echo32gamer Posted March 14, 2008 Share Posted March 14, 2008 Is there a cropping tool, I can't seem to find it. Does anyopne know? Quote Link to comment Share on other sites More sharing options...
jerkfight Posted March 14, 2008 Share Posted March 14, 2008 2 things. 1. This belongs in General Questions & Discussion. 2. Select a section and press the crop button. Where's the Crop tool?Right under your nose, so to speak. Simply select the area you want to crop by using one of the selection tools. You can then move, resize, or even rotate the selection by using the Move Selection tool (2nd row, 2nd column). Finally, click on Crop to Selection in the Image menu (or press Ctrl + Shift + X, or use the button in the toolbar). If you're interested in selecting, say, a 4 inch by 6 inch area of the image, make sure the "Units" are set to inches (in the toolbar, or in the View -> Units menu), and then watch the statusbar (lower left in the main window) to see how large a selection is while you are drawing it. Quote Link to comment Share on other sites More sharing options...
