Sign in to follow this
KrisVDM
Drop Shadow and other effects, KrisVDM's Plugin Pack (updated 2010-10-26)
To be honest .. I actually stopped using paint.net a while ago primarily due to the fact it did not have an easy object align or drop shadow feature, two things I really relied on with the project I was then involved in.
I was still learning back then...didn't even know you could download plugins. I thought i'd recently give it another whirl to see if anythings changed..
Gotta say im impressed with what this guys offering 'for free' .. and i'm back to using it again on a regular basis.
Good job and thanks :)
Share this post
Link to post
The installer for this pack is not compatible with the Windows Store version. Does anyone have the DLLs separately? Need to know what plugin folders (Effects, FileTypes, Shapes) each go in as well. I'd ask the developer directly but due to the pack not being updated in over 7 years, I'm gonna guess he's not entirely interested in this any more.
Share this post
Link to post
A workaround for plugin installers that do not work with the Windows Store version is:
1. (If they do not already exist) Create two folders, one named "Effects" and one named "FileTypes", in the main "paint.net" folder, usually like "C:\Program Files\paint.net\Effects" and  "C:\Program Files\paint.net\FileTypes".
2. Download and run the plugin installer.
3. Follow the instructions in the second yellow "Note" at https://www.getpaint.net/doc/latest/InstallPlugins.html
4. Cut and paste the files installed in the folders in step 1 into the folders created in step 3.
Share this post
Link to post
Creating the folders under "Program Files" (both x86 and x64, separately and together) causes the installer to immediately crash when run. I do not want to have to install the non-Windows Store version of paint.net as I do not want to potentially cause conflicts from the install and eventual uninstall process. I've dug through the .exe and .dll in the zip folder that's downloaded, but can't find the effect .dll's in the a usable format.
Edited by InsanityOnABun
Share this post
Link to post
11 minutes ago, InsanityOnABun said:
I've dug through the .exe ... but can't find the effect .dll's in the a usable format.
The dll files are embedded in the exe file, but you need the proper developer tools (and know how to use them) to manually extract them.
I don't know what sort of conflicts you think you'll run into, but I say just do it. Or do it in a VM, or another physical computer.
Share this post
Link to post
I've added a second download option to the first post. Now you can download a zipped pack of DLLs for manual installation with the Store version of paint.net.
You will need to
  1. Download the zipped DLL package (click the big gray button)
  2. Extract the DLLs to the folder  /Documents*/paint.net App Files/Effects/
  3. Restart paint.net
* the name of this folder may be translated to your system language
Share this post
Link to post
Registry keys and / or config files both versions use that the installer may overwrite to default, the same that the uninstaller may clean up, stuff like that. I work in IT, I've learned to expect things like that. Not interested in getting a VM environment set up and a new VM spun up just to get some dll's. That seems a bit excessive. And besides, attention is going to be brought to this one way or another as more extension installers are found that don't recognize the store version.
You will need to
Excellent, thank you!
Share this post
Link to post
On ‎2‎/‎18‎/‎2008 at 6:57 PM, BoltBait said:
OK, guys. Be nice.
Kris is sharing his hard work free of charge here.
I agree, if you don't like it, uninstall it. But it is free of all charges so there's no reason to be hating on his hard work
Share this post
Link to post
You joined just to quote something I said 10 years ago?
I'll be watching you.
Share this post
Link to post
lol btw I love your plugin pack :)
Share this post
Link to post
I have recently downloading and run the installer and restarted pdn but the plugins will not appear. I searched in the effects folder and they are not there either :( Any help on this matter would be appreciated :)
Share this post
Link to post
