jaznet Posted February 1, 2008 Share Posted February 1, 2008 I felt this would be useful when working with many layers, to avoid having to click the up/down buttons so many times. Instead you could scroll using drag. Also useful when testing mult. possible combos for different backgrounds. Quote Link to comment Share on other sites More sharing options...
pyrochild Posted February 1, 2008 Share Posted February 1, 2008 I agree, but this might fall under Popular Feature Requests[/url]":1r1t2v0i]Layer "folders", or the ability to organize layers in a hierarchy -- I want this too, and it depends on some major plumbing work being done. This would be a Paint.NET v4.0 level of feature. No ETA. Quote ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
jaznet Posted February 12, 2008 Author Share Posted February 12, 2008 Yeah, I read that thread too, yet I don't think it would require a hierarchy, but iinstead giving you the ability to use just the Layers window itself to organize using drag and drop. The layers are already in a set order when you create them, but say you wanted to see how two layers at the bottom would look in the front of the set. Instead of constantly clicking the arrow buttons, with this feature you could just drag and drop the labels within the Layers window to where you want them in the set, like you'd do with a slide sorter in a presentation program. Quote Link to comment Share on other sites More sharing options...
Myrddin Posted February 12, 2008 Share Posted February 12, 2008 yet I don't think it would require a hierarchy, but iinstead giving you the ability to use just the Layers window itself to organize using drag and drop.But, is this not the same as......ability to organize layers in a hierarchy......?Yes, I believe it to be. By clicking and dragging you are organising. By organising you are therefore creating a hierarchy; you are giving precedence to one layer over another. Regardless of semantics, I think the point pyrochild was alluding to was that this a v4.0 feature. EDITED: added more to the abridged quote; it gives more sense to what I wrote after. Quote How to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
I Like Pi Posted February 12, 2008 Share Posted February 12, 2008 I believe Rick meant folders by hierarchy, since by the definition of hierarchy you mentioned, you can already organize layers in a hierarchy. I'm pretty sure that this would not need the rearchitecturing planned for 4.0, since the layers are still in a linear order (i.e. not in folders). Quote Link to comment Share on other sites More sharing options...
Myrddin Posted February 12, 2008 Share Posted February 12, 2008 Well, Rick does make the distinction between 'folders' and 'hierarchical ordering', hence my absence of mention to folders. Although, this I do agree with... since by the definition of hierarchy you mentioned, you can already organize layers in a hierarchy.But, in context, I went along with the notion of drag-hierarchy. Quote How to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
