toe_head2001 Posted January 12, 2008 Share Posted January 12, 2008 I was wonder if any one has a technique on how get rounded corner gradients. In other words, go from this: To this: Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
oma Posted January 12, 2008 Share Posted January 12, 2008 are you sure you have to those pic right way around. you want to go from square bevels to rounded? if you want rounded bevels use the rounded edge rectangle tool draw your shape on transparent layer. magic wand inside of round edge rect. go to next transparent layer leaving selection active and use the plug in render bevel irregular shapes i generally use both primary and secondary same color when doing this. Quote My Deviant Art Gallery Oma's Paint.Net gallery Link to comment Share on other sites More sharing options...
david.atwell Posted January 12, 2008 Share Posted January 12, 2008 You can also use Shape3D and fiddle with the "rounded edges" option. Quote The Doctor: There was a goblin, or a trickster, or a warrior... A nameless, terrible thing, soaked in the blood of a billion galaxies. The most feared being in all the cosmos. And nothing could stop it, or hold it, or reason with it. One day it would just drop out of the sky and tear down your world.Amy: But how did it end up in there?The Doctor: You know fairy tales. A good wizard tricked it.River Song: I hate good wizards in fairy tales; they always turn out to be him. Link to comment Share on other sites More sharing options...
BoltBait Posted January 12, 2008 Share Posted January 12, 2008 Try it like this: Create 2 layers. Fill the bottom layer with your darkest color (gray). On the top layer, draw a rounded rectangle filled with white to the size you want. Gaussian blur that rounded rectangle layer using the amount of the size of your desired bevel. Flaten both layers into 1. Select magic wand and change the tolerance to 0. Shift-click in the darkest gray area outside of the bevel. Press the Delete key. Feather the result if necessary. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
toe_head2001 Posted January 12, 2008 Author Share Posted January 12, 2008 Thanks for the help. are you sure you have to those pic right way around. Oops :oops: Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
