Color filter box is too small.
That seems like either 1) a problem with your Windows display customization, or 2) a problem with the plugin, which should be posted in the thread for that plugin.
It was fixed, then it came back, and he's fixed it again.
You may wish to download the most recent package and re-extract.
You can get it here: viewtopic.php?f=16&t=20318
~ Becoming the Archetype
Thanks, I have just done that, and the problem has been fixed.
I don't remember downloading these effects seperately, and presumed they came in with the updates, thats why I reported the problem here.
It's fixed now, so thanks everyone.
