CodeLab v6.0 (for advanced users) Released June 25, 2020
Now that looks cool! Nice job t_h. CodeLab is becoming more and more sophisticated. Like its all grown up, *sniff* our little editor is a big boy now :mrgreen:
Link to post
Sweet! I've been missing auto indent now that I'm using VS a great deal more.
Link to post
CodeLab 3.0 Released
This is only for Paint.NET 4.0.20+!
HUGE update today...
Editor Changes:
▪ PDN Dark Theme compatibility (toe_head2001)
▪ New 'Find & Replace' panel with expanded functionality (toe_head2001)
▪ Edit -> Format Document. Automatic line indentation, and whitespace trimming from line ends (toe_head2001)
▪ F12 to 'Go To Definition'. Objects from the .Net Framework open docs.microsoft.com; objects from UserScript go to location in document (toe_head2001)
▪ Proper "Intelligent Assistance" for User Defined type members (fields, methods, ect. in your script), and type members defined in the Effect class (EnvironmentParameters, IsCancelRequested, ect.) (toe_head2001)
▪ Autocomplete box can now be filtered object type (Class, Property, Keyword, ect.) (toe_head2001)
▪ Bug fix: Red underlines for errors are now correctly located (toe_head2001)
Code Generation Changes:
▪ Int and Double sliders can now have decorations (BoltBait)
▪ Users can have controls disabled based on the status of other controls (enable/disable checkbox, etc.) (BoltBait)
▪ OnSetRenderInfo can be optionally utilized in the UserScript via the PreRender method. (toe_head2001)
▪ All File > New templates rewritten to utilize the new PreRender() function (BoltBait)
▪ Bug fix: Radio buttons and Drop-down lists now properly set default values (toe_head2001)
Grab the CodeLab DLL here:
Big shout-out to @MJW for helping design and test all the new features!
  • Like 3
  • Upvote 2
Click to play:
Link to post
  • BoltBait changed the title to CodeLab v3.0 (for advanced users) Released January 10, 2018
^^^ This is black magic! Pure witchcraft and wizardry!  :MagicWandTool:
Job well done! Those guys are awesome!   *tuts his own horn, and breaks his arm off patting himself on the back*  :lol:
Do we even need Visual Studio anymore? :P
Nearly 12 years ago, it was written:
Quote
Please note that this ... is not meant to provide a robust development environment.
I think it's safe to say that we now have the most robust development environment of any image manipulation program. :trophy:
Here are the keyboard commands to invoke filtering within the AutoComplete box:
Alt+L    Local Variables and Parameters
Alt+O    Constants
Alt+P    Properties
Alt+F    Fields
Alt+M    Methods
Alt+C    Classes
Alt+S    Structs
Alt+E    Enums
Alt+K    Keywords
Enjoy the new features and bugfixes.
  • Like 2
  • Upvote 2
Link to post
Thank you very much for this wonderful tool!
Do you think it's possible to add a Classic Color control (existing in Windows) other than the pdn Color Wheel?
It would take up much less space in the UI.
Link to post
CodeLab only supports IndirectUI controls built-in to paint.net itself.
Click to play:
Link to post
@BoltBait, @toe_head2001 & @MJW - you guys rock! Thank you for these wonderful tools.
Link to post
Question from a total noob...
Is there a way to quickly preview the dialog without having to publish, move the effect to appropriate location, and run PDN to see if it works?  Or is this more for Visual Studio where the ability to use XML editor to customize the location of each interactive feature?
Thanks.
Link to post
4 hours ago, xod said:
Some comments on formatting:
- if the comment ends in a bracket, below statement is wrongly indented
- also for more 'using' statements
Thanks for the report. I'll get these fixed. I suspect there more small issues with it, yet to be discovered.
Once we make "bug free", I'd like to automatically execute the 'Format Document' feature.  For example, when you paste in code, 'Format Document' would just automatically run on that pasted code.
No there is not. Previewing the dialog from CodeLab would technically be possible, but that's very low on my list of priorities.
When you derive from PropertyBasedEffect, you can't customize the dialog extensively. You literally declare a short list of properties, and paint.net generates a dialog at runtime based on those properties (this is colloquially  know as "IndirectUI").
If you need a fully custom dialog, you have to tediously build it from scratch with WinForms controls.
Link to post
Can such object operations be defined, which let to change all of the channels together such these codes can to changed together as Instead of this
CurrentPixel.R = PrimaryColor.R + 25;
CurrentPixel.G = PrimaryColor.G + 25;
CurrentPixel.B = PrimaryColor.B + 25;
CurrentPixel.A = PrimaryColor.A + 25;
we can simply use.
CurrentPixel = PrimaryColor + 25;
Link to post
You could create a function for that.
    ColorBgra PrimaryColorColor = EnvironmentParameters.PrimaryColor;
    ColorBgra CurrentPixel;
            CurrentPixel = IncrementAllChannels(PrimaryColorColor, 25);
            dst[x,y] = CurrentPixel;
ColorBgra IncrementAllChannels(ColorBgra color, int amount)
    return ColorBgra.FromBgraClamped(color.B + amount, color.G + amount, color.B + amount, color.A + amount);
Link to post
  • BoltBait changed the title to CodeLab v6.0 (for advanced users) Released June 25, 2020
