Need help with alpha channels...
The eaisest way for me to explain to you the help I am looking for is this...I am using a template for a sim-racing game that there is a alpha channel that I need to access. The template is a multilayered .psd. Here is a link...Thank you very much if you actually take the time to watch it because it will explain it way more than I can.
- Basically the "paint" schemes are comming out way to shiny and I need to alter the alpha channel so that it will remove this affect. I just don't know how to accomplish this with paint.net and or if I even can? Thank You for any help you can offer me!
You can download a filetype plugin so you can work on .psd files here.
I've used it a few times, and it breaks the file into the appropriate layers. You can then modify the layers how you see fit.
Have it...The issue is not that I can't open it...I don't know how to alter the alpha channel
Alpha channel is just a fancy way of saying "transparency." You can adjust the alpha channel of an entire layer by going to Layers>Properties and adjusting the Opacity slider, or selections using BoltBait's "Transparency" adjustment plugin.
Here in lies the problem...using another program I can access a channel dialog box that lets me view the active and inactive alpha channels. I can't seem to do this in paint.net or don't know how to. I have to turn on an alpha channel that is by default off. So first step would be how do I access the hidden alpha channels in paint.net or is this not possible?
Quite honestly, I don't even know what you mean. Is there a tutorial somewhere I could take a look at?
If you click the youtube link in my first post it will show you in ripoffshop...err photoshop what I am trying to accomplish.
It's around the 2min 10 sec mark.
