toe_head2001 1,787 Posted January 27, 2019 Report Share Posted January 27, 2019 That's pretty strange. CodeLab should only fallback to the Verdana font if none of the other fonts (Consolas, Courier New, ect.) are available. Given that Consolas, Courier New, and Verdana are all included with Windows 7, those fonts must have been uninstalled from your computer at some point. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
BoltBait 3,232 Posted March 19, 2019 Report Share Posted March 19, 2019 CodeLab 4.2 Released This is only for Paint.NET 4.1.6+! Big update today... Changes: ▪ New Icons! (toe_head2001) ▪ Improved the 'unsaved changes' dialog for when there's only one tab open, and also changed the wording in the dialog when there's multiple tabs open, to be less confusing (toe_head2001) ▪ The search box (in Find & Replace) now turns red when there are no matches (toe_head2001) ▪ When using Save As, the "//Name: " comment is now parsed to try to create a default filename. If it's unsuccessful, it will fall back to "MyScript.cs" (toe_head2001) ▪ Minor fixes to Format Document (toe_head2001) ▪ Files (with .cs extension) can now be dropped (drag and drop) into CodeLab to open them. (toe_head2001) ▪ Options to use force SingleRenderCall and Legacy ROI when Building DLL (toe_head2001 and BoltBait) ▪ Added three additional menu items to the Effects menu to start CodeLab with specific parameters (EffectsFlags, EffectRendingSchedule). (toe_head2001) ▪ Scripts with "//Submenu: Adjustments" will be put in the Adjustments menu instead of the Effects menu (BoltBait) ▪ If your effect has a sample image for The Plugin Browser, it will be shown on the Build to DLL form (BoltBait) ▪ Added a new high res icon for when CodeLab is running higher than 96dpi (BoltBait) ▪ Added new build options (Legacy ROI, Single Render Call) to File New template screen (BoltBait) ▪ Added the following script comments to control build options: (BoltBait)// Force Legacy ROI // Force Single Render Call ▪ CodeLab can now be installed to the Store version of Paint.NET. However, when running the Store version you can not create a Visual Studio project from your CodeLab script. Building a DLL still works fine. (toe_head2001 and BoltBait) ▪ Assortment of bugfixes, cleanups, refactorings (toe_head2001 and BoltBait) Grab the CodeLab DLL here: http://www.boltbait.com/pdn/CodeLab/ Screenshots: New icons: When developing a CodeLab script that utilizes special rendering commands, CodeLab now has the ability to run under those conditions while you are developing your script: There are some new options on the File New screen: Here are the new features of the Save as DLL screen: You can now install CodeLab when using the Microsoft Store version of Paint.NET. The only limitation is that you can't generate a Visual Studio solution of your CodeLab script. If you click the button, nothing bad happens, it just tells you of the limitation. New Options: Legacy ROI... Here is a good description of how the ROI's work: https://forums.getpaint.net/topic/113917-effectoptions/?do=findComment&comment=555790 Single Threaded vs. Single Render Call... SingleThreaded only uses 1 thread to make calls into Render. It'll still be called many, many times, just like if you didn't use the flag, but without any multithreading. Progress bar still works here. SingleRenderCall only calls Render once, and it's done with 1 array with all of the roi's. That this is effectively SingleThreaded is just a corollary. You won't see any progress bar updating here because the progress bar is updated as each Render call finishes, and there's no side-channel for reporting progress. 3 3 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
toe_head2001 1,787 Posted March 19, 2019 Report Share Posted March 19, 2019 Quote New Icons! (toe_head2001) I didn't get around to adding larger icons for HiDPI, but I plan to do so in the near future. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
xod 473 Posted March 20, 2019 Report Share Posted March 20, 2019 Thanks for your hard work. Is there any chance to Format Document and Find/Replace icons to be added to the toolbar? Quote Link to post Share on other sites
BoltBait 3,232 Posted March 20, 2019 Report Share Posted March 20, 2019 1 hour ago, xod said: Thanks for your hard work. You're welcome! 1 hour ago, xod said: Is there any chance to Format Document Easy. Do you really use it that often? 1 hour ago, xod said: and Find/Replace icons to be added to the toolbar? Hmmm... not as easy. We would need to highlight the icon if the Find window is open and close the window if clicked again... Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
toe_head2001 1,787 Posted March 20, 2019 Report Share Posted March 20, 2019 14 minutes ago, BoltBait said: We would need to highlight the icon if the Find window is open and close the window if clicked again... Would we though? Most programs don't do that with their find buttons. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
xod 473 Posted March 20, 2019 Report Share Posted March 20, 2019 1 hour ago, BoltBait said: Easy. Do you really use it that often? Yes, I use it very often. But I think I could get used to the CTRL + Q combination. Now, CodeLab became very confuse for me. What version I need to use? Quote Link to post Share on other sites
BoltBait 3,232 Posted March 20, 2019 Report Share Posted March 20, 2019 Normally, you would just start CodeLab using the top entry, "CodeLab...". However, On 3/18/2019 at 9:59 PM, BoltBait said: When developing a CodeLab script that utilizes special rendering commands, CodeLab now has the ability to run under those conditions while you are developing your script: Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
BoltBait 3,232 Posted March 20, 2019 Report Share Posted March 20, 2019 1 hour ago, toe_head2001 said: Would we though? Most programs don't do that with their find buttons. It's not absolutely necessary. Are we as good as everyone else... or are we BETTER? 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
xod 473 Posted March 20, 2019 Report Share Posted March 20, 2019 (edited) If I run older scripts in Single Render Call or Legacy ROI mode, CodeLab freezes and I'm forced to close Paint.Net from Task Manager. Edit: Sorry, there was something wrong with my script. CodeLab works perfectly. Edited March 24, 2019 by xod Quote Link to post Share on other sites
BoltBait 3,232 Posted March 20, 2019 Report Share Posted March 20, 2019 1 hour ago, xod said: If I run older scripts in Single Render Call or Legacy ROI mode, CodeLab freezes and I'm forced to close Paint.Net from Task Manager. You'll need to give us more information. I'm not seeing any lockups. I am able to run older scripts in all 4 of the CodeLab modes. EDIT: How old is "older"? I mean, you can't run scripts designed for CodeLab 1.0... but, more modern previous versions (CodeLab 2.0+) should be fine. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
ReMake 996 Posted March 21, 2019 Report Share Posted March 21, 2019 CodeLab 4.2 in Russian You can find the new version of CodeLab in Russian here. Вы можете найти новую версию CodeLab на русском языке здесь. Quote Link to post Share on other sites
toe_head2001 1,787 Posted March 25, 2019 Report Share Posted March 25, 2019 On 3/20/2019 at 8:40 PM, xod said: If I run older scripts in Single Render Call or Legacy ROI mode, CodeLab freezes and I'm forced to close Paint.Net from Task Manager. Edit: Sorry, there was something wrong with my script. If your script is causing CodeLab to freeze, that's an issue. Can you share the script with us, so we can investigate? Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
xod 473 Posted April 3, 2019 Report Share Posted April 3, 2019 (edited) On 3/25/2019 at 7:37 PM, toe_head2001 said: If your script is causing CodeLab to freeze, that's an issue. Can you share the script with us, so we can investigate? Spoiler // Name: Test // Author: // Submenu: // URL: // Title: #region UICode ListBoxControl Amount1 = 0; // Options|Move X, Y|Diagonals IntSliderControl Amount2 = 20; // [0,800] {Amount1} X IntSliderControl Amount3 = 20; // [0,800] {Amount1} Y IntSliderControl Amount4 = 20; // [0,800] {!Amount1} Step CheckboxControl Amount5 = false; // [0,1] {Amount1} Show coordinates #endregion void Render(Surface dst, Surface src, Rectangle rect) { Rectangle selection = this.EnvironmentParameters.GetSelection(src.Bounds).GetBoundsInt(); dst.CopySurface(src, rect.Location, rect); float selTop = selection.Top; float selBot = selection.Bottom; float selLeft = selection.Left; float selRight = selection.Right; int step = Amount4; float fontSize = selection.Right/100; using (RenderArgs ra = new RenderArgs(dst)) { Graphics gr = ra.Graphics; gr.Clip = new Region(rect); gr.SmoothingMode = SmoothingMode.AntiAlias; StringFormat format = new StringFormat(); using(Pen pen = new Pen(Color.Black,1)) using (Font txtFont = new Font("Tahoma", fontSize, FontStyle.Regular)) using (SolidBrush txtBrush = new SolidBrush(Color.Blue)) { switch(Amount1) { case 0: // Move Lines PointF left = new PointF(selLeft - 1f, selTop + Amount2); PointF rite = new PointF(selRight, selTop + Amount2); PointF top = new PointF(Amount3 + selLeft, selTop - 1f); PointF bot = new PointF(Amount3 + selLeft, selBot); gr.DrawLine(pen, top, bot); gr.DrawLine(pen, left, rite); if (Amount5) { txtBrush.Color = Color.Blue; format.Alignment = StringAlignment.Near; format.LineAlignment = StringAlignment.Far; gr.DrawString(Amount2.ToString(), txtFont, txtBrush, selLeft, selTop + Amount2, format); txtBrush.Color = Color.Red; format.Alignment = StringAlignment.Far; format.LineAlignment = StringAlignment.Center; gr.DrawString(Amount3.ToString(), txtFont, txtBrush, selLeft + Amount3, selTop + fontSize, format); } break; case 1: // Diagonals for (int i = 1; i < selRight; i+=step) // if step (Amount4) = 0 CodeLab freezes. Logic Amount4 must be > 0. [1,800] { PointF topleft = new PointF(selLeft, selTop - i + 1f); PointF botrite = new PointF(selRight + i - 1f, selBot); gr.DrawLine(pen, topleft, botrite); PointF topleft2 = new PointF(selLeft - i + 1f, selTop); PointF botrite2 = new PointF(selRight, selBot + i - 1f ); gr.DrawLine(pen, topleft2, botrite2); } break; } } } } Edited April 3, 2019 by xod Quote Link to post Share on other sites
BoltBait 3,232 Posted April 3, 2019 Report Share Posted April 3, 2019 44 minutes ago, xod said: if step (Amount4) = 0 CodeLab freezes. Well, of course it does--you've created an endless loop. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
toe_head2001 1,787 Posted April 9, 2019 Report Share Posted April 9, 2019 Here's a little sneak peek of what I'm working on. Disclaimer: It's half broken, and a work-in-progress. Visual Studio 2019 colors: Yellow for Methods Aquamarine for Structs Purple for certain Keywords Light Blue for Parameters and Local Variables 1 3 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
Ego Eram Reputo 2,750 Posted April 9, 2019 Report Share Posted April 9, 2019 Oooh! I like it! Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
xod 473 Posted June 5, 2019 Report Share Posted June 5, 2019 Is it possible in CodeLab to have more validation conditions? Quote Link to post Share on other sites
BoltBait 3,232 Posted June 5, 2019 Report Share Posted June 5, 2019 17 minutes ago, xod said: Is it possible in CodeLab to have more validation conditions? The way the readonlyproperty system is designed, no. Sorry, this is not possible. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
xod 473 Posted June 5, 2019 Report Share Posted June 5, 2019 OK, thanks for the answer. Quote Link to post Share on other sites
xod 473 Posted June 10, 2019 Report Share Posted June 10, 2019 Wrong alignment for braces when I try to format document because the statement is in line with 'if' keyword. Spoiler // Name: TextWarp // Submenu: // Author: xod // Title: TextWarp // Version: 1.0.0 // Desc: // Keywords: // URL: // Help: #region UICode MultiLineTextboxControl Amount1 = "Text Warp"; // [1,32767] FontFamily Amount2 = new FontFamily("Arial"); // Font IntSliderControl Amount3 = 50; // [3,800] Font size PanSliderControl Amount4 = Pair.Create(-1.000,-1.000); // PanSliderControl Amount5 = Pair.Create(1.000,-1.000); // PanSliderControl Amount6 = Pair.Create(-1.000,1.000); // PanSliderControl Amount7 = Pair.Create(1.000,1.000); // IntSliderControl Amount8 = 0; // [0,360] Rotate CheckboxControl Amount9 = false; // [0,1] Shape #endregion void Render(Surface dst, Surface src, Rectangle rect) { Rectangle sel = EnvironmentParameters.GetSelection(src.Bounds).GetBoundsInt(); Color PrimaryColor = EnvironmentParameters.PrimaryColor; float x1 = (float)Math.Round((Amount4.First + 1) * sel.Width / 2); float y1 = (float)Math.Round((Amount4.Second + 1) * sel.Height / 2); float x2 = (float)Math.Round((Amount5.First + 1) * sel.Width / 2); float y2 = (float)Math.Round((Amount5.Second + 1) * sel.Height / 2); float x3 = (float)Math.Round((Amount6.First + 1) * sel.Width / 2); float y3 = (float)Math.Round((Amount6.Second + 1) * sel.Height / 2); float x4 = (float)Math.Round((Amount7.First + 1) * sel.Width / 2); float y4 = (float)Math.Round((Amount7.Second + 1) * sel.Height / 2); string text = Amount1; int font_size = Amount3; FontStyle font_style = FontStyle.Regular; dst.CopySurface(src, rect.Location, rect); using (RenderArgs ra = new RenderArgs(dst)) using (Pen pen = new Pen(PrimaryColor, 1)) using (GraphicsPath path = new GraphicsPath()) using (SolidBrush brush = new SolidBrush(PrimaryColor)) using (FontFamily font_family = new FontFamily(Amount2.Name)) using (Font font = new Font(font_family, font_size, font_style)) using (StringFormat string_format = new StringFormat()) { string_format.Alignment = StringAlignment.Near; string_format.LineAlignment = StringAlignment.Near; Graphics g = ra.Graphics; g.Clip = new Region(rect); g.SmoothingMode = SmoothingMode.AntiAlias; g.TextRenderingHint = TextRenderingHint.AntiAliasGridFit; // Create a rectangle. RectangleF srcRect = new RectangleF(0, 0, sel.Width, sel.Height); PointF p1 = new PointF(x1, y1); PointF p2 = new PointF(x2, y2); PointF p3 = new PointF(x3, y3); PointF p4 = new PointF(x4, y4); if(Amount9) path.AddRectangle(srcRect); path.AddString(text, font_family, (int)font_style, g.DpiY * font_size / 72, new PointF(0, 0), string_format); // Create a destination for the warped rectangle. PointF[] destPoints = {p1, p2, p3, p4}; // Create a translation matrix. Matrix matrix = new Matrix(); matrix.Translate(0, 0); if (Amount8 > 0) { // Move TopLeft corner to center of the canvas then rotate. matrix.Translate(sel.Width / 2, sel.Height / 2); matrix.Rotate(Amount8); } // Warp the source path. path.Warp(destPoints, srcRect, matrix, WarpMode.Perspective, 0.5f); // Draw the warped path to the screen. g.DrawPath(pen, path); if(!Amount9) g.FillPath(brush, path); }//Wrong alignment for braces when I try to format document //because the statement is in line with 'if' keyword } Quote Link to post Share on other sites
toe_head2001 1,787 Posted June 10, 2019 Report Share Posted June 10, 2019 1 hour ago, xod said: Wrong alignment for braces when I try to format document because the statement is in line with 'if' keyword. I think this might already be fixed for the next version. If not, I'll take a look at fixing it in the coming days. 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
BoltBait 3,232 Posted June 10, 2019 Report Share Posted June 10, 2019 1 hour ago, toe_head2001 said: I think this might already be fixed for the next version. If not, I'll take a look at fixing it in the coming days. While there are some fixes for both quick format and for typing, this is not fixed. You can even see it with the default script: The line after: if (IsCancelRequested) return; becomes indented improperly after pressing Ctrl+Q for Quick reformat. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
toe_head2001 1,787 Posted June 11, 2019 Report Share Posted June 11, 2019 14 hours ago, xod said: Wrong alignment for braces when I try to format document because the statement is in line with 'if' keyword. Ok, this is now fixed for the next version. 11 hours ago, BoltBait said: You can even see it with the default script: Well, that embarrassing. Like, did I even do basic testing?! For testing of Format Document, I have a special file filled with weird syntax. I've added a single-line if statement to that test file. I'm pretty sure this was a regression that happened within the last 6 months, because I did test the default script in the past. Anyways, it's in the test file now, so no more regressions in the future. 1 2 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
xod 473 Posted June 11, 2019 Report Share Posted June 11, 2019 Another issue. Try to run this code: Spoiler // Name: test // Submenu: // Author: // Title: test // Version: // Desc: // Keywords: // URL: // Help: #region UICode PanSliderControl Amount1 = Pair.Create(1.000,1.000); // {Amount2} CheckboxControl Amount2 = false; // [0,1] Enable #endregion void Render(Surface dst, Surface src, Rectangle rect) { } PDN crashes. It only works if parameters for Pair.Create is 0, 0 values: PairCreate(0.000, 0.000): Quote Link to post Share on other sites
