led_blunt Posted February 4, 2008 Share Posted February 4, 2008 Hi All, I am relatively new to Paint.Net, but love it, of course... Looked throught the tuts but can't quite figure this on out, any help would be great. Want to make the attached image look 3D and gold metallic, any tuts or tips would be apreciated. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Mike Ryan Posted February 4, 2008 Share Posted February 4, 2008 I believe there is a chrome text tutorial somewhere that with a little modification could get you your effect. H/O... Ahh! Here it is! Just shade it in a gold color at the end of the effect and it should look somewhat like what you describe. As for the real thing it would have to be multiple layers, brush tool, gaussian blur and the sorts. Not fun Quote Link to comment Share on other sites More sharing options...
BoltBait Posted February 4, 2008 Share Posted February 4, 2008 OK, here's how you can do it yourself. 1. Open your image Here is how to add some shading so that it looks 3D: 2. Layer > Duplicate Layer (Your graphic should have 2 layers now, both with a copy of your graphic.) 3. Select the top layer 4. Effects > Blurs > Gaussian Blur (Radius = 10) 5. Layers > Layer Property (Set blending mode to Darken and adjust Opacity for desired 3D effect) 6. Image > Flaten Here is how to color it gold: 7. Image > Add new layer 8. Select the new, empty, top layer 9. Fill that layer with color FFD92B (You can do this by entering FFD92B into the Hex box of the More>> mode of the Colors Docker window for your primary color. Then using the paint bucket tool fill the layer with color.) 10. Layers > Layer Property (Set blending mode to Multiply) 11. Image > Flaten Done. Here is the result: By the way, this method only works because your background color was black. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Curmudgeon Posted February 4, 2008 Share Posted February 4, 2008 Nice result, and simple too! Quote Link to comment Share on other sites More sharing options...
Ash Posted February 5, 2008 Share Posted February 5, 2008 A bit harder to do, if you like it, I can teach you a bit later. My connection in one AZ hotel feels like dial up I'll be back home in 1 week :? If more people wanna learn this, then I will make it a tut. Hint: Curves+ & Curves+ Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
Stephan Posted February 5, 2008 Share Posted February 5, 2008 My try: I did outline it to show that it is in fact 3d... Kinda... Sort of. Quote Link to comment Share on other sites More sharing options...
iKid Posted February 6, 2008 Share Posted February 6, 2008 Maybe you will like this~ I used BB's method, which worked good, then I tweeked it a little bit. 1. Open your imageHere is how to add some shading so that it looks 3D: 2. Layer > Duplicate Layer (Your graphic should have 2 layers now, both with a copy of your graphic.) 3. Select the top layer 4. Effects > Blurs > Gaussian Blur (Radius = 10) 5. Layers > Layer Property (Set blending mode to Darken and adjust Opacity for desired 3D effect) 6. Image > Flaten Here is how to color it gold: 7. Image > Add new layer 8. Select the new, empty, top layer 9. Fill that layer with color FFD92B (You can do this by entering FFD92B into the Hex box of the More>> mode of the Colors Docker window for your primary color. Then using the paint bucket tool fill the layer with color.) 10. Layers > Layer Property (Set blending mode to Multiply) 11. Image > Flaten Quote Link to comment Share on other sites More sharing options...
