RoosSkywalker 1 Posted September 11, 2017 Report Share Posted September 11, 2017 Does the download link on the first page have the updated version? http://users.telenet.be/krisvandermotten/Downloads/PaintDotNetEffects.html Quote Link to post Share on other sites
AndrewDavid 730 Posted September 11, 2017 Report Share Posted September 11, 2017 Hi @RoosSkywalker That pack has not been updated for the newer versions of Paint. Last update to the pack was 2010. Fortunately all the effects still work in Paint 4.17 And yes - you can trust the link. Hope this helps. Quote Link to post Share on other sites
InsanityOnABun 0 Posted January 15, 2018 Report Share Posted January 15, 2018 The installer for this pack is not compatible with the Windows Store version. Does anyone have the DLLs separately? Need to know what plugin folders (Effects, FileTypes, Shapes) each go in as well. I'd ask the developer directly but due to the pack not being updated in over 7 years, I'm gonna guess he's not entirely interested in this any more. Quote Link to post Share on other sites
Djisves 541 Posted January 16, 2018 Report Share Posted January 16, 2018 A workaround for plugin installers that do not work with the Windows Store version is: 1. (If they do not already exist) Create two folders, one named "Effects" and one named "FileTypes", in the main "paint.net" folder, usually like "C:\Program Files\paint.net\Effects" and "C:\Program Files\paint.net\FileTypes". 2. Download and run the plugin installer. 3. Follow the instructions in the second yellow "Note" at https://www.getpaint.net/doc/latest/InstallPlugins.html 4. Cut and paste the files installed in the folders in step 1 into the folders created in step 3. Quote Link to post Share on other sites
InsanityOnABun 0 Posted January 16, 2018 Report Share Posted January 16, 2018 (edited) 2 hours ago, Djisves said: A workaround for plugin installers that do not work with the Windows Store version is: 1. (If they do not already exist) Create two folders, one named "Effects" and one named "FileTypes", in the main "paint.net" folder, usually like "C:\Program Files\paint.net\Effects" and "C:\Program Files\paint.net\FileTypes". 2. Download and run the plugin installer. 3. Follow the instructions in the second yellow "Note" at https://www.getpaint.net/doc/latest/InstallPlugins.html 4. Cut and paste the files installed in the folders in step 1 into the folders created in step 3. Creating the folders under "Program Files" (both x86 and x64, separately and together) causes the installer to immediately crash when run. I do not want to have to install the non-Windows Store version of paint.net as I do not want to potentially cause conflicts from the install and eventual uninstall process. I've dug through the .exe and .dll in the zip folder that's downloaded, but can't find the effect .dll's in the a usable format. Edited January 16, 2018 by InsanityOnABun Quote Link to post Share on other sites
toe_head2001 1,792 Posted January 16, 2018 Report Share Posted January 16, 2018 11 minutes ago, InsanityOnABun said: I've dug through the .exe ... but can't find the effect .dll's in the a usable format. The dll files are embedded in the exe file, but you need the proper developer tools (and know how to use them) to manually extract them. 14 minutes ago, InsanityOnABun said: I do not want to have to install the non-Windows Store version of paint.net as I do not want to potentially cause conflicts from the install and eventual uninstall process. I don't know what sort of conflicts you think you'll run into, but I say just do it. Or do it in a VM, or another physical computer. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
Ego Eram Reputo 2,762 Posted January 17, 2018 Report Share Posted January 17, 2018 I've added a second download option to the first post. Now you can download a zipped pack of DLLs for manual installation with the Store version of paint.net. You will need to Download the zipped DLL package (click the big gray button) Extract the DLLs to the folder /Documents*/paint.net App Files/Effects/ Restart paint.net * the name of this folder may be translated to your system language 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
InsanityOnABun 0 Posted January 22, 2018 Report Share Posted January 22, 2018 On 1/16/2018 at 1:03 PM, toe_head2001 said: The dll files are embedded in the exe file, but you need the proper developer tools (and know how to use them) to manually extract them. I don't know what sort of conflicts you think you'll run into, but I say just do it. Or do it in a VM, or another physical computer. Registry keys and / or config files both versions use that the installer may overwrite to default, the same that the uninstaller may clean up, stuff like that. I work in IT, I've learned to expect things like that. Not interested in getting a VM environment set up and a new VM spun up just to get some dll's. That seems a bit excessive. And besides, attention is going to be brought to this one way or another as more extension installers are found that don't recognize the store version. On 1/16/2018 at 7:33 PM, Ego Eram Reputo said: I've added a second download option to the first post. Now you can download a zipped pack of DLLs for manual installation with the Store version of paint.net. You will need to Download the zipped DLL package (click the big gray button) Extract the DLLs to the folder /Documents*/paint.net App Files/Effects/ Restart paint.net * the name of this folder may be translated to your system language Excellent, thank you! Quote Link to post Share on other sites
stevrons 0 Posted March 20, 2018 Report Share Posted March 20, 2018 This was great and a very helpful plugin, awesome, thank you Quote Link to post Share on other sites
tysmvm 0 Posted July 6, 2018 Report Share Posted July 6, 2018 On 2/18/2008 at 6:57 PM, BoltBait said: OK, guys. Be nice. Kris is sharing his hard work free of charge here. I agree, if you don't like it, uninstall it. But it is free of all charges so there's no reason to be hating on his hard work Quote Link to post Share on other sites
BoltBait 3,236 Posted July 7, 2018 Report Share Posted July 7, 2018 1 hour ago, tysmvm said: I agree, if you don't like it, uninstall it. But it is free of all charges so there's no reason to be hating on his hard work You joined just to quote something I said 10 years ago? I'll be watching you. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
tysmvm 0 Posted July 7, 2018 Report Share Posted July 7, 2018 13 hours ago, BoltBait said: You joined just to quote something I said 10 years ago? I'll be watching you. lol btw I love your plugin pack Quote Link to post Share on other sites
tysmvm 0 Posted August 1, 2018 Report Share Posted August 1, 2018 I have recently downloading and run the installer and restarted pdn but the plugins will not appear. I searched in the effects folder and they are not there either Any help on this matter would be appreciated Quote Link to post Share on other sites
Xeno_Xenino 0 Posted March 28, 2020 Report Share Posted March 28, 2020 good i like it Quote Link to post Share on other sites
Pharylon 0 Posted April 22, 2020 Report Share Posted April 22, 2020 Hey, the download link to the zipped files doesn't work. Thanks! Quote Link to post Share on other sites
hary 0 Posted May 23, 2020 Report Share Posted May 23, 2020 Hello, I am about making neon or glowing rainbow text for My Daughter Bday. I found this step https://forums.getpaint.net/topic/26770-porcelain-neon-text/ but the dropbox download link for drop shadow is dead, and KrisVDM doesnt seem active, I hope He is ok. is there any other tutorial using PDN to make neon light, all I found in google search always show PS on how to make neon light text. Thankyou. Quote Link to post Share on other sites
Djisves 541 Posted May 23, 2020 Report Share Posted May 23, 2020 58 minutes ago, hary said: the dropbox download link for drop shadow is dead Yes, the "zipped DLLs" link is dead, but the installer version link works fine. I'm sure one of the moderators will fix the dropbox link shortly. In the meantime, click on the blue button to take you to Kris' site to download his plugins. Quote Link to post Share on other sites
hary 0 Posted May 24, 2020 Report Share Posted May 24, 2020 12 hours ago, Djisves said: Yes, the "zipped DLLs" link is dead, but the installer version link works fine. I'm sure one of the moderators will fix the dropbox link shortly. In the meantime, click on the blue button to take you to Kris' site to download his plugins. Thanks for the reply Djisves. so the exe work for windows store version? from the info if I use the windows store version, the exe doesnt work. and have to copy the dll. I will give it a try. Thankyou. Quote Link to post Share on other sites
Djisves 541 Posted May 24, 2020 Report Share Posted May 24, 2020 No, the installer is only good for the classic version. The moderators have not fixed the link on the first post yet, so use this zip file until they do: Vandermotten.PaintDotNetEffects_DLLs.zip 1 1 Quote Link to post Share on other sites
hary 0 Posted May 27, 2020 Report Share Posted May 27, 2020 On 5/24/2020 at 3:47 PM, Djisves said: No, the installer is only good for the classic version. The moderators have not fixed the link on the first post yet, so use this zip file until they do: Vandermotten.PaintDotNetEffects_DLLs.zip Thankyou so much Djisves. 😊 Quote Link to post Share on other sites
RookieTeam 0 Posted May 27, 2020 Report Share Posted May 27, 2020 So First things first: It worked before alright, but when I do it now it breaks Explenation: I use one of his effects and then try to load it and then the whole paint.net crashes for no reason, With other of his plugins too, oh and It doesnt say any plugin error. Also i am using the free version And Its probably because of many plugins but what do you all think? Quote Link to post Share on other sites
toe_head2001 1,792 Posted May 27, 2020 Report Share Posted May 27, 2020 @RookieTeam, do you have a Crash Log you can post? Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
iTony888 0 Posted June 2, 2020 Report Share Posted June 2, 2020 I am using the latest Windows app Paint.net version 4.2.12 (Final 4.212.7454.35665) Not the classic version. Running Windows 10 OS. I have followed the instructions on this page https://www.getpaint.net/doc/latest/InstallPlugins.html and created the folders "Effects", "FileTypes", and "Shades" in documents. Then I add the "Vandermotten.PaintDotNetEffects.Installer.dll" to "Effects" folder. When I open Paint.net I get this error message. Kris Vandermotten's Effects installed incorrectly. Please run installer. I can't run the installer because that is for the classic Paint.net version. So what am I doing wrong? Quote Link to post Share on other sites
toe_head2001 1,792 Posted June 2, 2020 Report Share Posted June 2, 2020 27 minutes ago, iTony888 said: Then I add the "Vandermotten.PaintDotNetEffects.Installer.dll" to "Effects" folder. The "Vandermotten.PaintDotNetEffects.Installer.dll" file is not an Effect, and doesn't belong there. You can run the installer, and it will extract the Effect files into Program Files/... And then you can manually move the Effect files into Documents/... Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to post Share on other sites
iTony888 0 Posted June 3, 2020 Report Share Posted June 3, 2020 6 hours ago, toe_head2001 said: The "Vandermotten.PaintDotNetEffects.Installer.dll" file is not an Effect, and doesn't belong there. You can run the installer, and it will extract the Effect files into Program Files/... And then you can manually move the Effect files into Documents/... When I run the installer it tells me that Paint.net is not installed and will not finish the installation. Quote Link to post Share on other sites
