Racingdj08 Posted February 12, 2008 Share Posted February 12, 2008 Well ok, i drew a car and want to know how to render the reflections and colors on the car....I know how i want to do the reflections, gradiants, ect, but i cant figure out how...please help. This is how far I am, Its based off the Mitsubishi Concept RA: Quote My to be Gamertag for Xbox 360: RaDJ038v2 Currently it is: RacingDJ0388 Forget the gamertag change. Its fine. Link to comment Share on other sites More sharing options...
ncfan51 Posted February 12, 2008 Share Posted February 12, 2008 I will edit my post and tell you soon, as I'm a bit busy now. Don't lose hope...yet. Quote +_+_+_+_+_+_+_+_+_+_+_+ I am a disco dancer. +_+_+_+_+_+_+_+_+_+_+_+ Link to comment Share on other sites More sharing options...
Racingdj08 Posted February 14, 2008 Author Share Posted February 14, 2008 Ok i will wait, thanks Quote My to be Gamertag for Xbox 360: RaDJ038v2 Currently it is: RacingDJ0388 Forget the gamertag change. Its fine. Link to comment Share on other sites More sharing options...
ncfan51 Posted February 14, 2008 Share Posted February 14, 2008 1. Select a part of the car. 2. Apply a gradient. 3. New layer 3. This is tricky. Set the rounded rectangle tool to "filled shape" and draw it somewhere. Then use Layer>>Rotate/Zoom to position it correctly. Lower the opacity. Sorry these instructions are not super clear; If you still have problems, PM "Pyjo", as he is really good at this stuff. Pyjo is so good he made this: viewtopic.php?f=12&t=22117&p=136010#p136010 Quote +_+_+_+_+_+_+_+_+_+_+_+ I am a disco dancer. +_+_+_+_+_+_+_+_+_+_+_+ Link to comment Share on other sites More sharing options...
Racingdj08 Posted February 14, 2008 Author Share Posted February 14, 2008 Ok that somewhat answers my question, im going for a more realistic look, but i'll try that. Also adding a reflection to the car how do i "bend" the reflection Quote My to be Gamertag for Xbox 360: RaDJ038v2 Currently it is: RacingDJ0388 Forget the gamertag change. Its fine. Link to comment Share on other sites More sharing options...
Racingdj08 Posted February 15, 2008 Author Share Posted February 15, 2008 ok thanks question answered.. Heres my shot at it, i'll post my final version in the pictorium http://img88.imageshack.us/my.php?image ... ineys6.png Quote My to be Gamertag for Xbox 360: RaDJ038v2 Currently it is: RacingDJ0388 Forget the gamertag change. Its fine. Link to comment Share on other sites More sharing options...
