Drop Shadow and other effects, KrisVDM's Plugin Pack (updated 2021-01-20)
KrisVDM
  • 11 months later...
I've just noticed that every time at first run when I use Kri's Average blur or drop shadow effect, PDN requests an internet connection in background. Any explanation ?
Interesting. It's downloading this XML document: http://users.telenet.be/krisvandermotten/Downloads/PaintDotNetEffects.xml
From looking at the contents of the document, I'm not sure what the purpose of the download would be. I'm guessing Kris was playing with some functionality, and forgot to remove it. Let's wait to hear it from the horse's mouth though.
  • 8 months later...
Make sure you have the latest version of both Drop Shadow and Scriptlab. If the problem persists, post your problem in the Scriptlab thread....
22 hours ago, jumbohotdogs100 said:
I have verstion 4.0.12 and scriptlab wont process the drop shadow effect :( is there any way I can fix this? I need the drop shadow effect to work for a project
ScriptLab was not working in paint.net 4.0.12 but this is fixed as of today. Please go download the latest version.
ambigram signature by Kemaru
[i write plugins and stuff]
  • BoltBait featured this topic
  • 2 months later...
  • 3 weeks later...
To be honest .. I actually stopped using paint.net a while ago primarily due to the fact it did not have an easy object align or drop shadow feature, two things I really relied on with the project I was then involved in.
I was still learning back then...didn't even know you could download plugins. I thought i'd recently give it another whirl to see if anythings changed..
Gotta say im impressed with what this guys offering 'for free' .. and i'm back to using it again on a regular basis.
Good job and thanks :)
  • 8 months later...
  • 4 months later...
The installer for this pack is not compatible with the Windows Store version. Does anyone have the DLLs separately? Need to know what plugin folders (Effects, FileTypes, Shapes) each go in as well. I'd ask the developer directly but due to the pack not being updated in over 7 years, I'm gonna guess he's not entirely interested in this any more.
A workaround for plugin installers that do not work with the Windows Store version is:
1. (If they do not already exist) Create two folders, one named "Effects" and one named "FileTypes", in the main "paint.net" folder, usually like "C:\Program Files\paint.net\Effects" and  "C:\Program Files\paint.net\FileTypes".
2. Download and run the plugin installer.
3. Follow the instructions in the second yellow "Note" at https://www.getpaint.net/doc/latest/InstallPlugins.html
4. Cut and paste the files installed in the folders in step 1 into the folders created in step 3.
Creating the folders under "Program Files" (both x86 and x64, separately and together) causes the installer to immediately crash when run. I do not want to have to install the non-Windows Store version of paint.net as I do not want to potentially cause conflicts from the install and eventual uninstall process. I've dug through the .exe and .dll in the zip folder that's downloaded, but can't find the effect .dll's in the a usable format.
Edited by InsanityOnABun
11 minutes ago, InsanityOnABun said:
I've dug through the .exe ... but can't find the effect .dll's in the a usable format.
The dll files are embedded in the exe file, but you need the proper developer tools (and know how to use them) to manually extract them.
I don't know what sort of conflicts you think you'll run into, but I say just do it. Or do it in a VM, or another physical computer.
I've added a second download option to the first post. Now you can download a zipped pack of DLLs for manual installation with the Store version of paint.net.
You will need to
  1. Download the zipped DLL package (click the big gray button)
  2. Extract the DLLs to the folder  /Documents*/paint.net App Files/Effects/
  3. Restart paint.net
* the name of this folder may be translated to your system language
Registry keys and / or config files both versions use that the installer may overwrite to default, the same that the uninstaller may clean up, stuff like that. I work in IT, I've learned to expect things like that. Not interested in getting a VM environment set up and a new VM spun up just to get some dll's. That seems a bit excessive. And besides, attention is going to be brought to this one way or another as more extension installers are found that don't recognize the store version.
You will need to
Excellent, thank you!
  • 3 months later...
On ‎2‎/‎18‎/‎2008 at 6:57 PM, BoltBait said:
OK, guys. Be nice.
Kris is sharing his hard work free of charge here.
I agree, if you don't like it, uninstall it. But it is free of all charges so there's no reason to be hating on his hard work
You joined just to quote something I said 10 years ago?
I'll be watching you.
Click to play:
  • 1 year later...
Hello,
I am about making neon or glowing rainbow text for My Daughter Bday.
I found this step https://forums.getpaint.net/topic/26770-porcelain-neon-text/
but the dropbox download link for drop shadow is dead, and KrisVDM doesnt seem active, I hope He is ok.
is there any other tutorial using PDN to make neon light, all I found in google search always show PS on how to make neon light text.
Thankyou.
Yes, the "zipped DLLs" link is dead, but the installer version link works fine.
I'm sure one of the moderators will fix the dropbox link shortly. In the meantime, click on the blue button to take you to Kris' site to download his plugins.
  • KrisVDM changed the title to Drop Shadow and other effects, KrisVDM's Plugin Pack (updated 2021-01-20)
