Bricks (updated with examples)
jchunn
  • 11 years later...
13 hours ago, Eli said:
@jchunn A neat effect. Thanks! it would be great if the width and height size were not limited to just 200.
This is a thread over 10 years old so he probably never will update it, but the brick effect is something that I can definitely do. It doesn't look too hard to recreate and expand.
Edited by Reptillian
G'MIC Filter Developer
@Reptillian Yes, it  is an old effect that needs some refreshing. If you can recreate it may I suggest two improvements: bricks with adjustable rounded corners and an option to offset the bricks to the left or right.
