Ego Eram Reputo Posted October 3, 2013 Share Posted October 3, 2013 Wait - you downloaded a plugin pack from somewhere else? That was ill-advised as you have found. The PDF version of the Plugin Index has the filename listed for each plugin dll. Use that information to confirm you have the correct dll(s) installed and remove the others. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
johnnysdream Posted October 4, 2013 Share Posted October 4, 2013 Wait - you downloaded a plugin pack from somewhere else? That was ill-advised as you have found. The PDF version of the Plugin Index has the filename listed for each plugin dll. Use that information to confirm you have the correct dll(s) installed and remove the others. Well I figured that would be the very first thing that someone would reply with.The fact is,I downloaded it again and again and again.AFTER I deleted them from my effects folder like you said(thanks for the reply btw).They are all 3 still there.Again,all the other packs(including everything in the Bolt pack)install just fine except for oldfeather.Last night I found a couple ways to do the same job.Antialias or something like that.But I still prefer oldfeather. Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted October 4, 2013 Share Posted October 4, 2013 Have you tried TR's Edge Fader? Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
johnnysdream Posted October 4, 2013 Share Posted October 4, 2013 Have you tried TR's Edge Fader? Actually I installed that a few days ago.It seemed to fade the edges really good but yet the edge that was left was still a lil jagged.I'll have another go at that. Quote Link to comment Share on other sites More sharing options...
charlieb000 Posted June 2, 2016 Share Posted June 2, 2016 (edited) BoltBait, can you update your website (http://www.boltbait.com/pdn/) to include a link to here for people on XP/3.5? for some reason it came up in google search, and it only had the link for the newer version. I had the impression that PDN was not very useful because it had no ability to add or manipulate alpha in an image (except paste, where it was a hinderance, it wiped out the image!)… and then i saw PDN had the ability to have plugins… now all i need is a plug in that will rearrange the list of plugins in the menu according to what they manipulate (ie: transparency (distribution/reprocess), colours (distribution/reprocess), process content (S&D/replace), lensing (blur/reshape), Computer Generated Imagry (2d, 3d)) probably will need submenus due to the number available. Edited June 2, 2016 by charlieb000 Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 2, 2016 Share Posted June 2, 2016 Plugins cannot alter the placement of other plugins in the menu system. I believe there are one or two plugins which can be relocated in this way - it is not the norm. Your best bet for bookmarking your favorite plugins is the Plugin Browser (link in my signature). RE: 3.5 - I'm not sure if BoltBait is still supporting PDN 3.5. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
