Subscript or superscript available for fonts?
Superscript and subscript aren't different symbols, they're a different way of displaying words (above or below the line).
I know, but if you use the equation creator in MS Word you can type it out and then copy it into paint.net. Makes typing anything not on the keyboard really easy.
No, you don't understand. Superscript and subscript aren't something available in the Equation Editor; it's just a different way of rendering existing text. Curmudgeon's suggestion is the easiest.
  • 13 years later...
