TommyCarlier Posted February 13, 2006 Share Posted February 13, 2006 I get this exception when I try to install Paint.NET 2.6 RC2 (also had it with previous versions of 2.6) on my WinXP SP2 PC at work (I didn't get the exception on my WinXP SP2 PC at home): System.IO.FileNotFoundException: Could not load file or assembly 'PaintDotNet.Resources, Version=2.6.2232.23934, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified. File name: 'PaintDotNet.Resources, Version=2.6.2232.23934, Culture=neutral, PublicKeyToken=null' at PaintDotNet.Setup.SetupWizard.MainImpl(String[] args) at PaintDotNet.Setup.SetupWizard.Main(String[] args) WRN: Assembly binding logging is turned OFF. To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1. Note: There is some performance penalty associated with assembly bind failure logging. To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog]. Quote Link to comment Share on other sites More sharing options...
TommyCarlier Posted February 27, 2006 Author Share Posted February 27, 2006 With the 2.6 final version, I still have this problem. After getting this error message, in "C:\Documents and Settings\tommy.carlier\Local Settings\Temp\PdnSetup" I can find 1 file: SetupFrontEnd, which is only 68KB. So my guess would be that some files were not extracted properly. Any ideas? Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 27, 2006 Share Posted February 27, 2006 Is there a file called PaintDotNet.Resources.dll ? Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
TommyCarlier Posted February 27, 2006 Author Share Posted February 27, 2006 Is there a file called PaintDotNet.Resources.dll ?No there isn't. Only SetupFrontEnd.exe. Quote Link to comment Share on other sites More sharing options...
