CodeLab v6.0 (for advanced users) Released June 25, 2020
Another thing I don't understand (yes, they are legion :)), why should this line...,
temp = new Surface( src.Width, src.Height );
Generate this Codelab error?
Error at line 68: The type 'System.Windows.Size' is defined in an assembly that is not referenced. You must add a reference to assembly 'Windowsbase, version 3.0.0.0, culture =neutral, PublicKeyToken=31bf38......... (CS0012)
The line above used to work, but doesn't now :/.
What is the correct method of creating a temporary surface in Codelab?
So long as it works, that'll do nicely. Thanks APShredder!
  • 6 months later...
Hi,
I've encounted a crash error while I was entering some code...
As I mentioned earlier I've a trouble with the autocompletion activated by semicolumn';' instead point '.'
This time Codelab makes a pdncrash during the typing. I could repro it.
First time I thought the open parenthese was causing the bug. But for the repro I typed the open parenthese correctly...
Perhaps with the full crash log it could help to solve this.
Hidden Content: pdncrash.log
Please e-mail this file to crashlog@getpaint.net so we can diagnose and fix the problem.
Application version: Paint.NET v3.5.8 (Final Release build 3.58.4081.24580)
Time of crash: 29/05/2011 17:46:24
Application uptime: 00:27:41.3780254
Install directory: C:\Program Files\Paint.NET
OS Version: 6.1.7601.65536 Service Pack 1 Workstation x64
.NET version: CLR 2.0.50727.5444 x64, FX 2.0 (rtm sp1 sp2) 3.0 (rtm sp1 sp2) 3.5 (rtm sp1 sp1_CP) 4.0 (rtm rtmEx)
Processor: 4x "Intel(R) Core(TM)2 Quad  CPU   Q9000  @ 2.00GHz" @ ~1995MHz (DEP, SSE, SSE2, SSE3, SSSE3, SSE4_1), fps=0x1
Physical memory: 4095 MB
UI DPI: 96,00 dpi (1,00x scale)
UI Theme: Aero/Aero + DWM (Aero.msstyles)
Updates: true, 27/05/2011
Locale: pdnr.c: en-US, hklm: en-US, hkcu: en-US, cc: fr-FR, cuic: en-US
Managed assemblies:
   mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.NET\Framework64\v2.0.50727\mscorlib.dll
   PaintDotNet, Version=3.58.4081.24586, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.exe
   PaintDotNet.Base, Version=3.58.4081.24574, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Base.dll
   System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll
   WindowsBase, Version=3.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\Windows\assembly\GAC_MSIL\WindowsBase\3.0.0.0__31bf3856ad364e35\WindowsBase.dll
   System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System.Windows.Forms\2.0.0.0__b77a5c561934e089\System.Windows.Forms.dll
   System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll
   System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System.Core\3.5.0.0__b77a5c561934e089\System.Core.dll
   PaintDotNet.Core, Version=3.58.4081.24581, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Core.dll
   PaintDotNet.SystemLayer, Version=3.58.4081.24580, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.dll
   PaintDotNet.Resources, Version=3.58.4081.24580, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Resources.dll
   PaintDotNet.Data, Version=3.58.4081.24584, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Data.dll
   PaintDotNet.Effects, Version=3.58.4081.24585, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Effects.dll
   PaintDotNet.SystemLayer.Native.x64, Version=3.58.4081.24579, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x64.dll
   msvcm90, Version=9.0.30729.5570, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.5570_none_08e72cf3a83ac624\msvcm90.dll
   "AA's_Assistant", Version=1.0.3697.21415, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AA's_Assistant.dll
   advcolorrep, Version=1.3.3303.27314, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\advcolorrep.dll
   AlignPlugin, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlignPluginold.dll
   Alpha-Displacement Mask, Version=1.4.1.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha-Displacement Mask.dll
   AlphaMask, Version=2.0.3574.41943, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaMask.dll
   Animal, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Animal.dll
   Apply Texture, Version=1.0.0.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Apply Texture.dll
   AutoChrome, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AutoChrome.dll
   AutoChromeNoise, Version=1.0.3847.37353, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AutoChromeNoise.dll
   AverageEdgeBlur, Version=1.0.3991.32409, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AverageEdgeBlur.dll
   Bars, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bars.dll
   BlackandAlpha+, Version=1.1.3809.21705, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlackandAlpha+.dll
   BlendModesPlus, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlendModesPlus.dll
   "Borders N' Shapes", Version=1.8.3627.29848, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Borders N' Shapes.dll
   Boutons, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Boutons.dll
   Burninate, Version=1.1.3182.28956, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Burninate.dll
   ChartWhiteBalance, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ChartWhiteBalance.dll
   CircleText, Version=1.3.4159.37815, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CircleText.dll
   CodeLab, Version=1.6.3863.41871, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CodeLab.dll
   Color Match, Version=1.1.3627.29847, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Color Match.dll
   coloraberation, Version=1.0.3859.18981, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\coloraberation.dll
   ColorBalance, Version=1.1.3182.30196, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorBalance.dll
   ColorModulo, Version=1.1.3643.38108, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorModulo.dll
   ColorSort, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorSort.dll
   ColorZoomBlur, Version=1.1.3873.36417, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorZoomBlur.dll
   ComputeShaderEffects, Version=1.0.0.6, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ComputeShaderEffects.dll
   CondHSAdj, Version=1.7.2618.31817, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CondHSAdj.dll
   CurtisBlack.Common, Version=1.0.3736.39220, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Common.dll
   CurtisBlack.Effects, Version=11.1.3736.39220, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Effects.dll
   CurtisBlack.Resources, Version=1.0.3490.22409, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Resources.dll
   Curves+, Version=3.0.3627.29849, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Curves+.dll
   CustomBrushesMini, Version=2.1.4039.25699, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CustomBrushesMini.dll
   Displacement, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Displacement.dll
   DistortingMirror, Version=1.0.3851.29620, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DistortingMirror.dll
   DPL KAL, Version=1.0.3937.11496, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DPL KAL.dll
   dpyColorBalance, Version=1.0.3518.25420, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\dpyColorBalance.dll
   DragFrom, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DragFrom.dll
   Droste, Version=0.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\droste.dll
   EdHarvey.DrawingHelpers, Version=3.22.2940.32375, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.DrawingHelpers.dll
   EdHarvey.Effects, Version=3.5.3786.8637, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.dll
   EditableText, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EditableText.dll
   Enlarge, Version=1.0.4162.27486, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Enlarge.dll
   ErodeDilate, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ErodeDilate_v0.2.dll
   ExtendBorder, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ExtendBorder.dll
   Feather, Version=3.0.3723.26349, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Feather.dll
   Film, Version=2.0.3612.21577, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Film.dll
   Filters, Version=1.0.3853.27872, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Filters.dll
   FindEdges, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FindEdges.dll
   Frames, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Frame.dll
   GenTree, Version=0.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GenTree.dll
   Gradient Bars, Version=3.0.3627.29850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Bars.dll
   Gradient Blocks, Version=1.0.3742.38604, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Blocks.dll
   GradientBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Blur.dll
   Gradient Mapping, Version=3.0.3627.29847, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Mapping.dll
   GrainFiller, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GrainFiller.dll
   Gravity, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gravity.dll
   GridMaker, Version=3.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GridMaker.dll
   HexaGrid, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HexaGrid.dll
   ImageShackUpload, Version=2.6.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ImageShackUpload.dll
   IniFile, Version=2.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\IniFile.dll
   Jitter, Version=3.0.3612.21576, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Jitter.dll
   JumbleMax, Version=1.0.4133.31165, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\JumbleMax.dll
   KaleidoGen, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\KaleidoGen.dll
   Kaleidoscope, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Kaleidoscope.dll
   Landscape, Version=1.1.3593.25344, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Landscape.dll
   LensFlare, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LensFlare.dll
   Lightning, Version=1.1.3896.32593, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Lightning.dll
   LightRays, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LightRays.dll
   Liquify, Version=1.2.4112.39851, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Liquify.dll
   Magnifier, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Magnifier.dll
   Majority, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Majority.dll
   maskUI, Version=1.0.3851.36525, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\maskUI.dll
   MathNet.Iridium, Version=2007.3.8.35795, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MathNet.Iridium.dll
   Matrice, Version=1.0.3810.11744, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Matrice.dll
   Melting, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Melting.dll
   Metallize, Version=1.1.3504.33530, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Metallize.dll
   MirrorRotateMenu, Version=2.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MirrorRotateMenu.dll
   Moire, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Moire.dll
   MosaicManiac, Version=1.0.906.8, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MosaicManiac.dll
   MotionSharpen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MotionSharpen.dll
   MultiThreshold, Version=1.0.3730.36634, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MultiThreshold.dll
   Nebulous, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Nebulous.dll
   NewtonFractal, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NewtonFractal.dll
   NonRepeatableCollections, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NonRepeatableCollections.dll
   Oblique, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Oblique.dll
   Olden, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Olden.dll
   Outline Object, Version=2.6.3612.21574, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Outline Object.dll
   OutlineObject, Version=1.1.3160.31739, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Outline.dll
   Overliner, Version=1.2.3888.29226, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Overliner.dll
   PageCurl, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PageCurl.dll
   PaletteFromImage, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PaletteFromImage.dll
   Panelling, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Panelling.dll
   NewPastel, Version=1.2.3182.29587, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Pastel.dll
   PDNPalette, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PDNPalette.dll
   PerlinTexture, Version=1.1.3857.30918, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PerlinTexture.dll
   Perspective, Version=2.0.3716.33788, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Perspective.dll
   PhotoAdjustments, Version=1.1.3670.37697, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PhotoAdjustments.dll
   PhotoFloodFillPlugIn, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PhotoFloodFillPlugIn.dll
   Pixelate+, Version=1.2.3742.38634, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Pixelate+.dll
   PixelVal-Alpha, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PixelVal-Alpha.dll
   Polar, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polar.dll
   Polygones, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polygones.dll
   PowerStretch20Beta, Version=1.9.3045.14671, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PowerStretch.dll
   PrinterPlus, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PrinterPlus.dll
   pyrochild.effects.common, Version=2.0.3106.38959, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\pyrochild.effects.common.dll
   pyrochild.effects.REQUIRED, Version=3.6.3742.39840, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\pyrochild.effects.REQUIRED.dll
   RadialBlurDeluxe, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RadialBlurDeluxe_v0.1.dll
   Radialcolors, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Radialcolors.dll
   rainbow loom, Version=3.0.3530.27322, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\rainbow loom.dll
   RainbowTwist, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RainbowTwist.dll
   Random Effect, Version=1.3.3627.29846, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Effect.dll
   RandLines, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random lines.dll
   RandMaze1, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Maze1.dll
   RandMaze2, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Maze2.dll
   Random Shape Fill, Version=1.5.3621.26292, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Shape Fill.dll
   RefocusingSDe, Version=1.0.3760.21016, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RefocusingSDe.dll
   ReverseColors, Version=1.0.4121.15722, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ReverseColors.dll
   Rosaces, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Rosaces.dll
   RotateText, Version=1.0.3586.32866, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RotateText.dll
   RotateTextSUI, Version=1.0.3703.25609, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RotateTextSUI.dll
   SBCommon, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SBCommon.dll
   ScriptLab, Version=2.6.3627.29850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ScriptLab.dll
   SeamlessTextureMaker, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SeamlessTextureMaker.dll
   SelectionTools, Version=2.0.3746.20418, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SelectionTools.dll
   ShadowEffect, Version=1.1.0.43197, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ShadowEffect.dll
   Shape3D, Version=1.2.6.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Shape3D.dll
   SinWaves, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SinWaves.dll
   SlimDX, Version=2.0.10.43, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SlimDX.D3D11.x64.dll
   Smudge, Version=3.5.4162.28661, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Smudge.dll
   Sparkles, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sparkles.dll
   SpeechBubble, Version=2.0.3747.41051, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpeechBubble.dll
   Spiral, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Spiral.dll
   SpiralText, Version=1.3.4159.37832, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiralText.dll
   SpiroGraph, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiroGraph.dll
   SpiroShapes, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiroShapes.dll
   Splashes, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Splashes.dll
   Splatter, Version=1.6.3627.29848, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Splatter.dll
   StarGlow, Version=1.0.3839.21249, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\StarGlow.dll
   Stars, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stars.dll
   Stitch, Version=1.0.3627.29848, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stitch.dll
   ThatOtherApp, Version=2.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ThatOtherApp.dll
   ThreadsMarker, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ThreadsMarker.dll
   ThreeCircles, Version=1.0.3852.28460, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ThreeCircles.dll
   Tiles, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tiles.dll
   Trail, Version=1.0.3723.27562, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Trail.dll
   trail3d, Version=1.0.3902.32071, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\trail3d.dll
   Transparency, Version=1.1.3182.29244, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Transparency.dll
   TreeGen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TreeGen.dll
   TubeOblique, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TubeOblique.dll
   Twist, Version=1.0.3742.39641, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Twist.dll
   TwistZ, Version=1.1.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TwistZ.dll
   Untitled, Version=1.0.4159.24106, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Untitled.dll
   Vandermotten.PaintDotNetEffects.Blurs, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll
   Vandermotten.PaintDotNetEffects.ColorAccent, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll
   Vandermotten.PaintDotNetEffects, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.dll
   Vandermotten.PaintDotNetEffects.DropShadow, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll
   Vandermotten.PaintDotNetEffects.Duotones, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll
   Vandermotten.PaintDotNetEffects.FadeEdge, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll
   Vandermotten.PaintDotNetEffects.Gradient, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll
   Vandermotten.PaintDotNetEffects.Monochromes, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll
   Vandermotten.PaintDotNetEffects.ObjectAlign, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll
   Vibrato, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vibrato.dll
   Volutes, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Volutes.dll
   WaterReflection, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WaterReflection.dll
   Waves, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Waves.dll
   WaveText, Version=1.1.4159.37845, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WaveText.dll
   WaveTextSUI, Version=1.1.4159.37868, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WaveTextSUI.dll
   WetFloor, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WetFloor.dll
   WhichSymbolPlus, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WhichSymbolPlus.dll
   XYCoords, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\XYCoords.dll
   Microsoft.VisualBasic, Version=8.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\Microsoft.VisualBasic\8.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.dll
   System.Design, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\System.Design\2.0.0.0__b03f5f7f11d50a3a\System.Design.dll
   System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System.Xml.dll
   mscorlib.resources, Version=2.0.0.0, Culture=fr, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.NET\Framework64\v2.0.50727\mscorlib.dll
   ICSharpCode.SharpZipLib, Version=0.86.0.518, Culture=neutral, PublicKeyToken=1b03e6acf1164f73 @ C:\Program Files\Paint.NET\ICSharpCode.SharpZipLib.dll
   Accessibility, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\Accessibility\2.0.0.0__b03f5f7f11d50a3a\Accessibility.dll
   AnimGIF, Version=2.3.4040.877, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\AnimGIF.dll
   AsciiArtFileType, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\AsciiArtFileType.dll
   AviFile, Version=1.0.2920.35272, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\AviFile.dll
   AVIImport, Version=2.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\AVIImport.dll
   CodeFileType, Version=0.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\CodeFileType.dll
   DPXFileType, Version=1.0.0.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\DPXFileType.dll
   HexaTxt, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\HexaTxt.dll
   IcoCur, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\IcoCur.dll
   OptiPngFileType, Version=8.11.30.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\OptiPngFileType.dll
   PhotoShop, Version=1.0.4.33208, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\PhotoShop.dll
   System.Configuration, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\System.Configuration\2.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll
   System.Security, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\assembly\GAC_MSIL\System.Security\2.0.0.0__b03f5f7f11d50a3a\System.Security.dll
   wf-6rqgz, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @
Native modules:
   C:\Program Files\Paint.NET\PaintDotNet.exe, version='3.58.4081.24586'
   C:\Windows\SYSTEM32\ntdll.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\SYSTEM32\MSCOREE.DLL, version='4.0.40305.0 (Main.040305-0000)'
   C:\Windows\system32\KERNEL32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\KERNELBASE.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\ADVAPI32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\msvcrt.dll, version='7.0.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\SYSTEM32\sechost.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\RPCRT4.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll, version='4.0.30319.1 (RTMRel.030319-0100)'
   C:\Windows\system32\SHLWAPI.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\GDI32.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\system32\USER32.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\system32\LPK.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\USP10.dll, version='1.0626.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\system32\IMM32.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\MSCTF.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\Microsoft.NET\Framework64\v2.0.50727\mscorwks.dll, version='2.0.50727.5444 (Win7SP1GDR.050727-5400)'
   C:\Windows\WinSxS\amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4940_none_88df89932faf0bf6\MSVCR80.dll, version='8.00.50727.4940'
   C:\Windows\system32\shell32.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\system32\ole32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\profapi.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\mscorlib\345f462e6c356def729b91b3dd357025\mscorlib.ni.dll, version='2.0.50727.5444 (Win7SP1GDR.050727-5400)'
   C:\Windows\system32\CRYPTBASE.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\uxtheme.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\System\10c175a0e1e17d02e98977648d730cca\System.ni.dll, version='2.0.50727.5420 (Win7SP1.050727-5400)'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Core\c12b9ea3f53f5ff91fa04ce55c5255cc\System.Core.ni.dll, version='3.5.30729.5420 built by: Win7SP1'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\WindowsBase\21effc369751627310a7afbe50e25311\WindowsBase.ni.dll, version='3.0.6920.5011 built by: Win7SP1'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Drawing\940612923c264f3be3def97104fca663\System.Drawing.ni.dll, version='2.0.50727.5420 (Win7SP1.050727-5400)'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Windows.Forms\77c0639a8cd91b7643ded889e3194246\System.Windows.Forms.ni.dll, version='2.0.50727.5420 (Win7SP1.050727-5400)'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Base\1b250fa07b212422445d0f0f85106d02\PaintDotNet.Base.ni.dll, version='3.58.4081.24574'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.SystemL#\71f84b9a592e4448ea91f386601cfd49\PaintDotNet.SystemLayer.ni.dll, version='3.58.4081.24580'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Resourc#\bfbefd697615d59e97ebeddd35309673\PaintDotNet.Resources.ni.dll, version='3.58.4081.24580'
   C:\Windows\system32\CRYPTSP.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\rsaenh.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Core\fe70b1044cf75c13fdbf835b7cd495b5\PaintDotNet.Core.ni.dll, version='3.58.4081.24581'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Data\e9e7b7097070a67a6f1068ecbb44e3ee\PaintDotNet.Data.ni.dll, version='3.58.4081.24584'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet\a5f1af4499b41eabf3a286dbc7125300\PaintDotNet.ni.exe, version='3.58.4081.24586'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.SystemL#\b644fe8409375637fa586f066f797d6b\PaintDotNet.SystemLayer.Native.x64.ni.dll, version='3.58.0.0'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\Interop.WIA\e60ffe2dbab2c45e9458891f746a36a4\Interop.WIA.ni.dll, version='1.0.0.0'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\PaintDotNet.Effects\5b07807d20598493541c1f8bada5647e\PaintDotNet.Effects.ni.dll, version='3.58.4081.24585'
   C:\Program Files\Paint.NET\Native.x64\PaintDotNet.Native.x64.dll, version='3.58.0.0'
   C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.5570_none_08e72cf3a83ac624\MSVCR90.dll, version='9.00.30729.5570'
   C:\Windows\WinSxS\amd64_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.5570_none_390e4a460a1e25cc\VCOMP90.DLL, version='9.00.30729.5570 built by: QFE'
   C:\Windows\system32\dwmapi.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.17514_none_2b24536c71ed437a\gdiplus.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\Microsoft.NET\Framework64\v2.0.50727\mscorjit.dll, version='2.0.50727.5444 (Win7SP1GDR.050727-5400)'
   C:\Windows\system32\WindowsCodecs.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_fa396087175ac9ac\comctl32.dll, version='6.10 (win7_rtm.090713-1255)'
   C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x64.dll, version='3.58.0.0'
   C:\Windows\system32\OLEAUT32.dll, version='6.1.7601.17514'
   C:\Windows\WinSxS\amd64_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.5570_none_0a20e83fa767bc68\ATL90.DLL, version='9.00.30729.5570'
   C:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.5570_none_08e72cf3a83ac624\msvcm90.dll, version='9.00.30729.5570'
   C:\Windows\system32\d2d1.dll, version='6.1.7601.17563 (win7sp1_gdr.110218-1555)'
   C:\Windows\system32\dwrite.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\RpcRtRemote.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\system32\wtsapi32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\WINSTA.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\system32\version.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\SetupApi.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\CFGMGR32.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\system32\DEVOBJ.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\WINTRUST.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\system32\CRYPT32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\MSASN1.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Program Files\Elantech\ETDApix.dll, version='7, 0, 6, 0'
   C:\Windows\system32\WINSPOOL.DRV, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Program Files\Paint.NET\Effects\AA's_Assistant.dll, version='1.0.3697.21415'
   C:\Program Files\Paint.NET\Effects\advcolorrep.dll, version='1.3.3303.27314'
   C:\Program Files\Paint.NET\Effects\AlignPluginold.dll, version='1.5.0.0'
   C:\Program Files\Paint.NET\Effects\Alpha-Displacement Mask.dll, version='1.4.1.1'
   C:\Program Files\Paint.NET\Effects\AlphaMask.dll, version='2.0.3574.41943'
   C:\Program Files\Paint.NET\Effects\Animal.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\Effects\Apply Texture.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\Effects\AutoChrome.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\AutoChromeNoise.dll, version='1.0.3847.37353'
   C:\Program Files\Paint.NET\Effects\AverageEdgeBlur.dll, version='1.0.3991.32409'
   C:\Program Files\Paint.NET\Effects\Bars.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\BlackandAlpha+.dll, version='1.1.3809.21705'
   C:\Program Files\Paint.NET\Effects\BlendModesPlus.dll, version='2.1.0.0'
   C:\Program Files\Paint.NET\Effects\Borders N' Shapes.dll, version='1.8.3627.29848'
   C:\Program Files\Paint.NET\Effects\Boutons.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\Burninate.dll, version='1.1.3182.28956'
   C:\Program Files\Paint.NET\Effects\ChartWhiteBalance.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\Effects\CircleText.dll, version='1.3.4159.37815'
   C:\Program Files\Paint.NET\Effects\CodeLab.dll, version='1.6.3863.41871'
   C:\Program Files\Paint.NET\Effects\Color Match.dll, version='1.1.3627.29847'
   C:\Program Files\Paint.NET\Effects\coloraberation.dll, version='1.0.3859.18981'
   C:\Program Files\Paint.NET\Effects\ColorBalance.dll, version='1.1.3182.30196'
   C:\Program Files\Paint.NET\Effects\ColorModulo.dll, version='1.1.3643.38108'
   C:\Program Files\Paint.NET\Effects\ColorSort.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\ColorZoomBlur.dll, version='1.1.3873.36417'
   C:\Program Files\Paint.NET\Effects\ComputeShaderEffects.dll, version='1.0.0.6'
   C:\Program Files\Paint.NET\Effects\CondHSAdj.dll, version='1.7.2618.31817'
   C:\Program Files\Paint.NET\Effects\CurtisBlack.Common.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\Effects\CurtisBlack.Effects.dll, version='11.1.3736.39220'
   C:\Program Files\Paint.NET\Effects\CurtisBlack.Resources.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\Effects\Curves+.dll, version='3.0.3627.29849'
   C:\Program Files\Paint.NET\Effects\CustomBrushesMini.dll, version='2.1.4039.25699'
   C:\Program Files\Paint.NET\Effects\Displacement.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\DistortingMirror.dll, version='1.0.3851.29620'
   C:\Program Files\Paint.NET\Effects\DPL KAL.dll, version='1.0.3937.11496'
   C:\Program Files\Paint.NET\Effects\dpyColorBalance.dll, version='1.0.3518.25420'
   C:\Program Files\Paint.NET\Effects\DragFrom.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\droste.dll, version='0.1.0.0'
   C:\Program Files\Paint.NET\Effects\EdHarvey.DrawingHelpers.dll, version='3.22.2940.32375'
   C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.dll, version='3.5.3786.8637'
   C:\Program Files\Paint.NET\Effects\EditableText.dll, version='1.0.1.0'
   C:\Program Files\Paint.NET\Effects\Enlarge.dll, version='1.0.4162.27486'
   C:\Program Files\Paint.NET\Effects\ErodeDilate_v0.2.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\Effects\ExtendBorder.dll, version='1.3.0.0'
   C:\Program Files\Paint.NET\Effects\Feather.dll, version='3.0.3723.26349'
   C:\Program Files\Paint.NET\Effects\Film.dll, version='2.0.3612.21577'
   C:\Program Files\Paint.NET\Effects\Filters.dll, version='1.0.3853.27872'
   C:\Program Files\Paint.NET\Effects\FindEdges.dll, version='1.2.0.0'
   C:\Program Files\Paint.NET\Effects\Frame.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\GenTree.dll, version='0.1.0.0'
   C:\Program Files\Paint.NET\Effects\Gradient Bars.dll, version='3.0.3627.29850'
   C:\Program Files\Paint.NET\Effects\Gradient Blocks.dll, version='1.0.3742.38604'
   C:\Program Files\Paint.NET\Effects\Gradient Blur.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\Effects\Gradient Mapping.dll, version='3.0.3627.29847'
   C:\Program Files\Paint.NET\Effects\GrainFiller.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\Gravity.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\GridMaker.dll, version='3.2.0.0'
   C:\Program Files\Paint.NET\Effects\HexaGrid.dll, version='1.2.0.0'
   C:\Program Files\Paint.NET\Effects\ImageShackUpload.dll, version='2.6.2.0'
   C:\Program Files\Paint.NET\Effects\IniFile.dll, version='2.0.1'
   C:\Program Files\Paint.NET\Effects\Jitter.dll, version='3.0.3612.21576'
   C:\Program Files\Paint.NET\Effects\JumbleMax.dll, version='1.0.4133.31165'
   C:\Program Files\Paint.NET\Effects\KaleidoGen.dll, version='1.2.0.0'
   C:\Program Files\Paint.NET\Effects\Kaleidoscope.dll, version='1.3.0.0'
   C:\Program Files\Paint.NET\Effects\Landscape.dll, version='1.1.3593.25344'
   C:\Program Files\Paint.NET\Effects\LensFlare.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\Lightning.dll, version='1.1.3896.32593'
   C:\Program Files\Paint.NET\Effects\LightRays.dll, version='1.3.0.0'
   C:\Program Files\Paint.NET\Effects\Liquify.dll, version='1.2.4112.39851'
   C:\Program Files\Paint.NET\Effects\Magnifier.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\Majority.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\maskUI.dll, version='1.0.3851.36525'
   C:\Program Files\Paint.NET\Effects\MathNet.Iridium.dll, version='2007.3.8.0'
   C:\Program Files\Paint.NET\Effects\Matrice.dll, version='1.0.3810.11744'
   C:\Program Files\Paint.NET\Effects\Melting.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\Effects\Metallize.dll, version='1.1.3504.33530'
   C:\Program Files\Paint.NET\Effects\MirrorRotateMenu.dll, version='2.0.1'
   C:\Program Files\Paint.NET\Effects\Moire.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\MosaicManiac.dll, version='1.0.0906.08'
   C:\Program Files\Paint.NET\Effects\MotionSharpen.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\MultiThreshold.dll, version='1.0.3730.36634'
   C:\Program Files\Paint.NET\Effects\Nebulous.dll, version='0.0.0.0'
   C:\Program Files\Paint.NET\Effects\NewtonFractal.dll, version='0.0.0.0'
   C:\Program Files\Paint.NET\Effects\NonRepeatableCollections.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\Effects\Oblique.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\Effects\Olden.dll, version='1.5.0.0'
   C:\Program Files\Paint.NET\Effects\Outline Object.dll, version='2.6.3612.21574'
   C:\Program Files\Paint.NET\Effects\Outline.dll, version='1.1.3160.31739'
   C:\Program Files\Paint.NET\Effects\Overliner.dll, version='1.2.3888.29226'
   C:\Program Files\Paint.NET\Effects\PageCurl.dll, version='1.3.0.0'
   C:\Program Files\Paint.NET\Effects\PaletteFromImage.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\Effects\Panelling.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\Pastel.dll, version='1.2.3182.29587'
   C:\Program Files\Paint.NET\Effects\PDNPalette.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\Effects\PerlinTexture.dll, version='1.1.3857.30918'
   C:\Program Files\Paint.NET\Effects\Perspective.dll, version='2.0.3716.33788'
   C:\Program Files\Paint.NET\Effects\PhotoAdjustments.dll, version='1.1.3670.37697'
   C:\Program Files\Paint.NET\Effects\PhotoFloodFillPlugIn.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\Effects\Pixelate+.dll, version='1.2.3742.38634'
   C:\Program Files\Paint.NET\Effects\PixelVal-Alpha.dll, version='0.0.0.0'
   C:\Program Files\Paint.NET\Effects\Polar.dll, version='1.1.1.0'
   C:\Program Files\Paint.NET\Effects\Polygones.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\PowerStretch.dll, version='1.9.3045.14671'
   C:\Program Files\Paint.NET\Effects\PrinterPlus.dll, version='1.5.0.0'
   C:\Program Files\Paint.NET\Effects\pyrochild.effects.common.dll, version='2.0.3106.38959'
   C:\Program Files\Paint.NET\Effects\pyrochild.effects.REQUIRED.dll, version='3.6.3742.39840'
   C:\Program Files\Paint.NET\Effects\RadialBlurDeluxe_v0.1.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\Effects\Radialcolors.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\rainbow loom.dll, version='3.0.3530.27322'
   C:\Program Files\Paint.NET\Effects\RainbowTwist.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\Random Effect.dll, version='1.3.3627.29846'
   C:\Program Files\Paint.NET\Effects\Random lines.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\Random Maze1.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\Random Maze2.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\Random Shape Fill.dll, version='1.5.3621.26292'
   C:\Program Files\Paint.NET\Effects\RefocusingSDe.dll, version='1.0.3760.21016'
   C:\Program Files\Paint.NET\Effects\ReverseColors.dll, version='1.0.4121.15722'
   C:\Program Files\Paint.NET\Effects\Rosaces.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\RotateText.dll, version='1.0.3586.32866'
   C:\Program Files\Paint.NET\Effects\RotateTextSUI.dll, version='1.0.3703.25609'
   C:\Program Files\Paint.NET\Effects\SBCommon.dll, version='3.0.0.0'
   C:\Program Files\Paint.NET\Effects\ScriptLab.dll, version='2.6.3627.29850'
   C:\Program Files\Paint.NET\Effects\SeamlessTextureMaker.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\Effects\SelectionTools.dll, version='2.0.3746.20418'
   C:\Program Files\Paint.NET\Effects\ShadowEffect.dll, version='1.1.0.43197'
   C:\Program Files\Paint.NET\Effects\Shape3D.dll, version='1.2.6.0'
   C:\Program Files\Paint.NET\Effects\SinWaves.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\SlimDX.D3D11.x64.dll, version=''
   C:\Program Files\Paint.NET\Effects\Smudge.dll, version='3.5.4162.28661'
   C:\Program Files\Paint.NET\Effects\Sparkles.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\SpeechBubble.dll, version='2.0.3747.41051'
   C:\Program Files\Paint.NET\Effects\Spiral.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\SpiralText.dll, version='1.3.4159.37832'
   C:\Program Files\Paint.NET\Effects\SpiroGraph.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\SpiroShapes.dll, version='2.0.0.0'
   C:\Program Files\Paint.NET\Effects\Splashes.dll, version='1.1.1.0'
   C:\Program Files\Paint.NET\Effects\Splatter.dll, version='1.6.3627.29848'
   C:\Program Files\Paint.NET\Effects\StarGlow.dll, version='1.0.3839.21249'
   C:\Program Files\Paint.NET\Effects\Stars.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\Effects\Stitch.dll, version='1.0.3627.29848'
   C:\Program Files\Paint.NET\Effects\ThatOtherApp.dll, version='2.2.0.0'
   C:\Program Files\Paint.NET\Effects\ThreadsMarker.dll, version='0.0.0.0'
   C:\Program Files\Paint.NET\Effects\ThreeCircles.dll, version='1.0.3852.28460'
   C:\Program Files\Paint.NET\Effects\Tiles.dll, version='1.1.1.0'
   C:\Program Files\Paint.NET\Effects\Trail.dll, version='1.0.3723.27562'
   C:\Program Files\Paint.NET\Effects\trail3d.dll, version='1.0.3902.32071'
   C:\Program Files\Paint.NET\Effects\Transparency.dll, version='1.1.3182.29244'
   C:\Program Files\Paint.NET\Effects\TreeGen.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\TubeOblique.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\Effects\Twist.dll, version='1.0.3742.39641'
   C:\Program Files\Paint.NET\Effects\TwistZ.dll, version='1.1.2.0'
   C:\Program Files\Paint.NET\Effects\Untitled.dll, version='1.0.4159.24106'
   C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll, version='3.8.0.0'
   C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll, version='3.8.0.0'
   C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.dll, version='3.8.0.0'
   C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll, version='3.8.0.0'
   C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll, version='3.8.0.0'
   C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll, version='3.8.0.0'
   C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll, version='3.8.0.0'
   C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll, version='3.8.0.0'
   C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll, version='3.8.0.0'
   C:\Program Files\Paint.NET\Effects\Vibrato.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\Volutes.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\WaterReflection.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\Waves.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\WaveText.dll, version='1.1.4159.37845'
   C:\Program Files\Paint.NET\Effects\WaveTextSUI.dll, version='1.1.4159.37868'
   C:\Program Files\Paint.NET\Effects\WetFloor.dll, version='1.1.0.0'
   C:\Program Files\Paint.NET\Effects\WhichSymbolPlus.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\Effects\XYCoords.dll, version='1.0.0.0'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\Microsoft.VisualBas#\0b96353f37e92297d4a4dd03a10e3e1f\Microsoft.VisualBasic.ni.dll, version='8.0.50727.5420 (Win7SP1.050727-5400)'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Design\daa5bf9f980223227e97aa9d9c6bbf21\System.Design.ni.dll, version='2.0.50727.5420 (Win7SP1.050727-5400)'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Xml\c813b78e94fdbbc26105edf4a14d8402\System.Xml.ni.dll, version='2.0.50727.5420 (Win7SP1.050727-5400)'
   C:\Windows\assembly\GAC_MSIL\mscorlib.resources\2.0.0.0_fr_b77a5c561934e089\mscorlib.resources.dll, version='2.0.50727.5420 (Win7SP1.050727-5400)'
   C:\Windows\system32\RichEd20.DLL, version='5.31.23.1230'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\ICSharpCode.SharpZi#\f0d119ddaa0a1432c43590277de38b0c\ICSharpCode.SharpZipLib.ni.dll, version='0.86.0.518'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\Accessibility\941db5e1e81527f7771c2d2a4fa5ff4b\Accessibility.ni.dll, version='2.0.50727.4927 (NetFXspW7.050727-4900)'
   C:\Windows\system32\CLBCatQ.DLL, version='2001.12.8530.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\explorerframe.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\DUser.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\DUI70.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\Microsoft.NET\Framework64\v2.0.50727\diasymreader.dll, version='8.0.50727.5420 (Win7SP1.050727-5400)'
   C:\Program Files\Paint.NET\FileTypes\AnimGIF.dll, version='2.3.4040.877'
   C:\Program Files\Paint.NET\FileTypes\AsciiArtFileType.dll, version='1.0.0.0'
   C:\Program Files\Paint.NET\FileTypes\AviFile.dll, version='1.0.2920.35272'
   C:\Program Files\Paint.NET\FileTypes\AVIImport.dll, version='2.3.0.0'
   C:\Program Files\Paint.NET\FileTypes\CodeFileType.dll, version='0.1.0.0'
   C:\Program Files\Paint.NET\FileTypes\DPXFileType.dll, version='1.0.0.1'
   C:\Program Files\Paint.NET\FileTypes\HexaTxt.dll, version='1.1.1.0'
   C:\Program Files\Paint.NET\FileTypes\IcoCur.dll, version='3.0.0.0'
   C:\Program Files\Paint.NET\FileTypes\OptiPngFileType.dll, version='8.11.30.0'
   C:\Program Files\Paint.NET\FileTypes\PhotoShop.dll, version='1.0.4.0'
   C:\Windows\System32\comdlg32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\propsys.dll, version='7.00.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\ntmarta.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\WLDAP32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\XmlLite.dll, version='1.3.1000.0'
   C:\Windows\system32\LINKINFO.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\apphelp.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Program Files\Alwil Software\Avast5\ashShA64.dll, version='6, 0, 999, 0'
   C:\Windows\system32\msi.dll, version='5.0.7601.17514'
   C:\Windows\system32\EhStorShell.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\ntshrui.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\srvcli.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\system32\cscapi.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\system32\slc.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\msls31.dll, version='3.10.349.0'
   C:\Windows\system32\SearchFolder.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\System32\StructuredQuery.dll, version='7.00.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\System32\Secur32.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\System32\SSPICLI.DLL, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\system32\mssprxy.dll, version='7.00.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\thumbcache.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\PSAPI.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\SHDOCVW.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\ieframe.DLL, version='9.00.8112.16421 (WIN7_IE9_RTM.110308-0330)'
   C:\Windows\system32\OLEACC.dll, version='7.0.0.0 (win7_rtm.090713-1255)'
   C:\Windows\system32\iertutil.dll, version='9.00.8112.16421 (WIN7_IE9_RTM.110308-0330)'
   C:\Windows\system32\samcli.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\system32\SAMLIB.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\netutils.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\system32\NetworkExplorer.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\WINMM.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\NetworkItemFactory.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\dtsh.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\FirewallAPI.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\system32\MPR.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\wkscli.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\system32\PortableDeviceApi.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\EhStorAPI.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\System32\npmproxy.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\FunDisc.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\ATL.DLL, version='3.05.2284'
   C:\Windows\System32\msxml6.dll, version='6.30.7601.17514'
   C:\Windows\system32\fdproxy.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\System32\fdwcn.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\System32\wcnapi.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\IconCodecService.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\fdWNet.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\IPHLPAPI.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\NSI.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\WINNSI.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\WS2_32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\dfscli.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\browcli.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Program Files\Internet Explorer\ieproxy.dll, version='9.00.8112.16421 (WIN7_IE9_RTM.110308-0330)'
   C:\Windows\system32\mswsock.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\DNSAPI.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\rasadhlp.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\dhcpcsvc.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\dhcpcsvc6.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\actxprxy.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\system32\urlmon.dll, version='9.00.8112.16421 (WIN7_IE9_RTM.110308-0330)'
   C:\Windows\system32\WININET.dll, version='9.00.8112.16421 (WIN7_IE9_RTM.110308-0330)'
   C:\Windows\system32\Normaliz.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\system32\ktmw32.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Configuration\5cde78d37a85f0f16357c9ce7e096534\System.Configuration.ni.dll, version='2.0.50727.5420 (Win7SP1.050727-5400)'
   C:\Windows\assembly\NativeImages_v2.0.50727_64\System.Security\b635e23f324f082741810d950cf2a6b6\System.Security.ni.dll, version='2.0.50727.5420 (Win7SP1.050727-5400)'
   C:\Windows\system32\SXS.DLL, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\System32\drprov.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\System32\ntlanman.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
   C:\Windows\System32\davclnt.dll, version='6.1.7601.17514 (win7sp1_rtm.101119-1850)'
   C:\Windows\System32\DAVHLPR.dll, version='6.1.7600.16385 (win7_rtm.090713-1255)'
Exception details:
System.ArgumentOutOfRangeException: Length cannot be less than zero.
Parameter name: length
  at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy)
  at PaintDotNet.Effects.CodeTextBox.OnKeyDown(KeyEventArgs e)
  at System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m)
  at System.Windows.Forms.Control.WmKeyChar(Message& m)
  at System.Windows.Forms.Control.WndProc(Message& m)
  at System.Windows.Forms.RichTextBox.WndProc(Message& m)
  at PaintDotNet.Effects.CodeTextBox.WndProc(Message& m)
This is the code I was working on, nothing special... (:Warning: WIP plugin, need some tests)
Hidden Content: code for codelab
// Name: Enlarge Color
// Author: 2011 MadJik (Jean-Claude Jay)
// Submenu: Color
// URL: http://www.getpaint.net/redirect/plugins.html
#region UICode
int Amount1 = 10; // [0,255] Tolerance mini
int Amount2 = 40; // [0,255] Tolerance maxi
bool Amount3 = true; // [0,1] Check with Primary color
bool Amount4 = false; // [0,1] Check with Secondary color
bool Amount5 = false; // [0,1] Invert changed colors
#endregion
ColorBgra PrimColor = (ColorBgra)EnvironmentParameters.PrimaryColor;
ColorBgra SecoColor = (ColorBgra)EnvironmentParameters.SecondaryColor;
ColorBgra PrimColorOut = PrimColor;
ColorBgra SecoColorOut = SecoColor;
ColorBgra CurrentPixel;
// added part with crash error ----------------
if (Amount5)
	PrimColorOut.R = (byte)(255 - PrimColorOut.R);
	PrimColorOut.G = (byte)(255 - PrimColorOut.G);
	PrimColorOut.B = (byte)(255 - PrimColorOut.;
	SecoColorOut.R = (byte)(255 - SecoColorOut.R);
	SecoColorOut.G = (byte)(255 - SecoColorOut.G);
	SecoColorOut.B = (byte)(255 - SecoColorOut.;
// end added part with crash error ----------------
		CurrentPixel = src[x,y];
		if (Amount3) if ((Math.Abs(CurrentPixel.R - PrimColor.R) >= Amount1) && (Math.Abs(CurrentPixel.G - PrimColor.G) >= Amount1) && (Math.Abs(CurrentPixel.B - PrimColor. >= Amount1))
  			  if ((Math.Abs(CurrentPixel.R - PrimColor.R) <= Amount2) && (Math.Abs(CurrentPixel.G - PrimColor.G) <= Amount2) && (Math.Abs(CurrentPixel.B - PrimColor. <= Amount2))
			CurrentPixel = PrimColorOut;
		if (Amount4) if ((Math.Abs(CurrentPixel.R - SecoColor.R) >= Amount1) && (Math.Abs(CurrentPixel.G - SecoColor.G) >= Amount1) && (Math.Abs(CurrentPixel.B - SecoColor. >= Amount1))
  			  if ((Math.Abs(CurrentPixel.R - SecoColor.R) <= Amount2) && (Math.Abs(CurrentPixel.G - SecoColor.G) <= Amount2) && (Math.Abs(CurrentPixel.B - SecoColor. <= Amount2))
			CurrentPixel = SecoColorOut;
		dst[x,y] = CurrentPixel;
  • 4 weeks later...
Hi Boltbait, firstly Codelab is a fantastic add in, good job.
Secondly I have installed it into paint however when I try to save as dll I get a message saying unable to build the dll. It also says cannot create temporary file c:\program files\paint.net\effects\cscb17.tmp access is denied.
yes I am an administrator on this pc with full rights to the program folder
thirdly I am new to writing in C but i am trying to write a piece of code which reads a file containing a list of x,y coordinates followed by rgb colors.in the format x,y,r,g,b,x,y,r,g,b,x,y,r,g,b......... or as an example 360,220,45,22,223,390,240,47,34,25,400,212,50,90,100..............
For each of these coordinates and rgb values I wish to fill in an area starting at the x,y coordinate with the relevant color. The fill will automatically stops when it reaches a black line. So if you picture odd shapes all over a page. This will color in each shape so long as I have a file listing one of the x,y cordinates within each shape on the page.
Can you tell me if this is possible using codelab and perhaps even giving me a shove in the right direction, I have already read your excellent 4 tutorials so I now have a bit of a clue.
Regards
In order to Save as DLL from CodeLab, you must run Paint.NET as an administrator. That is, right-click on the Paint.NET icon and select "Run as administrator" from the menu.
As for the other issue, you'd be better off creating a filetype plugin.
Click to play:
err filetype plugin ??? whats that
ok looked it up
Filetype plugin = a script that is run automatically when executable detects the type of file.
I need to develop the program first, I dont care how I run it, whether it is by selecting a file of a type or by hardcoding it into a dll file. I thought by doing it within paint and codelab I had most of the functionality already built in ?
  • 3 months later...
Version 1.8 released.
Just a little bug fix in how referenced assemblies are handled. You can join me in thanking pyrochild for the code needed to fix the problem.
As always, download your update here: http://boltbait.com/pdn/codelab/
Click to play:
Hmmm... Works on my machine. ;)
No one ever uses the File>New templates. So, I wouldn't worry about it. In fact, how did you even find that screen? :D
Looks like the button is still clickable, so I'll add it to the list... near the bottom. ;)
EDIT: FYI, the button on the left says "Generate Code" and the one on the right says "Cancel".
Click to play:
Regarding the buttons, it's probably a font size difference. Some systems use different default fonts, and it affects dialog layout.
The fix could be as simple as putting some logic into OnLayout() so that ClientSize.Height is equal to something like okButton.Bottom + 8
  • 3 weeks later...
I know this has been up before, and that a (imo bad) solution exists, but could you consider adding in an option to not auto-compile the code as you write it?
Frankly, it gets irritating when ones code writing process goes like this:
  • writes a few characters
  • *codelab freezes when compiling*
  • writes a few more characters
  • *codelab freezes when compiling again*
Otherwise, codelab is a gem. It really shines when doing casual prototypes of ideas.
Hi,
It is not only compiling (this is fast enough to ignore it) but it runs the effect on the image. If you have some "frozen" period, then you should considere to write your code over a smaller image.
Personaly I'm using a external editor as long as I'm not debugging...
Oh, I see. That explains the waiting time.
Anyway, I stand by my point. A switch would make editing in codelab swifter. Wouldn't this be fairly easy to implement? Wouldn't checking a flag variable (controlled by a something similar to the switch for large characters) be able to work?
(I might be wrong though. I haven't checked the source, so it could very well be a complex task.)
  • 11 months later...
Thanks so much for creating Code Lab -- it's a lot of fun to use.
I came across something odd, though ... when I try "Save as DLL" for some code that uses RandomNumber, it fails with the following error message:
"The name 'RandomNumber' does not exist in the current context (CS0103)"
... even though the code builds and runs just fine otherwise .
Tiny example:
		CurrentPixel.R = (byte) RandomNumber.Next(256);
RandomNumber obviously works fine for everybody else (there's all that code out there that uses it!), so I'm at a loss to work out what I am doing differently (Windows 7, 64 bit, Paint.net version 3.5.10, build 3.510.4297.28964, installed in the standard location C:\Program Files\Paint.NET).
Edited by davidf
Hello davidf - welcome,
Have you included the 'reseed' button in the U.I. ?
I tried your code without it, and, as you say it works directly in codelab but won't build. I then added the reseed button using the 'file/User interface designer' dialogue and managed to get it to build. (but haven't haven't tested it yet).
Also are you saving as a .cs file before trying to build?
Hope that helps - I'm no expert!
I think codelab does have a few issues with random numbers - but Mr 'Boltbait' would be the expert for that!
The last part of his Codelab tutorials (UI elements) has some info on random numbers.
I noticed a bunch of that stuff too when I wrote my plugin...the debug is real, uh, sassy that way.
Best bet is to:
01. Find some source that used something like that and do it the same way.
02. Change things here and there so it looks more like "proper" C# until there is no error. Beats having to experiment anyway.
My problem was I had a capitalized "IF" statement. I kept getting an error that the code was missing a line end marker.
Anywayz, the CodeLab is pretty cool and the Boltbait tutorials were great (although missing function definitions and a bit OOP oriented). C# is pretty complicated, but luckily you don't have to learn a bunch of it to write a plugin...or download Visual Studio and have it take over your computer.
One suggestion for users...when you change stuff in the debug window, remember to change things in your source text file, otherwise you're cs file will have LF in it. Then you have to open Notepad2 and replace all LF with CRLF...it's a real pain...at least for Windows users.
Good job tho!
"....brings out the duty in my soul" -Spinal Tap
  • 3 weeks later...
  • BoltBait changed the title to CodeLab v6.0 (for advanced users) Released June 25, 2020
