Image Umbrella: Realistic Images
I believe alpha mask takes the average of the mask's color and sets the original image's (the one that is displayed on your canvas) alpha to that average and does it pixel after pixel. Thats why color is not very important, also the alpha channel is only 1 channel red, green and blue are 3 so it would be impossible to use all 3 on the alpha channel.
History repeats itself, because nobody was paying attention the first time.
Link to post
I hope I understand you right, anyway: the mix alpha function allows you to mix the alpha your current picture has with the lumosity of the mask, so if I'm correct leaving the mix alpha option unchecked should just set the mask average color to alpha.
Masking works best when the mask is anti-aliased like lines or shapes, the image you're masking doesn't really matter.
Link to post
If you want color values in a mask, use Channel Mask. Sharp, try using lens on the planet to give it a rounded feel, then add lighting and shadow etc. :wink:
Oma, great job on the wine bottle, i just think the white highlight is too strong and thick, maybe some transparency too? :wink:
Merry Christmas
Link to post
Add height to the brown skin (emboss/relief) + add the shine (white to transparent gradient) on both sides + a blend mode? The seeds need to be added as well. :P (these ideas are just off the top of my head, they may not work.. use at own risk)
Looking great though! :D
Merry Christmas
Link to post
Well, basically, how did you distort the spheres (head, body, etc.) so that they weren't spheres?
I've tried a couple and they haven't worked. It looks similar to one of Madjik's works.
"pyrochild, you're my favorite person ever. We should go snowboarding some time."~ 007 Nab. Ish.
PDN Gallery | I Made a Deviant Art!
Link to post
don't know which one you mean by Madjik I didn't follow anything but what was in my head.
similar to how I did the cherries (see my pear tut near the bottom of page 2)
basically its sphere 3d full sphere
next layer same texture sphere 3d but use half sphere I didn't save the settings, but if you can't figure them out let me know I can most likely re do pretty close for you.
put a little black blur on a separate transparent layer down the centre under the half sphere and over the layer of the full sphere. flatten
I didn't save the exact settings I used (this is a mock up of the settings I did)
hope that is what you want to know
ciao
OMA
Link to post
:lol::lol: yes he was very nightmare-ish wasn't he. Helen and I had been PMing about good and bad images and about either posting them or not. He was one I pulled out of the trash bin.
At least Nab I hoped learned how to do a step he was needing for a project from it.
:lol::lol: That poor puppy was so ugly! now he is going back in the trash bin. I have said in the past I learn a lot from my bad trash. This one I learned red and yellow and green don't look good as dog colors (looks more like a turkey than a dog) :lol::lol: but on the plus side I learned how to give good perspective of a dog coming out of the screen towards you. Which by the way was the original experiment.
@stealthed when you look off in the distance at land you sometimes see some greenish blue in the tree line. and some browns, you see tree trunk color but not the actual tree trunks because of all the leaves.
More variety of green tones could help, maybe even darker ones in the gully like areas.
When I did my landscape I have in the galleria I used some dithers and stretched and pulled them around (using same method for distortion as in the dog above.) and then lowerd the transparency. I'm not sure if that's the look you are going for but I thought it gave me the real mottled feel of forests.
EDIT Stealthed I hope it was trees and not just hilly grass. either way it really needs to be more dark tones less acidy green looking.
ciao
Link to post
Thanks Oma, I tried responding last night but the connection kept timing out.
Now I understand how you got those shapes, I think it'll come useful in the future.
Thanks again for all your help,
Nab
Link to post
