Big problem with execution of source code 3.22
Hi,
I put mt.exe and signtool.exe in windows directory, so that I built code successfully.
But, when I execute code, the following warning box is showed.
Paint.NET has detected that some important installation files are missing. If you click the Repari button..........
The missing files are: PaintDotNet.String.3.DE.resources, paintDotNet.Strings.3.ES.resources, ...
So, i click the Repair button, but failed.
OS: Windows XP SP2
Visual Studio 2008
What shall I do?
Please help me.
Thanks.
  • 4 weeks later...
The compiled build of Paint.NET does not provide these resources, and if you already have an installed version of Paint.NET, and did not build and run an installer from source, PdnRepair can not fix your issue. Just copy the resources from your existing install.
Or do like the dialog says, and use /skiprepairattempt... :roll:
ambigram signature by Kemaru
[i write plugins and stuff]
Wasn't in the dialog. Perhaps you have a different version? :roll:
Did you try to run a Debug or a Release build? It will only show that part of the message in Debug mode.
Aha! Makes sense.
The command-line will work in both modes, though.
Alternatively, you can go into the Startup.cs code and remove certain strings for that. Do you really need the Japanese and Italian translations? Didn't think so. :D
