TwinBlade778 Posted December 15, 2007 Share Posted December 15, 2007 After I downloaded version 3.20, 3 invalid shortcuts appeared on my desktop. Every time I try to delete them, it says, 'Cannot delete file: Cannot read from source file or disk'. Is there a way to delete them? Quote Will make one when not lazy. Link to comment Share on other sites More sharing options...
Andrew D Posted December 15, 2007 Share Posted December 15, 2007 After I downloaded version 3.20, 3 invalid shortcuts appeared on my desktop. Every time I try to delete them, it says, 'Cannot delete file: Cannot read from source file or disk'. Is there a way to delete them? Press F5 when on your desktop. It should get rid of most of them. Quote Link to comment Share on other sites More sharing options...
Myrddin Posted December 16, 2007 Share Posted December 16, 2007 In the past (actually, my past at least), the problem usually attributes itself to the file - the shortcut - being Read-only. Right click on shortcut > Properties > uncheck the 'Read-only' box. This is not a guaranteed solution to the problem, but could work nevertheless. You could also restart your computer and try again - whether you have since the install or not. Quote How to Use Images in Your Posts, Signatures, and AvatarsHow to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
