Color Pallette Issues
This is a small glitch, and I have noticed it works with every color. Anyways, I have no idea on how to explain this glitch, other than to try and have you recreate it. Sorry.
1st: Pick any color, and under the "More" button set the V value (HSV) to anything less than 100 (For example set it to 50)
2nd: Click on the "Add Color to Pallette" icon and set it to any Pallette location you like
3rd: With your new color set, click on any other color in your Pallette
4th: Now click on your newly created color and you will notice that the V value is one less than what you set it as
That is pretty much it. Once again, as I said, it is small and it doesnt matter so much to me (I am color defficient) but I figured I would let you know :wink:
Yeah it's hard to figure out what terms to search for on this problem. "RGB HSV conversion precision" isn't really what most people think of when they encounter this!
