Ego Eram Reputo 2,752 Posted June 3, 2020 Report Share Posted June 3, 2020 Download the zipped DLLs (gray button in the first post). Unzip the file Copy & paste the DLLs to the \Effects folder you have created. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
iTony888 0 Posted June 3, 2020 Report Share Posted June 3, 2020 12 hours ago, Ego Eram Reputo said: Download the zipped DLLs (gray button in the first post). Unzip the file Copy & paste the DLLs to the \Effects folder you have created. I already did that and it doesn't work as it keeps giving me an error message saying that the Effects installed incorrectly. I posted images about it. Quote Link to post Share on other sites
toe_head2001 1,789 Posted June 3, 2020 Report Share Posted June 3, 2020 1 hour ago, iTony888 said: I already did that You did not. You downloaded the installer. The link for the non-installer download is working again; use it. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
iTony888 0 Posted June 3, 2020 Report Share Posted June 3, 2020 2 hours ago, toe_head2001 said: You did not. You downloaded the installer. The link for the non-installer download is working again; use it. Where is the link for the non-installer? Quote Link to post Share on other sites
Djisves 533 Posted June 3, 2020 Report Share Posted June 3, 2020 On 2/18/2008 at 11:00 PM, KrisVDM said: Download (zipped DLLs for manual installation with Store version of paint.net) >>Zipped DLLs Quote Link to post Share on other sites
iTony888 0 Posted June 3, 2020 Report Share Posted June 3, 2020 (edited) 1 hour ago, Djisves said: I see it but unfortunately it will not allow me to download before I create an account and I am not going to do that. I think I will go back to the classic version of Paint.net because this is way too complicated to add plugins to the Windows app version. Thank you for all your help. Edited June 3, 2020 by iTony888 Quote Link to post Share on other sites
toe_head2001 1,789 Posted June 3, 2020 Report Share Posted June 3, 2020 32 minutes ago, iTony888 said: ... it will not allow me to download before I create an account ... This is not true at all. The download button is on the top-right of the webpage. A Dropbox account is not required; simply close the Dropbox registration form when it opens. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
iTony888 0 Posted June 4, 2020 Report Share Posted June 4, 2020 3 hours ago, toe_head2001 said: This is not true at all. The download button is on the top-right of the webpage. A Dropbox account is not required; simply close the Dropbox registration form when it opens. Oh I see how it works now. I click on direct download. A popup registration form appears. I closed it and nothing happened. I had to go back and re-click on direct download again and then the zip folder downloaded the second time. But I already went back to the classic version of Paint.net as its way more easy to install plugins. I spent over 2 days trying to get plugins to work with Paint.net Windows app version. Then after I installed the classic version, a few minutes later and I have my plugins installed. Classic is so simple. Quote Link to post Share on other sites
RookieTeam 0 Posted June 16, 2020 Report Share Posted June 16, 2020 @toe_head2001I indeed have my issue fixed, I don't know what happened but, second what plugin does where colors are into a circle like a gradient chart or color wheel and they all zoom into a point? Quote Link to post Share on other sites
ThanosMassias 1 Posted July 8, 2020 Report Share Posted July 8, 2020 I don't know if Kris Vandermotten is still actively working on his plugins but I'd like to suggest adding the option to select which side(s) one wants to face in his Fade Edge plugin (for example, I might want to fade just the top and right sides). Quote Link to post Share on other sites
NSD 56 Posted July 8, 2020 Report Share Posted July 8, 2020 2 1 Quote Link to post Share on other sites
earmuffs 0 Posted September 6, 2020 Report Share Posted September 6, 2020 uhhhh when i download it, it tells me i need .NET framework 3.5 required, i install it, the installer usually appears after the download process is complete, but it didn't. is there something that i did wrong? Quote Link to post Share on other sites
doubleo20 0 Posted October 22, 2020 Report Share Posted October 22, 2020 (edited) hi i am trying to install the vandermotten pack plugin, i have installed the exe file but when i open paint.net, the drop shadow effect doesn't show up that is part of the pack i downloaded. theres another file in the folder that has .dll, I wonder if i s I am making photos for school projects. please reply asap Edited October 22, 2020 by Ego Eram Reputo Edited title & merged with VPP thread. Quote Link to post Share on other sites
Ego Eram Reputo 2,752 Posted October 22, 2020 Report Share Posted October 22, 2020 (edited) Hello & welcome to the forum @doubleo20 Drop Shadow can be found under the Effects > Object submenu. Did you look there? PS I've joined your thread to the KVDM plugin pack thread (we try to keep all the plugin discussions in one place). Edited October 23, 2020 by Ego Eram Reputo Spelling Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
doubleo20 0 Posted October 22, 2020 Report Share Posted October 22, 2020 58 minutes ago, Ego Eram Reputo said: Helo & welcome to the forum @doubleo20 Drop Shadow can be found under the Effects > Object submenu. Did you look there? PS I've joined your thread to the KVDM plugin pack thread (we try to keep all the plugin discussions in one place). yes. its not there. thank you for the response. I am also trying to figure out the problem myself. Quote Link to post Share on other sites
Djisves 533 Posted October 22, 2020 Report Share Posted October 22, 2020 2 hours ago, doubleo20 said: i have installed the exe file I may not have understood correctly, but just in case: The .exe file is the installation file. Only download the .exe file if you have the free version of Paint.NET. Extract the .exe file from the zip you have down loaded to your desktop. Don't copy the .exe file into the Effects folder. Keep the .exe file on your desktop. Double click the .exe file to install the plugins. If you have the store version, download the Zipped DLLs files on the forst post and follow the instructions On 2/18/2008 at 11:00 PM, KrisVDM said: Download the zipped DLL package (click the gray button) Extract the DLLs to the folder /Documents/paint.net App Files/Effects/ (create the folders if they are not present) Restart paint.net * /Documents/ may be translated to your system language Quote Link to post Share on other sites
