tanknspank 0 Posted April 3, 2009 Report Share Posted April 3, 2009 Thanks a lot. Ima smart little dude but when it comes to stuff like this i need a little help xD There is no button to push like you said. If it matters i am running on Vista. Quote Link to post Share on other sites
BoltBait 3,235 Posted April 3, 2009 Author Report Share Posted April 3, 2009 Sorry, I don't run Vista, maybe someone else can help? Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
tanknspank 0 Posted April 3, 2009 Report Share Posted April 3, 2009 Ok. Well thanks for trying. Quote Link to post Share on other sites
atypicalcarl 0 Posted April 3, 2009 Report Share Posted April 3, 2009 In Vista, I believe it'll be called "Open File Location." Do as Bolt says and click the effects folder, then paste (or drag and drop) your dll there. Quote When computers become self-aware and take over the world, the porn bots will get much, MUCH worse. Link to post Share on other sites
MortalShadows 0 Posted April 5, 2009 Report Share Posted April 5, 2009 I am guessing you are using vista, and for that reason, you will need to follow these steps to fix the problem... I am using version 3.36 of paint.net and vista 32 bit. I tried downloading the zip and extracting it, but vista wont allow me. I visited the link you gave, but I am a bit afraid whether or not I should activate the administrator account. Anyone else has done it? Is it safe? I am just a normal computer user and dont know much about the intricacies. Kindly suggest. Thanks for the plugins, I hope I can install and use those someday. Edited Later: Ok I have copy pasted the dlls without creating the administrator account. I can see them in the paint.net software. Is there a thread where I can know how I can use them, especially the feather plugin? Thanks again. Quote Link to post Share on other sites
atypicalcarl 0 Posted April 5, 2009 Report Share Posted April 5, 2009 An administrator account is necessary because Vista won't allow you to easily get around DEP. You'll need it to move files to program folders, etc. The *very* cool codelab project can only build a dll if you're running paint.net as an administrator on Vista. Visit the tutorials forum and read, read, read. It's a terrific resource! Quote When computers become self-aware and take over the world, the porn bots will get much, MUCH worse. Link to post Share on other sites
00e 0 Posted April 12, 2009 Report Share Posted April 12, 2009 what file do i download? Quote Link to post Share on other sites
Kelly_Girl33 0 Posted April 13, 2009 Report Share Posted April 13, 2009 Looks really good . Thanks! Quote Link to post Share on other sites
Tabou 0 Posted July 3, 2009 Report Share Posted July 3, 2009 Colour Balance is a must. Have you considered adding a Greyscale "checkbox switch" and a contrast slider? You would have a great channel mixer. Outline, feather, selections - it's all good. Thank-You. Quote Link to post Share on other sites
Lance McKnight 4 Posted August 18, 2009 Report Share Posted August 18, 2009 Hey BoltBait, could you possibly add options to your Bevel plugin? For example, Hard Chisel, Soft Chisel, and Pillow emboss. That way I can get rid of a couple of plugins and use yours instead. Quote Officially retired from this forum. Have a nice day. Link to post Share on other sites
BoltBait 3,235 Posted August 18, 2009 Author Report Share Posted August 18, 2009 Show me some examples of what you want and I'll explain why I can't. Thanks! Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
Lance McKnight 4 Posted August 19, 2009 Report Share Posted August 19, 2009 Disregard then because if you can't be able to add those different bevelling options. Edit: After I thought about what I meant, I decided to show you what I meant. In this tutorial, there were several different emboss/bevel being done. I currently have two plugins that does Bevel (beside yours), and Emboss/Engrave plugin. They are okay, but what I am looking for is a plugin that incoporate those "styles" and giving more control. I understand if they can't work because they are working from a selection of an image. However, running Emboss/Engrave or Bevel plugin, I have to select the image first before activating the UI in those plugins; otherwise, it will render the entire canvas rather than the selected object. Quote Officially retired from this forum. Have a nice day. Link to post Share on other sites
LJXD 0 Posted September 2, 2009 Report Share Posted September 2, 2009 For some reason all your plugins disappeared from the effects and adjustments menu when i updated my Paint.NET version to alpha v3.5. I'll download again but i'd thought i'd let you know. Quote |My Sig Tut| Deviant Art |Advanced Grunge Texture|My Gallery The Birthplace of Life Link to post Share on other sites
PatrickS91 0 Posted September 25, 2009 Report Share Posted September 25, 2009 Awesome pack! Now if I could only make ovals correctly, life would be perfect.. Well, more perfect than it is now. Quote Link to post Share on other sites
satishbhawra37 0 Posted September 25, 2009 Report Share Posted September 25, 2009 flips the selection on the vertical axis. Similar to the layer flip of the same name. :Vertical: Flip Vertical - flips the selection on the horizontal axis. Similar to the layer flip of the same name. Quote Link to post Share on other sites
Dr. Agon 0 Posted October 2, 2009 Report Share Posted October 2, 2009 My computer (or at least I THINK it's my computer) won't let me download these files. I followed your instructions on it, but unzip does not come up... why is that? Quote "I reject your Reality and Substitute my own" -Adam Savage, Mythbusters My PhotoBucket Link to post Share on other sites
Ego Eram Reputo 2,753 Posted October 3, 2009 Report Share Posted October 3, 2009 Are you downloading the *.zip file from the first post, or have you clicked on the information icon and been taken to BoltBaits website? If it's the latter option, the files on that website are not zipped :wink: Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
LibbyH 2 Posted October 7, 2009 Report Share Posted October 7, 2009 BoltBait this is an amazing plug-in pack. I'm really excited about the new Gaussian Blur effect, I love what it did with the picture you posted, and the feather option. (And I'm excited about testing the others as well.) Thanks! Quote My Gallery Link to post Share on other sites
justlittlethings 0 Posted October 7, 2009 Report Share Posted October 7, 2009 Hi. I can't seem to install these plugins. I saved the download to the effects folder and clicked it. All the files are there, pretty as you please, but when I open paint.net, the plugin features aren't there. My paint.net folder sits directly on my c drive, not in the program files folder and I have windows vista. Does anyone have any advice. I need these plugins badly. Thanks in advance. Quote Link to post Share on other sites
Sarkut 7 Posted October 7, 2009 Report Share Posted October 7, 2009 (edited) The plugin .dll files need to be copied from the zip and pasted into the Effects folder. All folders zip or non-zip should be removed from the Effects folder. Only plugin files in the Effects folder, no folders. =================================== Edited July 20, 2010 by Sarkut Quote Link to post Share on other sites
iRemy 0 Posted October 17, 2009 Report Share Posted October 17, 2009 Um every time i download this and save it to my effects folder, it says it's saved. but then when i go to unzip it, its not there... help? :? Quote Link to post Share on other sites
BoltBait 3,235 Posted October 18, 2009 Author Report Share Posted October 18, 2009 To those who have donated... THANK YOU! Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to post Share on other sites
Electroman 0 Posted October 18, 2009 Report Share Posted October 18, 2009 Useful, thanks for posting Quote Link to post Share on other sites
