32 bit depth MS flight simulator texture.
If your familiar with MS flight simulator Textures, they were created as a bitmap file format of 32 bit depth. When I open one of these airplane textures & make any color change with Paint.net & save, it turns into a 24 bit depth file & will not display any longer on the original aircraft. :(
I have looked at Save As but do not have any higher choices.
Any ideas?
The BMP codec that we have does not support loading saving the alpha channel with 32-bit BMP images. Because of this, we have it save in 24-bit format. If you want to retain the alpha channel, and if your other software supports it, I recommend using PNG or TGA.
Flight Simulator does not support formats that do not have the extention .bmp.
