pyrochild 362 Posted March 13, 2008 Report Share Posted March 13, 2008 So are you now planning to implement the colour choosing feature when 3.30 stable build is developed? Considering he's the one who finally convinced Rick that a color-chooser was a must.... Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to post Share on other sites
KrisVDM 14 Posted March 13, 2008 Author Report Share Posted March 13, 2008 So are you now planning to implement the colour choosing feature when 3.30 stable build is developed?Planning? No, it's done. You'll need to download Paint.NET beta 2 though.Updated effects available through my blog at http://www.u2u.info/Blogs/Kris/ Quote Kris VandermottenDownload my Paint.NET Effects Link to post Share on other sites
jerkfight 17 Posted March 13, 2008 Report Share Posted March 13, 2008 So are you now planning to implement the colour choosing feature when 3.30 stable build is developed? Considering he's the one who finally convinced Rick that a color-chooser was a must.... Pyrochild, man, today im missing the obvious and your stating it. And thanks KrisVDM: Im going to still wait for a stable build Quote Link to post Share on other sites
KrisVDM 14 Posted March 13, 2008 Author Report Share Posted March 13, 2008 And thanks KrisVDM: Im going to still wait for a stable buildIt's pretty stable. Give it a shot, if it doesn't work out you can alway uninstall and go back to the latest non-beta release. Quote Kris VandermottenDownload my Paint.NET Effects Link to post Share on other sites
jerkfight 17 Posted March 13, 2008 Report Share Posted March 13, 2008 And thanks KrisVDM: Im going to still wait for a stable buildIt's pretty stable. Give it a shot, if it doesn't work out you can alway uninstall and go back to the latest non-beta release. Its not that its not stable, its that many plugins are in-compatible, so i rather wait. Infact i already downloaded it earlier, and went straight back... Quote Link to post Share on other sites
Ash 10 Posted March 14, 2008 Report Share Posted March 14, 2008 Can you have a list of all the effects in your package on the 1st post?So users will know what they will be getting with each dll. Done. Thanks! :wink: Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to post Share on other sites
Fisherman's Friend 1 Posted March 15, 2008 Report Share Posted March 15, 2008 Updated effects available through my blog at http://www.u2u.info/Blogs/Kris/ Thank you very much! One recommendation - maybe nonsense: I'd rather do Drop Shadow in the Object submenu, which is not built-in but common if you use popular effects like Feather or Outline Object. I don't think Stylize is the appropriate place for it - considering the other effects in the menu. "Object" however comes better to my mind. Edit: Fixed an issue with the quote. Quote Link to post Share on other sites
Ash 10 Posted March 15, 2008 Report Share Posted March 15, 2008 One recommendation - maybe nonsense: I'd rather do Drop Shadow in the Object submenu, which is not built-in but common if you use popular effects like Feather or Outline Object.I don't think Stylize is the appropriate place for it - considering the other effects in the menu. "Object" however comes better to my mind. Yes, Object menu is better! Even render is better! Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to post Share on other sites
BoltBait 3,235 Posted March 15, 2008 Report Share Posted March 15, 2008 I think the Object menu is best for drop shadow. In fact, I've been thinking of some more stuff to go in there... :shock: Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
jrjordan 0 Posted March 18, 2008 Report Share Posted March 18, 2008 I am fairly new at this program and don't know a lot about working it, but I cannot get the shadow effect or any of the plugin's effects to work. They appear in the menus, but when I adjust them nothing happens to the image on which I am working. I extracted the file, put the .dlls in the effects folder, but no luck when adjusting. I can move the adjustments, but the image is not altered, no drop shadow, no I have an extracted src.V3.2 file and an unextracted file with the same name, so I am not sure I need to do something else in the effects folder? The only setting that affects the image is when I uncheck "Keep original image" and the image goes black. I am running the beta version required. Any suggestions? Thanks!! Quote Link to post Share on other sites
Fisherman's Friend 1 Posted March 19, 2008 Report Share Posted March 19, 2008 I cannot get the shadow effect or any of the plugin's effects to work. They appear in the menus (...)I am running the beta version required. Does "any of the plugin's effects" mean you can't get the effects from this thread "13 effects and a..." working or do you have problems with all effects available? Quote Link to post Share on other sites
jrjordan 0 Posted March 20, 2008 Report Share Posted March 20, 2008 Yes, thanks for the request for clarification. Actually, I was wanting to use the drop shadow mainly and it will not work. I go to Effects > Stylize > Drop Shadow. I see the offset x and y, widening radius, blur, and shadow color. I widen the radius by moving the point to the right and nothing happens. Adjusting the shadow color does not change color, no x or y offset, no nothing. And it seems to not work only for the drop shadow. The main one I would like to use. Thanks for the help!! Quote Link to post Share on other sites
KrisVDM 14 Posted March 21, 2008 Author Report Share Posted March 21, 2008 I cannot get the shadow effect or any of the plugin's effects to work. They appear in the menus, but when I adjust them nothing happens to the image on which I am working. [...] I can move the adjustments, but the image is not altered, no drop shadow, noWhat kind of picture are you trying this on? You need a picture with transparency for the drop shadow to have any kind of effect. So it won't do anything on a jpeg image, for example. Just to see the effect, use the eraser with a big radius (100 pixels or so) and erase part of your image. Then try again. Quote Kris VandermottenDownload my Paint.NET Effects Link to post Share on other sites
jrjordan 0 Posted April 4, 2008 Report Share Posted April 4, 2008 Ok, yes, I just needed to set a transparency, thanks for your help. Quote Link to post Share on other sites
Ash 10 Posted May 30, 2008 Report Share Posted May 30, 2008 Seems many users not able to find the latest Drop shadow plugin. Sticky'd Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to post Share on other sites
iPollesion 0 Posted June 4, 2008 Report Share Posted June 4, 2008 Thank you for this plugin. I love it, it is nice. Color changing is a lot easier now. Thank you again, much needed. Quote Link to post Share on other sites
ChitoDog 1 Posted June 29, 2008 Report Share Posted June 29, 2008 I need some help installing the Vandermotten.PaintDotNetEffects.DropShadow.dll: The "Drop Shadow" effect, under the Stylize effect menu. I tried adding it, then I close my PdN program and reopen it, but I still can't find the Drop Shadow effect nowhere in "Stylize Effect Menu". I've tried this like 3 times now, but it still won't show. I've added other plug-ins before, but this is the first one I've added that won't show anywhere in the menu. Help anyone? Quote Link to post Share on other sites
BoltBait 3,235 Posted June 30, 2008 Report Share Posted June 30, 2008 Did you also include the Vandermotten.PaintDotNetEffects.dll? Here are some snippets from his first post: UPDATE: I heard your feedback. The effects are now split over six dll's (+ the framework one, always required) and the submenus should be ok now.Effects per DLL: [*:3vcs6enb] Vandermotten.PaintDotNetEffects.dll: You allways need this dll. It includes the framework used by the other dll's.[*:3vcs6enb] Vandermotten.PaintDotNetEffects.DropShadow.dll: The "Drop Shadow" effect, under the Stylize effect menu. With offset, widening, blur and a color picker. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
ChitoDog 1 Posted June 30, 2008 Report Share Posted June 30, 2008 Wow, thanx a lot BoltBait, I must've overlooked that part. I went ahead and added that .dll file as well and there it was, the drop shadow effect. Thanx again BoltBait, I really appreciate your help and quick response Quote Link to post Share on other sites
Newb 0 Posted July 23, 2008 Report Share Posted July 23, 2008 This isn't working for me. I have it downloaded, with the .dll thing, and it shows up in the stylize list, but when I try to use it, nothing happens. The image stays the same no matter how many times I use it or with what settings, it stay the same. Quote Link to post Share on other sites
RyuinfinityPDN 0 Posted July 25, 2008 Report Share Posted July 25, 2008 Which one? Quote -- Make an Explosion in Space-- Link to post Share on other sites
BoltBait 3,235 Posted July 25, 2008 Report Share Posted July 25, 2008 This isn't working for me. I have it downloaded, with the .dll thing, and it shows up in the stylize list, but when I try to use it, nothing happens. The image stays the same no matter how many times I use it or with what settings, it stay the same. Drop Shadow requires some transparent area around your object in order to put the shadow in. So, be sure the layer you're working on has some transparent area. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
soulthoughts 0 Posted August 8, 2008 Report Share Posted August 8, 2008 Okay I've read all the posts about the problems/fixes for getting this to work and it's still a no go for me. Do I unzip the plugin and put it in the effects folder like I did in the past? What should the folder structure look like? My folder structure looks like this: C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNet.Effects Inside the Vandermotten.PaintDotNet.Effects folder I have: Properties (folder) Resources (folder) Vandermotten.PaintDotNetEffects.Samples.dll src.V3.2.zip (zip file) Vandermotten.PaintDotNet.Effects.sln Vandermotten.PaintDotNetEffects.Blurs.dll Vandermotten.PaintDotNetEffects.dll Vandermotten.PaintDotNetEffects.DropShadow.dll Vandermotten.PaintDotNetEffects.Duotones.dll Vandermotten.PaintDotNetEffects.FadeEdge.dll Vandermotten.PaintDotNetEffects.Monochromes.dll I have no 'compatible' folder as mentioned in another post. I downloaded the plugin from the direct link. I am using v3.35 of pdn and running WinXP if it's relevant. Do I have to register the dlls? I'm at a loss. Thanks in advance. Quote Link to post Share on other sites
KrisVDM 14 Posted August 9, 2008 Author Report Share Posted August 9, 2008 Do I unzip the plugin and put it in the effects folder like I did in the past? What should the folder structure look like?Directly under C:\Program Files\Paint.NET\Effects\ (no subfolder!), place the dlls:Vandermotten.PaintDotNetEffects.dll (This one is mandatory) Vandermotten.PaintDotNetEffects.Samples.dll Vandermotten.PaintDotNetEffects.Blurs.dll Vandermotten.PaintDotNetEffects.DropShadow.dll Vandermotten.PaintDotNetEffects.Duotones.dll Vandermotten.PaintDotNetEffects.FadeEdge.dll Vandermotten.PaintDotNetEffects.Monochromes.dll Each of the effect dlls is optional, but of course, you need at least one. Quote Kris VandermottenDownload my Paint.NET Effects Link to post Share on other sites
soulthoughts 0 Posted August 11, 2008 Report Share Posted August 11, 2008 It's fixed! Thanks for the help. Quote Link to post Share on other sites
