que0x Posted December 21, 2007 Share Posted December 21, 2007 Hi Folks, how would i replace color with transparent ? Thanks! Quote Link to comment Share on other sites More sharing options...
DarkShock Posted December 21, 2007 Share Posted December 21, 2007 This is how: Hit the "More >>" button on the colors window. This expands the window. Set the "Transparency - Alpha" to 0. :wink: Quote ---- Gallery | Sig Tutorial | deviantART | Sig Videos | PhotoBucket ----D E S T I N Y Link to comment Share on other sites More sharing options...
que0x Posted December 21, 2007 Author Share Posted December 21, 2007 thanks for sharing , but nothing replaced with i do this, i set all values to 0 and still can't replace a white background to transparent . Quote Link to comment Share on other sites More sharing options...
Wither Posted December 21, 2007 Share Posted December 21, 2007 Make sure the blend style is set to Overwrite. Edit: Ok, I was wrong. That won't do what you're asking. Sorry. Quote YouTube | Myspace | deviantART Link to comment Share on other sites More sharing options...
que0x Posted December 21, 2007 Author Share Posted December 21, 2007 still no luck, here is the image : how can i turn the white background into transparent ? many thanks ! Quote Link to comment Share on other sites More sharing options...
BoltBait Posted December 21, 2007 Share Posted December 21, 2007 Read this tutorial: viewtopic.php?f=15&t=3172 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
DarkShock Posted December 21, 2007 Share Posted December 21, 2007 still no luck,here is the image : how can i turn the white background into transparent ? many thanks ! Oh that's what you meant. Just go to the link BoltBait provided. :wink: Quote ---- Gallery | Sig Tutorial | deviantART | Sig Videos | PhotoBucket ----D E S T I N Y Link to comment Share on other sites More sharing options...
que0x Posted December 21, 2007 Author Share Posted December 21, 2007 thanks Folks , totally forgot the wand tool ! very helpful community here Quote Link to comment Share on other sites More sharing options...
DarkShock Posted December 21, 2007 Share Posted December 21, 2007 thanks Folks , totally forgot the wand tool !very helpful community here Glad you like it here and welcome to the PdN forums. :wink: Quote ---- Gallery | Sig Tutorial | deviantART | Sig Videos | PhotoBucket ----D E S T I N Y Link to comment Share on other sites More sharing options...
Addict Posted December 23, 2007 Share Posted December 23, 2007 Hi there. I've been messing with this and searching for quite some time on how to do what I'm trying to accomplish, but haven't been having much luck. I'm hoping someone can help me out here. Essentially, I have a GIF image I've converted to PNG so I can use the varying levels of Alpha available. I'm trying to turn the white areas into transparent colors, but am having issues. I can certainly do the wand/delete option, but the problem lies in that some of the areas are variations of white...and they need to be converted into varying levels of transparency. Here is a sample image: After wand/delete, it looks like this: Obviously, this isn't the desired result. So, I have tried using the fill tool with varying levels of tolerance, but that provides similar results...but to different portions of the image (not the desired result). I have also tried using the recolor tool, but it doesn't seem to want to replace with a transparent color at all...just dumps the same Alpha 255 color in place. So, is there a way to have it turn various shades of white into various shades of transparency? The only other option I can think of is to cut out everything but the top portion of the image and then create my own mirror of it below...but that's actually above my skill level so far. Any thoughts would be appreciated! Quote Link to comment Share on other sites More sharing options...
BoltBait Posted December 23, 2007 Share Posted December 23, 2007 The reflection is actually quite easy. You just need my wet floor effect plugin: http://boltbait.googlepages.com/reflections OK? Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Addict Posted December 23, 2007 Share Posted December 23, 2007 The reflection is actually quite easy. You just need my wet floor effect plugin:http://boltbait.googlepages.com/reflections OK? Hey, thanks! Kind of a round-about way to my solution, but it'll do. Thanks! Quote Link to comment Share on other sites More sharing options...
markandrew Posted January 6, 2008 Share Posted January 6, 2008 Hello, all, first posting. Despite having used the wand technique to make my background transparent, the saved image still shows with a white background, which makes the main image look very ugly. It seems, from what I've read, that true transparent backgrounds can only be achieved by saving as either .png or .gif - yes? Which means it doesn't work for .jpgs. However, having saved it alternatively as a .gif image, Photobucket is refusing to upload it as a .gif; though it tells me that's the file it's uploading, it actually turns up with a -1.jpg extension, so the background is still white. Any suggestions, please, as to where I might be going wrong, either in PDN or at Photobucket? Quote Link to comment Share on other sites More sharing options...
david.atwell Posted January 6, 2008 Share Posted January 6, 2008 You should set this as its own thread; that way people don't think it's a reply to an old problem. But to answer your question, I'm going to ask another: How are you saving it in Paint.NET? Are you manually typing the .GIF extension yourself, or selecting GIF from the drop-down list in the save dialog? If you would, please append the answer to that question to your original post and create a new thread. Thank you. :-) Quote The Doctor: There was a goblin, or a trickster, or a warrior... A nameless, terrible thing, soaked in the blood of a billion galaxies. The most feared being in all the cosmos. And nothing could stop it, or hold it, or reason with it. One day it would just drop out of the sky and tear down your world.Amy: But how did it end up in there?The Doctor: You know fairy tales. A good wizard tricked it.River Song: I hate good wizards in fairy tales; they always turn out to be him. Link to comment Share on other sites More sharing options...
Mike Ryan Posted January 7, 2008 Share Posted January 7, 2008 My HUGE suggestion would be using the Alpha mask plugin. It lets you remove the white and/ or black out of an image. Quote Link to comment Share on other sites More sharing options...
