Better handling of fonts
I use paint.net very often and I have added some of my own fonts. When I access the fonts tab, it is very slow and hard to select the font that you want to use. I am asking that you would look into better compatibility for the people who manually add their fonts.
Thanks
Thaguh4real
Thaguh4real
If your fonts menu is slow, either you have far too many fonts, or you have 1 or more badly-designed fonts. Bad fonts make GDI+ cry. (GDI+ is the system library that PdN uses for its font handling).
If you can tell at which point in the scrolling the font menu becomes super-slow, you can figure out which font(s) is causing the problem, and uninstall it.
ambigram signature by Kemaru
[i write plugins and stuff]
