bethreil Posted March 11, 2008 Share Posted March 11, 2008 I have digital photos of a bedroom I want to paint. The walls and ceiling are white. Is there a way to make the walls and ceiling transparent using Paint.net tools? My plan is to then make a transparency from the photo and put different paint samples behind it to see how different colors would look in the room. Thanks, Beth Quote Link to comment Share on other sites More sharing options...
jchunn Posted March 11, 2008 Share Posted March 11, 2008 I have digital photos of a bedroom I want to paint. The walls and ceiling are white. Is there a way to make the walls and ceiling transparent using Paint.net tools? My plan is to then make a transparency from the photo and put different paint samples behind it to see how different colors would look in the room. Thanks, Beth Start by trying the magic wand. If that doesn't do it for you, try the "Color Replace" plugin in the Jesse Chunn plugin pack. Quote Total hack. Link to comment Share on other sites More sharing options...
