JS92 Posted January 19, 2008 Share Posted January 19, 2008 Yes you may have already guessed what this topic is about... if not then let me fill you in on some info about them...(correct me if i miss or say something wrong) RocketDock is a smoothly animated, alpha blended application launcher. It provides a nice clean interface to drop shortcuts on for easy access and organization. With each item completely customizable there is no end to what you can add and launch from the dock.Now with added Taskbar support your minimized windows can appear as icons on the dock. This allows for better productivity and accessibility. Quoted From Rocketdock™ Site Rocketdock Objectdock This is an image of the Rocketdock™. Features: •Minimize windows to the dock •Real-time window previews in Vista •Running application indicators •Simple drag-n-drop interface •Multi-monitor support •Supports alpha-blended PNG and ICO icons •Icons zoom and transition smoothly •Auto-hide and Popup on mouse over •Positioning and layering options •Fully customizable •Completely Portable •ObjectDock Docklet support. •Compatible with MobyDock, ObjectDock, RK Launcher, and Y'z Dock skins •Runs great on slower computers •Unicode compliant •Supports many languages and can easily be translated •A friendly user base •And best of all... its FREE!!! Examples taken from Rocketdock site! So, Which one do you use? I use Rocketdock and have only just downloaded it and can i say that it looks lovely and slick on my desktop! If you want to(and i know that there is a section for posting desktops but this one is only for rocket/stardock)...post your desktop to show your Rocketdock/Objectdock! (I will later) Quote Link to comment Share on other sites More sharing options...
Bobofthedead Posted January 19, 2008 Share Posted January 19, 2008 Stardock is not a docking program, what you're thinking of is Objectdock... Quote "I am the anarchist, I am the antichrist, I am the walrus, G'JOO G'GOO G'JOOB!" I dig a pygmy, by Charles Hawtree and the Deaf Aids. Phase One, in which Doris gets her oats. ~John Lennon Link to comment Share on other sites More sharing options...
JS92 Posted January 19, 2008 Author Share Posted January 19, 2008 Stardock is not a docking program, what you're thinking of is Objectdock... Edited: Just changed the 'Star...' to 'Object...'...sorry didnt realise. Quote Link to comment Share on other sites More sharing options...
Bobofthedead Posted January 19, 2008 Share Posted January 19, 2008 Thanks for that. I personally use Objectdock. It seems more complete and faster to me... Quote "I am the anarchist, I am the antichrist, I am the walrus, G'JOO G'GOO G'JOOB!" I dig a pygmy, by Charles Hawtree and the Deaf Aids. Phase One, in which Doris gets her oats. ~John Lennon Link to comment Share on other sites More sharing options...
Sozo Posted January 19, 2008 Share Posted January 19, 2008 Rocketdock has always worked well for me. Quote Link to comment Share on other sites More sharing options...
JS92 Posted January 19, 2008 Author Share Posted January 19, 2008 Thanks for that. I personally use Objectdock. It seems more complete and faster to me... Their site is very, very 'No 56K Warning' and i aint on 56K im on 2MB :oops: lol and it took a while for it too load for me! Ill check it out though. Quote Link to comment Share on other sites More sharing options...
Bobofthedead Posted January 19, 2008 Share Posted January 19, 2008 In all honesty, having tried both, Objectdock and Rocketdock both seem very similar. Are there any actual differences? Quote "I am the anarchist, I am the antichrist, I am the walrus, G'JOO G'GOO G'JOOB!" I dig a pygmy, by Charles Hawtree and the Deaf Aids. Phase One, in which Doris gets her oats. ~John Lennon Link to comment Share on other sites More sharing options...
Panhead Posted January 20, 2008 Share Posted January 20, 2008 i use rocketdock, i just got it Quote My deviantART iGraphix ~96% of teens won't stand up for God. Put this on your page if you're one of the 4% who will. skilletism (n.) - The abnormal liking of the band "Skillet". (see PANHEAD) panhead n. - an individual who shows extreme enthusiasm for the band Skillet. Generally driving for hours to concerts with frying pans riding shotgun. Link to comment Share on other sites More sharing options...
Olli Posted January 20, 2008 Share Posted January 20, 2008 I use ObjectDock but to bad they don't support multiple docks without paying. Quote wear our signature and earn 50 studiocredits. pm me your username if you want to participate. Link to comment Share on other sites More sharing options...
R3VENGE Posted January 20, 2008 Share Posted January 20, 2008 do they both work for xp?? if they do its likely ill get one of them. Quote psn id: R3V-fiR3 Link to comment Share on other sites More sharing options...
Wither Posted January 20, 2008 Share Posted January 20, 2008 do they both work for xp??if they do its likely ill get one of them. Minimum System Requirements: * Windows 2000/XP/Vista * 500Mhz or faster CPU * 10MB RAM free Please note that Windows XP x64 Edition, Windows Vista 64-bit Editions, and alternate shells are not supported. Quote YouTube | Myspace | deviantART Link to comment Share on other sites More sharing options...
R3VENGE Posted January 20, 2008 Share Posted January 20, 2008 thaqnks wither ill proabbly get it soon then Quote psn id: R3V-fiR3 Link to comment Share on other sites More sharing options...
jerkfight Posted January 20, 2008 Share Posted January 20, 2008 rocketdock is what i use Quote Link to comment Share on other sites More sharing options...
