Installer bug when closing system restore point
eNdi
Error "Could not find a part of the path 'C:\Program Files\Paint.NET\Staging" when installer is closing system restore point
Screen
I'm using Custom install and intalling program in "C:\Program Files\Grafika\Paint.NET (v3.22)" not "C:\Program Files\Paint.NET"
When I click "Continue" installer hangs.
When I use default path everything works OK.
Version 3.20 works OK. Tested version 3.22 Beta 2 and 3.22.
Screen
Did you change the default path after installation, or when you first installed Paint.NET? If so, the only thing you can really do is remove Paint.NET and re-install it correctly. Changing the directory after installation causes lots of trouble.
I'm always unistall any previous version before installing new. I'm always using custom install and I pick custom folder for installation. I'm not changing installation folder after installation.
Could you show us what the message is when that screen pops up? I don't mean the error message, I mean the box below that with all the exception details.
This looks like a bug in the installer.
For now, as a workaround, try installing to the default location and then re-run the installer and then choose the other directory that you want to use.
  • 4 weeks later...
