wjeanp Posted February 17, 2006 Share Posted February 17, 2006 hi,,, am trying to download the newest paint.net but when i try to run it come up with this box NSIS error this installer you are trying to use is corrupled or incomplete.. i did try to download it again after taking the other one out.. thank you for any help with this... wanda :shock: Quote Link to comment Share on other sites More sharing options...
SearedIce Posted February 18, 2006 Share Posted February 18, 2006 Are you using some sort of download manager, or did you simply download it with Internet Explorer or your browser? If you are using a manager of some sort, try downloading it again with your browser (no download manager things), and see if it works then. If this doesn't work, try downloading the installer from another website...try download.com for instance. Quote Link to comment Share on other sites More sharing options...
wjeanp Posted February 19, 2006 Author Share Posted February 19, 2006 thank you for the help.. i did go to download.com and downloaded the 2.5 that one i had to also download the net 1.1 for it so that may have been why the 2.6 would not download.. now will try to update it to the 2.6 again thank you for the help have a great day wanda Quote Link to comment Share on other sites More sharing options...
