Toli's Effects (v2.0.2, 20 Jan. 2008)
Toli
I tried out your effects.
The vertical flip button flips horizontal. The horizontal flips vertical.
I am not really certain what the 1st and second diagonal do.
I think you also need to rename a button 90 CCW(counter clockwise).
Just like they doing in photoshop transform.
I had read such good reports on this plugin and now I am disappointed :( .
Teacher:You have 70 minutes to take the FCC GROL license.
Student: How many lifelines do we get ?
I edited the ini files and made it a bit better for me.
now the buttons do what they say.
But I still would like Horizontial flip button to come before
vertical flip button.
I prefer the order of the buttons to be.
None
Vertical flip button.
Rotate 90 CW button.
Rotate 90 CCW button.
Rotate 180 button.
1st diagonal
2nd diagonal
same thing for the mirror/rotate menu
:cry:
Sorry, but you were wrong...
The buttons always did what they said.
You must understand that:
Horizontal Mirror = Vertical Flip
Vertical Mirror = Horizantal Flip
I never used and I will never use the word "flip" anywhere in my plugins, because of this possible ambiguity.
The First and Second Diagonal Mirrors do just this: A mirror (geometrical transformation) on the respective diagonal...
I really, cannot care less about what photoshop or other software does. Whoever likes that software may buy it. I will not.
I am sure that, if you think for a few seconds, you will understand this equivalence.
It's so simple: If you place a real mirror horizontally, the image will be flipped vertically, isn't it?
And as the order of the buttons / menus, it is the natural order of the geometric transformations as in their abstract algebraic structure, the geometric transformations group.
And your proposed order makes very little sense, because you separated the mirrors from the rotations, which should be kept toghether because they are similar geometric transformations. (the rotations keep the image intact, the mirrors convert it into its enantiomer, isn't it so?)
If you do not fully understand me, I reccommend searching the unknown terms in Wikipedia
The Author.
  • 2 months later...
  • 6 years later...
I'm getting this crash in PDN 4.0 For the Engrave/Emboss plugin. I used 5px Engrave on text I magic wanded.
This text file was created because paint.net crashed. Please e-mail this to crashlog4@getpaint.net so we can diagnose and fix the problem.
Application version: paint.net 4.0 (β 4.0.5168.12074)
Time of crash: 22/04/2014 04:26:38 PM
Application uptime: 00:05:27.9331389
Application state: Running
Working set: 200,988 KiB
Install directory: C:\Program Files\Paint.NET
OS Version: 6.3.9600.0 Workstation x64
.NET version: CLR 4.0.30319.34014 x64, FX 4.0 4.5
Processor: 4x "Intel(R) Core(TM) i5-3330S CPU @ 2.70GHz" @ ~2694MHz (DEP, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, XSAVE)
Physical memory: 8076 MB
Hardware acceleration: True
Video card: Intel(R) HD Graphics, Microsoft Basic Render Driver
UI animations: True
UI theme: Aero/Aero + DWM (Aero.msstyles)
Updates: True, 22/04/2014
Locale: pdnr.c: en-GB, hklm: en-GB, hkcu: en-GB, cc: en-GB, cuic: en-GB
Exception details:
System.MissingMethodException: Method not found: 'Void PaintDotNet.Utility.ClipNumericUpDown(System.Windows.Forms.NumericUpDown)'.
at Toli.EngraveEmbossEffectConfigDialog.UpDownWidth_Leave(Object sender, EventArgs e)
at System.Windows.Forms.ContainerControl.UpdateFocusedControl()
Managed assemblies:
mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscorlib.dll
PaintDotNet, Version=4.0.5168.12074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.exe
PaintDotNet.Base, Version=4.0.5168.12074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Base.dll
PaintDotNet.Core, Version=4.0.5168.12074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Core.dll
PaintDotNet.SystemLayer, Version=4.0.5168.12074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.dll
PaintDotNet.Framework, Version=4.0.5168.12074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Framework.dll
PaintDotNet.Resources, Version=4.0.5168.12074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Resources.dll
PaintDotNet.Data, Version=4.0.5168.12074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Data.dll
PaintDotNet.Effects, Version=4.0.5168.12074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Effects.dll
PaintDotNet.SystemLayer.Native.x64, Version=4.0.5168.12074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x64.dll
Alpha2Gray, Version=3.5.4315.35825, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha2Gray.dll
BasicAntialias11, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BasicAntialias11.dll
Burninate, Version=3.5.4315.36944, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Burninate.dll
ColorBalance, Version=3.5.4315.35037, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorBalance.dll
CustomBrushesMini, Version=2.1.4039.25699, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CustomBrushesMini.dll
DragFrom, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DragFrom.dll
Dream, Version=3.5.4318.27691, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Dream.dll
EditableText, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EditableText.dll
EngraveEmboss, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EngraveEmboss.dll
ExtendBorder, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ExtendBorder.dll
FindEdges, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FindEdges.dll
Flip, Version=3.5.4315.37010, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Flip.dll
GaussianBlurPlus, Version=3.5.4315.35054, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GaussianBlurPlus.dll
Gray2Alpha, Version=3.5.4318.27219, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gray2Alpha.dll
IniFile, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\IniFile.dll
Landscape, Version=3.5.4315.35071, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Landscape.dll
MirrorRotate, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MirrorRotate.dll
MirrorRotateMenu, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MirrorRotateMenu.dll
ObjectFeather, Version=3.5.4315.35085, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ObjectFeather.dll
Olden, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Olden.dll
Feather, Version=2.3.4315.37038, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OldFeather.dll
OutlineObject, Version=1.1.3160.31739, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Outline.dll
PasteAlpha, Version=3.5.4315.35562, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PasteAlpha.dll
Pastel, Version=3.5.4315.35379, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Pastel.dll
PhotoAdjustments, Version=3.5.4315.35128, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PhotoAdjustments.dll
Polygon, Version=3.5.4315.35143, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polygon.dll
PrinterPlus, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PrinterPlus.dll
ReflectionFlat, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ReflectionFlat.dll
SBCommon, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SBCommon.dll
SelectionTools, Version=3.5.4320.16766, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SelectionTools.dll
Shape3D, Version=1.2.6.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Shape3D.dll
Smooth, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Smooth.dll
ThatOtherApp, Version=2.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ThatOtherApp.dll
Transparency, Version=3.5.4315.35159, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Transparency.dll
Vandermotten.PaintDotNetEffects.Blurs, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll
Vandermotten.PaintDotNetEffects.ColorAccent, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll
Vandermotten.PaintDotNetEffects, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.dll
Vandermotten.PaintDotNetEffects.DropShadow, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll
Vandermotten.PaintDotNetEffects.Duotones, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll
Vandermotten.PaintDotNetEffects.FadeEdge, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll
Vandermotten.PaintDotNetEffects.Gradient, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll
Vandermotten.PaintDotNetEffects.Grid, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Grid.dll
Vandermotten.PaintDotNetEffects.Monochromes, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll
Vandermotten.PaintDotNetEffects.ObjectAlign, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll
AnimGIF, Version=2.4.4119.28305, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\AnimGIF.dll
AsciiArtFileType, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\AsciiArtFileType.dll
IcoCur, Version=3.7.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\IcoCur.dll
ImSVG.FileType, Version=0.10.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ImSVG.FileType.dll
ImXCF.FileType, Version=1.1.4411.19122, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\ImXCF.FileType.dll
PhotoShop, Version=2.4.0.32275, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\PhotoShop.dll
WebPFileType, Version=1.0.0.7, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\WebPFiletype.dll
WMF2WPF, Version=1.3.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\WMF2WPF.dll
WMFFileType, Version=1.3.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\WMFFileType.dll
WPFGDI, Version=1.3.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\FileTypes\WPFGDI.dll
WindowsFormsIntegration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\WindowsFormsIntegration\v4.0_4.0.0.0__31bf3856ad364e35\WindowsFormsIntegration.dll
OptionBasedLibrary v0.4, Version=0.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\OptionBasedLibrary v0.4.dll
Native modules:
C:\Program Files\Paint.NET\PaintDotNet.exe, version=4.0.5168.12074
C:\WINDOWS\SYSTEM32\ntdll.dll, version=6.3.9600.17031 (winblue_gdr.140221-1952)
C:\WINDOWS\SYSTEM32\MSCOREE.DLL, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\system32\KERNEL32.dll, version=6.3.9600.17031 (winblue_gdr.140221-1952)
C:\WINDOWS\system32\KERNELBASE.dll, version=6.3.9600.17031 (winblue_gdr.140221-1952)
C:\WINDOWS\system32\apphelp.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\system32\ADVAPI32.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\system32\msvcrt.dll, version=7.0.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\SYSTEM32\sechost.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\system32\RPCRT4.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll, version=4.0.30319.34014 built by: FX45W81RTMGDR
C:\WINDOWS\system32\SHLWAPI.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\SYSTEM32\combase.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\system32\USER32.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\system32\GDI32.dll, version=6.3.9600.17042 (winblue_gdr.140307-1710)
C:\WINDOWS\system32\IMM32.DLL, version=6.3.9600.17031 (winblue_gdr.140221-1952)
C:\WINDOWS\system32\MSCTF.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll, version=4.0.30319.34014 built by: FX45W81RTMGDR
C:\WINDOWS\SYSTEM32\MSVCR120_CLR0400.dll, version=12.00.20806.33440 built by: FX45W81RTMREL
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\mscorlib\a20cafac04a2e9b3bcb5ec4d674775e5\mscorlib.ni.dll, version=4.0.30319.34014 built by: FX45W81RTMGDR
C:\WINDOWS\system32\ole32.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\SYSTEM32\CRYPTBASE.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\SYSTEM32\bcryptPrimitives.dll, version=6.3.9600.17031 (winblue_gdr.140221-1952)
C:\WINDOWS\system32\uxtheme.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System\10e3367d9097070044e05c2825a4a1e9\System.ni.dll, version=4.0.30319.34003 built by: FX45W81RTMGDR
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\WindowsBase\fbfdc2935a4c1e34bec335d2cf21d303\WindowsBase.ni.dll, version=4.0.30319.34004 built by: FX45W81RTMGDR
C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\system32\rsaenh.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\SYSTEM32\bcrypt.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Drawing\7b48e37359be1aebd4e9f302040d517d\System.Drawing.ni.dll, version=4.0.30319.33440 built by: FX45W81RTMREL
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PresentationCore\71df43fcb7a7745ef38a6ce40ff33c2d\PresentationCore.ni.dll, version=4.0.30319.34004 built by: FX45W81RTMGDR
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\Presentatio5ae0f00f#\37aa83ffa60682e364b3caea876452c9\PresentationFramework.ni.dll, version=4.0.30319.34004
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Core\4c30ba993ce1f4d74c3fe26ffa9cd4a4\System.Core.ni.dll, version=4.0.30319.33440 built by: FX45W81RTMREL
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Base\3ffa8b3a50349465d49e5addfe82884f\PaintDotNet.Base.ni.dll, version=4.0.5168.12074
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Windows.Forms\00d5b8fae6d70bea4fe037311f3ee7e6\System.Windows.Forms.ni.dll, version=4.0.30319.33440 built by: FX45W81RTMREL
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet500b2e4f#\2282da149cd375ecff3a511f8d7f3bec\PaintDotNet.SystemLayer.ni.dll, version=4.0.5168.12074
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Core\61abbdaa2de2dc11597f7385e5be0728\PaintDotNet.Core.ni.dll, version=4.0.5168.12074
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet26779e70#\95256b16b114849473de63c112761f94\PaintDotNet.Resources.ni.dll, version=4.0.5168.12074
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet7afaaa15#\3388c6b4244553e05d15a3dfc13b1e8c\PaintDotNet.Framework.ni.dll, version=4.0.5168.12074
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Data\abbda7840c5b1575922ed0f5b9555e4a\PaintDotNet.Data.ni.dll, version=4.0.5168.12074
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet.Effects\de7fa72fd232ec5402a17e229adf161e\PaintDotNet.Effects.ni.dll, version=4.0.5168.12074
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNet\142629481eaf0dca5f6ae83b0197debd\PaintDotNet.ni.exe, version=4.0.5168.12074
C:\WINDOWS\SYSTEM32\dwrite.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\wpfgfx_v0400.dll, version=4.0.30319.33440 built by: FX45W81RTMREL
C:\WINDOWS\system32\OLEAUT32.dll, version=6.3.9600.16506
C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\PresentationNative_v0400.dll, version=4.0.30319.33440 built by: FX45W81RTMREL
C:\WINDOWS\system32\shell32.dll, version=6.3.9600.17031 (winblue_gdr.140221-1952)
C:\WINDOWS\SYSTEM32\SHCORE.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrjit.dll, version=4.0.30319.34014 built by: FX45W81RTMGDR
C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x64.dll, version=4.0
C:\WINDOWS\SYSTEM32\MSVCR100.dll, version=10.00.40219.325
C:\WINDOWS\SYSTEM32\VCOMP100.DLL, version=10.00.40219.325 built by: SP1LDR
C:\WINDOWS\SYSTEM32\MSVCP100.dll, version=10.00.40219.325
C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.00.9600.17031 (winblue_gdr.140221-1952)
C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.9600.17056_none_932f2645474c8242\gdiplus.dll, version=6.3.9600.17055 (winblue_gdr.140318-1651)
C:\WINDOWS\SYSTEM32\profapi.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\PaintDotNetc8826574#\7de16ae1f484892f0e2cf7407caa3879\PaintDotNet.SystemLayer.Native.x64.ni.dll, version=4.0
C:\WINDOWS\SYSTEM32\clbcatq.dll, version=2001.12.10530.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\System32\UIAnimation.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\system32\dwmapi.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\SYSTEM32\version.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.9600.17031_none_6242a4b3ecbb55a1\comctl32.dll, version=6.10 (winblue_rtm.130821-1623)
C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.9600.16384_none_34a8918f959016ea\comctl32.dll, version=6.10 (winblue_rtm.130821-1623)
C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=6.3.9600.16521 (winblue_gdr.140128-1545)
C:\WINDOWS\system32\d2d1.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\SYSTEM32\WINSTA.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\SYSTEM32\d3d11.dll, version=6.3.9600.17041 (winblue_gdr.140305-1710)
C:\WINDOWS\SYSTEM32\dxgi.dll, version=6.3.9600.17041 (winblue_gdr.140305-1710)
C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=6.3.9600.16505 (winblue_gdr.140106-1506)
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xaml\ce7fa13bc9c249e693cfa3a6ab2c2810\System.Xaml.ni.dll, version=4.0.30319.33440 built by: FX45W81RTMREL
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Xml\a0f91cf4cae3b99bd02319f6a31fa079\System.Xml.ni.dll, version=4.0.30319.33440 built by: FX45W81RTMREL
C:\WINDOWS\SYSTEM32\igd10iumd64.dll, version=10.18.10.3325
C:\WINDOWS\SYSTEM32\ncrypt.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\SYSTEM32\NTASN1.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\SYSTEM32\igdusc64.dll, version=8.15.10.9141
C:\WINDOWS\SYSTEM32\winmm.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\SYSTEM32\WINMMBASE.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\SYSTEM32\cfgmgr32.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\SYSTEM32\DEVOBJ.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\system32\explorerframe.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\system32\DUser.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\system32\DUI70.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\Program Files\Paint.NET\Effects\Alpha2Gray.dll, version=3.5.4315.35825
C:\Program Files\Paint.NET\Effects\BasicAntialias11.dll, version=0.0.0.0
C:\Program Files\Paint.NET\Effects\Burninate.dll, version=3.5.4315.36944
C:\Program Files\Paint.NET\Effects\ColorBalance.dll, version=3.5.4315.35037
C:\Program Files\Paint.NET\Effects\CustomBrushesMini.dll, version=2.1.4039.25699
C:\Program Files\Paint.NET\Effects\DragFrom.dll, version=1.1.0.0
C:\Program Files\Paint.NET\Effects\Dream.dll, version=3.5.4318.27691
C:\Program Files\Paint.NET\Effects\EditableText.dll, version=1.0.1.0
C:\Program Files\Paint.NET\Effects\EngraveEmboss.dll, version=2.0.2
C:\Program Files\Paint.NET\Effects\ExtendBorder.dll, version=1.3.0.0
C:\Program Files\Paint.NET\Effects\FindEdges.dll, version=1.2.0.0
C:\Program Files\Paint.NET\Effects\Flip.dll, version=3.5.4315.37010
C:\Program Files\Paint.NET\Effects\GaussianBlurPlus.dll, version=3.5.4315.35054
C:\Program Files\Paint.NET\Effects\Gray2Alpha.dll, version=3.5.4318.27219
C:\Program Files\Paint.NET\Effects\IniFile.dll, version=2.0.2
C:\Program Files\Paint.NET\Effects\Landscape.dll, version=3.5.4315.35071
C:\Program Files\Paint.NET\Effects\MirrorRotate.dll, version=2.0.2
C:\Program Files\Paint.NET\Effects\MirrorRotateMenu.dll, version=2.0.2
C:\Program Files\Paint.NET\Effects\ObjectFeather.dll, version=3.5.4315.35085
C:\Program Files\Paint.NET\Effects\Olden.dll, version=1.5.0.0
C:\Program Files\Paint.NET\Effects\OldFeather.dll, version=2.3.4315.37038
C:\Program Files\Paint.NET\Effects\Outline.dll, version=1.1.3160.31739
C:\Program Files\Paint.NET\Effects\PasteAlpha.dll, version=3.5.4315.35562
C:\Program Files\Paint.NET\Effects\Pastel.dll, version=3.5.4315.35379
C:\Program Files\Paint.NET\Effects\PhotoAdjustments.dll, version=3.5.4315.35128
C:\Program Files\Paint.NET\Effects\Polygon.dll, version=3.5.4315.35143
C:\Program Files\Paint.NET\Effects\PrinterPlus.dll, version=1.5.0.0
C:\Program Files\Paint.NET\Effects\ReflectionFlat.dll, version=1.0.0.0
C:\Program Files\Paint.NET\Effects\SBCommon.dll, version=3.0.0.0
C:\Program Files\Paint.NET\Effects\SelectionTools.dll, version=3.5.4320.16766
C:\Program Files\Paint.NET\Effects\Shape3D.dll, version=1.2.6.0
C:\Program Files\Paint.NET\Effects\Smooth.dll, version=2.0.2
C:\Program Files\Paint.NET\Effects\ThatOtherApp.dll, version=2.2.0.0
C:\Program Files\Paint.NET\Effects\Transparency.dll, version=3.5.4315.35159
C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll, version=3.8.0.0
C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll, version=3.8.0.0
C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.dll, version=3.8.0.0
C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll, version=3.8.0.0
C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll, version=3.8.0.0
C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll, version=3.8.0.0
C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll, version=3.8.0.0
C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Grid.dll, version=3.8.0.0
C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll, version=3.8.0.0
C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll, version=3.8.0.0
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Configuration\436bd23db5f3a6b8799945332afc0899\System.Configuration.ni.dll, version=4.0.30319.33440 built by: FX45W81RTMREL
C:\Windows\Microsoft.NET\Framework64\v4.0.30319\diasymreader.dll, version=12.0.20806.33440 built by: FX45W81RTMREL
C:\Program Files\Paint.NET\FileTypes\AnimGIF.dll, version=2.4.4119.28305
C:\Program Files\Paint.NET\FileTypes\AsciiArtFileType.dll, version=1.0.0.0
C:\Program Files\Paint.NET\FileTypes\IcoCur.dll, version=3.7.0.0
C:\Program Files\Paint.NET\FileTypes\ImSVG.FileType.dll, version=0.10.0.0
C:\Program Files\Paint.NET\FileTypes\ImXCF.FileType.dll, version=1.1.4411.19122
C:\Program Files\Paint.NET\FileTypes\PhotoShop.dll, version=2.4.0.0
C:\Program Files\Paint.NET\FileTypes\WebPFiletype.dll, version=1.0.0.7
C:\Program Files\Paint.NET\FileTypes\WMF2WPF.dll, version=1.3.1.0
C:\Program Files\Paint.NET\FileTypes\WMFFileType.dll, version=1.3.1.0
C:\Program Files\Paint.NET\FileTypes\WPFGDI.dll, version=1.3.1.0
C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\WindowsForm0b574481#\551df8c5bd0a143c9ed5c53aab20b9ca\WindowsFormsIntegration.ni.dll, version=4.0.30319.34004 built by: FX45W81RTMGDR
C:\Program Files\Paint.NET\OptionBasedLibrary v0.4.dll, version=0.3.0.0
C:\WINDOWS\system32\SETUPAPI.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\system32\WINTRUST.dll, version=6.3.9600.17016 (winblue_gdr.140201-2007)
C:\WINDOWS\system32\CRYPT32.dll, version=6.3.9600.16431 (winblue_gdr.131015-2301)
C:\WINDOWS\system32\MSASN1.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
C:\WINDOWS\system32\psapi.dll, version=6.3.9600.16384 (winblue_rtm.130821-1623)
pdnsig.png?psid=1
  • 6 months later...
  • 2 years later...
No Offense Toli & Pyro, but feel like a kid over-hearing adults, does the (awesome sounding) plugin work after all in PDN 4.0? Is it a simple cretin install for 'vacuum for brains' people like myself? Or do I need go back to school, discover how to manipulate the known universe to install? Shh! For sure you going to say go back to school... I'd just been following Welshblues lead on Glossy effect https://forums.getpaint.net/topic/26860-glossy-metallic-text/ and seem to have wondered into a discussion between Newton/Einstein that has left me very non-plussed as to continue or not. Thanks
After I waded through all the innuendo I couldn't really  understand what you were asking.
I'll assume you are not sure how to 'install' the Plugin?   See here how to do that.
Nope. I say: Keep calm and be careful with your words.
Hey Andrew, Thank you for your help.
Hello Pixie & Iron, thank you for answering. Allow me to put an end to your incorrect understanding - I was belittling myself & acknowledging my own lack of expertise. You needn't feel my insulting myself is in anyway a reflection on or meant for you. There wasn't innuendo at all, you guys are absolute masters, which is why I mentioned 'listening to the two clever people from our history' because I'd read the go in here, change this to that, copy this & alter that, then it would work (Trinity's post) - which I'd hesitate to do due to my inexperience but had still wanted to use Toli's effect. It was never my intention to slight any of you. I'm really in awe of the gifts people display in the forums. It looks as if you thought I was being nasty to someone. Perhaps you are unused to finding honest people championing you & blaming themselves for their own inadequacies, that you were under the impression I was being unkind to Toli. I hope you are both satisfied on my intent & mindset now and can accept my explanation as being genuine.
Hi Toli, thank you for not getting upset & also quietly chastising me. I meant what I'd said, it reads as an awesome extension & I hope that I'll have the grey matter to make use of it & others' writers (Pyros') effects.
As much as I'd love to get the most out of Paint.net, I don't really have the time for the learning curve. I've a 'sort of' ability to use in a simple manner but it is not my industry, so battle now & then, when I need it. Like now, I need create something beyond my immature grasp which impresses as professional. So must find out how to get the desired result & do it within my own time constraints. All the best to everyone.
I don't think anyone thought you were being insulting--just that your verbosity was unexpected. If you got excited, someone might misunderstand (hence Iron67's caution; he's refreshingly blunt and would not hesitate to call you out if he saw a problem :) ).
The installation is quite simple: just follow the links that AndrewDavid and Pixey gave you, then you're all set!
