nikwolf Posted January 22, 2008 Share Posted January 22, 2008 Hi, does paint.net evaluates the system color profile for the monitor? I have a calibrated monitor with a dedicated color profile. For displaying colors correctly, the application has to convert them to the monitor color space. Is paint.net able to do this or is this planed for the future? Regards, Nikwolf Quote Link to comment Share on other sites More sharing options...
k.digennaro Posted January 22, 2008 Share Posted January 22, 2008 im not exactly sure, but are you saying you need to calibrate the colors with the pc? if it is, i have that same problem for instance if i color something red on PDN and print it, when it comes out its pink. Quote Support Our Troops, End The War Link to comment Share on other sites More sharing options...
nikwolf Posted January 22, 2008 Author Share Posted January 22, 2008 Yes, but I am having the problem with blue This function is a part of color management. I have applications which do evaluate the color profile, and PDN display images differently. Quote Link to comment Share on other sites More sharing options...
