plural. This is how Visual Studio does it. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
