Help understanding the Conical and Diamond gradients
4fingers
Hi,
I was just wondering how the Conical and Diamond gradients were achieved.
So far I have only been able to get a linear like gradient using something like this:
gradient = sin(pos.x * Pi)
I am just interested in the algorithm or pseudo code. I tried looking at the source but had no idea where to look.
Any help would be great.
Relevant files:
\pdn_src_3_20\src\tools\GradientTool.cs
\pdn_src_3_20\src\Core\GradientRenderer.cs
\pdn_src_3_20\src\Core\GradientRenderers.cs
Also, http://en.wikipedia.org/wiki/Image_gradient
ambigram signature by Kemaru
[i write plugins and stuff]
Thanks for the tip I think I managed to find the code I was looking for:
public sealed class LinearDiamond
           : LinearStraight
           public override float ComputeUnboundedLerp(int x, int y)
               float dx = x - StartPoint.X;
               float dy = y - StartPoint.Y;
               float lerp1 = (dx * this.dtdx) + (dy * this.dtdy);
               float lerp2 = (dx * this.dtdy) - (dy * this.dtdx);
               float absLerp1 = Math.Abs(lerp1);
               float absLerp2 = Math.Abs(lerp2);
               return absLerp1 + absLerp2;
           public override float BoundLerp(float t)
               return Utility.Clamp(t, 0, 1);
           public LinearDiamond(bool alphaOnly, BinaryPixelOp normalBlendOp)
               : base(alphaOnly, normalBlendOp)
I was just wondering what was held in the variables "this.dtdx" and "this.dtdy". Although I can see the code I am not quite sure what it is doing:
protected float dtdx;
           protected float dtdy;
           public override void BeforeRender()
               PointF vec = new PointF(EndPoint.X - StartPoint.X, EndPoint.Y - StartPoint.Y);
               float mag = Utility.Magnitude(vec);
               if (EndPoint.X == StartPoint.X)
                   this.dtdx = 0;
               else
                   this.dtdx = vec.X / (mag * mag);
               if (EndPoint.Y == StartPoint.Y)
                   this.dtdy = 0;
               else
                   this.dtdy = vec.Y / (mag * mag);
               base.BeforeRender();
What does "Utility.Magnitude(vec)" do?
Why do you do "this.dtdx = vec.X / (mag * mag)" when both end and start points are the same?
Thanks again
